Question about Car Audio & Video
Half of my dash is working and half is not??
I changed the stock deck in my civic si 2005 but when i finished the the half dash was working and the other half wasnt working?
  • blingbling81 May 28, 2010
    which part? check fuses and ill
  • dsosalopez May 28, 2010
    i checked the 2 boxes of fuses and all them are good.
  • 175 Answers
Is it a display? there is extra wires in the harness that runs the display lik a holden astra
Posted on May 28, 2010
I disconnected the battery to my 98 honda civic lx. When I connected the battery back up the car would not start and the red led light on the dash is blinking three times and a relay is clicking and...
read the section on the immobilizer. if stock? is it? or aftermarket alarms, or immobilizers. did not, this begin in 2002? STOCK?
well if true , your car has custom IMMO and wiring.
custom devices, have custom programming and methods......
Here is how i found its not stock.....
in the operators guide . there are 7 civic op guides, (sub models)
Si,wagon, De sol, hatch,sedan, coupe and hybrid.???????
http://justgivemethedamnmanual.com/honda/honda-civic-sedan-owners-manuals/
zero IMMO in books.
so, is not stock and with all cars not stock you get to find
out what they put in the car, brand, make and model
that takes looking at the box added to car, then posting that...
my posts (all) are USA, and LHD cars. what yours is?,, im clueless
toggle switch to me. rings the custom bell , ding ding?
Aug 28, 2013 | Honda Civic Cars & Trucks
How to take out a 2003 honda civic stocked deck
Disconnect Battery, remove lower dash knee bolster. you'll need to disconnect the 2 bulk connectors on top of the fuse box.-------------------------------------------------------------------------------------
Renault diagnostic tool
Dec 10, 2012 | Cars & Trucks
When I checked my oil it was under the hole closest to the tip does this mean I need oil? and how do I know it's full/ how many quarts of oil does my car take? 2005 civic si 2.0
Start by adding 1/2 quart. Recheck the level. If it is now half way between the two marks than add the rest of the quart. The oil level should always be in between the two marks on the dipstick and close to the top mark.
Oct 17, 2010 | 2005 Honda Civic
How do I change the low beam bulb on a 2005 Honda Civic SI?
  1. Disconnect the 2P connector from the headlight.
  2. Turn the low beam bulb socket 45°counterclockwise to remove it from the headlight.
  3. Install a new bulb in the reverse order of removal.
Mar 22, 2010 | 2005 Honda Civic
High beam not working 2006 SI civic
In the under-dash fuse box check fuse #18 (20amp), fuse #12 (10amp) and fuse #13 (10amp). Don't forget to check the bulbs. -hope this helps
Jan 05, 2010 | 2006 Honda Civic Hybrid
How do i install the ACCEL universal performance coil into my 1999 honda civic si?
your stock coil should be strong enough to support light mods. if you do need the accel coil, look into honda-tech.com for detailed info
Sep 05, 2009 | 1999 Honda Civic
I have a 1990 honda civic hatchback si with an 89 ZC DOHC black top engine.. the rear motor mount is cracked and each time i down shift the engine raddles.. how do i change out the mount? and if possible.....
You will need something to lift the engine so that you can take the pressure off of the mount. It sounds like your fuel pump may be wearing out and it is not responding like it should...The pump on the gas tank should be located on the top of the tank....Under the back seat....
May 07, 2009 | 1990 Honda Civic
Honda civic pedal assembly
It should be a simple fix. If you go to a local dealer, it can be as easy as them pulling a pin, lowering the pedal and replacing the pin. If the car is newer, it is all electric and there are no hydrolic parts to depress. Good luck!!!
Oct 20, 2008 | 2005 Honda Civic
Civic SI 5-speed transmission/clutch
it depends on how high your reving the engine. if your at the stock a3 rev limit (6900-7000 rpms), between 400 and 450whp. the shaft the gears are on starts to flex and gears separate, causing minimal engagement, which rounds off the edges of the gears.
with a almost stock a3 tranny (stock + quaife LSD), 415whp and 9000rpm rev-limit, it took 1 good race at the drags to damage the 1st and 2nd gear syncros. after a few more races the gears were moderately damaged too.
as far as a good clutch, if you can afford it, i would recommend the FX600 from ClutchMasters.
Aug 08, 2008 | 2005 Honda Civic
Car Audio & Video Logo
153 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
