Question about Pioneer 12-Disc CD Changer for IP-Bus In-Dash Decks
Music Plays with Pauses on Bumpy Roads.
I have Pioneer 12 CD Changer installed in my car. It plays music normally when the car is still or moving on smooth surface. The problem starts when moving on Bumpy road the sound starts to flipflop. Kindly advise the solution.
  • 175 Answers
Check its mounted securly if it is then lens will need cleaniing failing that lens will prob be on the way out
Posted on May 28, 2010
What station does the 12 cdx run on?
according to pioneer their are 12 FM frequencies (stations) they start at 87.9 mhz and go to 90.1 mhz (fm) in0.2 mhz steps select with your remote. and set station and enjoy your music.
Sep 23, 2012 | Pioneer CDX-FM1287 12-Disc CD Changer
BOSE WAVE MUSIC SYSTEM PLAYS CD BUT DOES NOT TURN OFF
It is probable that the battery will need to be changed, this the first step to find out if additional work is required.
May 17, 2012 | Bose Wave music system with multi-CD...
My Pioneer DEH-4900IB plays music but there is no power to the unit. I can't turn it on or off, change volume, see a display but it still plays music. How can it do that?
I just had the same problem with my Pioneer radio. I pulled the radio fuses from my car's fuse box. This essentially forced the radio to turn off. A couple days later I placed the fuses back in and the radio functioned normally. Hopefully this will work for you.
Sep 03, 2010 | Car Audio & Video
Music plays normally at first then begins to cut out. The problem gets worse as the CD continues to play. RCA RP8070 Five Disc Changer. THANKS
There is a problem with the laser pic-up assembly(eye) 1st,2nd, 3rd,4rth music/track are recorded on disc from the center to edge.As the laser moves toward the edge the laser can't read perfectly the stored data on the disc. possible cause:the disc is in figure of 8, the lens needs cleaning, the suspension of the laser assembly,poor recording speed,spindle motor and voltage fluctuation of VCC
Sep 01, 2009 | RCA RP8070 5-Disc CD Changer
I have got a rca 5 disc changer rp 8055c it want play my cd
RCA 5 DISK CD PLAYER AND RADIO CANT HERE MUSIC LIGHTS COME ON CD PLAYS BUT NO SOUND.
HELP
Aug 16, 2009 | RCA RP8078 5-Disc CD Changer
I can not hear any audio
If you have the correct head unit, and assuming the cable is in good condition, the it should work. Although I do remember some Pioneers needed Permanent 12V+ and ground hooked up in order to work. If this is one of those, on the changer side there should be another white plug next to the changer cable with two or three wires in it. This should be the power feed wirs for the changer. I need more info to confirm.
Jun 14, 2009 | Pioneer CDXP1280 Multi-Disc CD Player...
Pionner cd-iu200v plays video from Iphone, no picture on avh4100
Check the initial settings menu (you will probably have to reset the system to get it to reappear) and set the aux 1 to IPOD. This will let the ipod video play via the aux 1 just like it is supposed to. This solution is buried in the manual but is really hard to pull together.
May 11, 2009 | Pioneer AVH-5700DVD DVD AV HEADUNIT...
Do All DVD Players Also Play Music CD's
All DVD Players will read and play CD players
Nov 16, 2008 | Hitachi GD 7500 Internal DVD Drive
Pioneer CDX_1280 12 Disc Changer
hi sounds like dirty laser, or dodgy disc.
check your cd for marks. you could try a cd cleaner disc. this may cause it
other wise its a new laser
Mark
Blue ICE
www.blueice-electronics.co.uk
Jan 04, 2008 | Pioneer CDX-P1280 12-Disc CD Changer
CD changer problem
According to the manual, error 11 means the disc is inserted upside down.
Oct 11, 2007 | Pioneer CDX-FM1289 12-Disc CD Changer
Pioneer 12-Disc CD Changer for  IP-Bus In-Dash Decks Logo
59 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
