Question about Hotpoint -Ariston VVSR1030HWO Top Load Washer
Hotpoint Aristont front-load washer. How to remove top cover
Bob Gemmell
  • 209 Answers
SOURCE: Need to remove top cover of GE WPXQ3090T2WW top load washer
There should be 2 screws holding it on at the rear. Looking from the rear these will be at each top corner. Once these are removed push the lid from the front of the machine towards the rear and it will pop off.
Posted on Sep 13, 2007
  • 1028 Answers
SOURCE: How do you remove the
clips just under front edge and about 3-4 ins from corners press in with putty knife lift top remove screws on upper edge either inside just below top or along top edge
Posted on Aug 10, 2008
Maytag317
  • 1136 Answers
SOURCE: Top loading maytag washer leaking water during wash cycle
Hi, There are two spring clips located in the gap between the top and front panel. They are the edges.
If the pump and hoses aare ok, fill the washer with water and look up toward the center of the tub abd transmission area. It migth have a seal going bad.
I hope this helps.
Vic
Posted on May 30, 2009
  • 5 Answers
SOURCE: hotpoint wd64 front load washer-dryer filter
if your hotpoint has no obvious filter its likely to be the type that has the filter built into the main exit hose from the drum to the pump. Clearing these is not as easy.Pull machine out and unplug it, on the rear there is a panel at the bottom which when removed you will see the pump where the exit hose attaches. From the pump to the drum is normally a wider black pipe and this contains the filter. removal of the pipe from the bottom of the drum is normally a jubilie clip but some have plastic clips that are easy to break. once you have dropped the pipe from the drum ( water goes everywhere ) you can then remove the white filter assembly which is like a shuttle **** with ping pong ball in it. clean out fully and make sure its all back together as before.
Posted on Sep 17, 2009
barkencoa
  • 3463 Answers
SOURCE: Locating the filter on the Hotpoint WMA54 front load washer
To check and clean the filter, you need to remove the lower rear panel of washer.
Locate and remove the large black hose fastened to bottom of drum.
Remove and clean filter inside hose.
Remove hose onto pump, and check for obstruction or blockage here and in the pump as well.
Hope this helps to solve your question.
Please leave feedback.
Thanks.
Posted on Dec 12, 2009
Testimonial: "Spot-on advice ticked all the boxes. Problem appears to have been resolved!"
How to take of front panel and side panel to get at drum
You dont...
Take of top cover, remove top front panel. Remove front, two screws top front, two screws bottom front, loosen the doorlock and door bellow. Disconnect everything on the drum, (motor, dampers, heater, water pressure switch hose ect. Lift the drum out. Good luck.
Sep 27, 2014 | Hotpoint WF430 Front Load Washer
How do i remove rubber seal on hotpoint washing machine for getting in to door lock
No need to remove seal.
Remove top cover, undo 2 screws securing door lock. and reach down inside the washer to access the door lock.. This is the easy to do it.
Feb 04, 2010 | Hotpoint Aquarius WD63 Front Load...
How do i get inside the Hotpoint Aquarius WD640 Front Load
The top cover can be removed by undoing screws at rear of cover, and sharply pushing forward on cover to remove.
The lower rear panel of washer is also removeable.
Jan 15, 2010 | Hotpoint Aquarius WD640 Front Load...
How to remove back from machine
There is a small cover at bottom rear of washer, this is the only access into the washer from the rear.
Simply undo the pozidrive screws, and remove cover.
Any other access is from the top, or by removing the front panel assy.
Hope this helps.
Jan 04, 2010 | Hotpoint WMA58 Front Load Washer
How Do you take the top off the Washing Machine Hotpoint WMA40
you need to remove the screws at the kick panel on the lower front panel by the floor, then the top cover screws are under top cover inside machine remove these and top will lift up
Dec 24, 2009 | Hotpoint WMA40 Front Load Washer
How to I remove the drum from a Hotpoint WM64 washing machine? I need to change the bearings.
Remove top cover and rear panel.
Remove belt and drum drive pulley.Remove clamp that secures door seal
Remove top control console panel.
Remove door lock.
Remove screws top and bottom holding front panel, remove front panel.
Remove spring clips holding plastic drum front, lift to one side plastic drum front cover.
Tap drum shaft to remove drum from container, remove bearings.
Please rate my solution.
Thanks.
Sep 04, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
How do i change the brushes on my wma35 hotpoint washing machine so that it'll spin?
unplug first then remove top cover motor should be there remove motor 2 bolts then u can change brushes
Jun 30, 2009 | Hotpoint WMA30 Front Load Washer
I need to replace a door seal, Hotpoint Ultima WF860
Push the top cover to the rear and lift at the same time, then ease the control panel to the right, you will not get control panel off with the top cover in place.
This will then give you access to the front panel scews, located at the top and bottom of the panel. remove the door seal ,and door lock, then lift the front panel away.
Nov 25, 2008 | Hotpoint Ultima WF860 Front Load Washer
Model WMA 42
The 2 screws securing the top are located behind 2 plastic covers on the front top, remove these 2 covers and the screws are located there, you will need a torx screwdriver to remove the screws.
Sep 08, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint -Ariston VVSR1030HWO Top Load Washer Logo
26 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
