Turned on my washer a TROMM LG wm2277hw and at every cycle turn it beeps LE
  • lescor857 Jan 22, 2009
    Only I have a WM1814CW model Front Load Washer
  • 135 Answers
LE means a faulty motor. The motor is called the "stator" in this machine. Located behind the back panel. Pretty easy to replace in this machine. Replace the stator and it will work like new!
Posted on Apr 07, 2008
  • Charles Durham Sep 23, 2013
    i check it for connutiy and it ohm out
6ya staff
SOURCE:
My lg tromm model number wm2277hw/01 has the error code le show 2 seconds into the cycle even if nothing is in the washer what is going on
Hall sensor needs replacing (motor position sensor). Pretty easy and under$20. Check out appliancepartsproscom, repairclinic.com or YouTube for how to videos.
Jan 22, 2017 | LG Washing Machines
My lg tromm washer on the wash cycle is not spinning, and is making a grinding noise
check for something in the bowel. pins ,buttons coins etc have a technician check the spin operation.
Mar 03, 2015 | LG 4925ER1015B 4924ER1010 Used Frontload...
LG Tromm WM2277HW will not spin both directions, LE error.
clean filter check that its drained all the water out any blockage and the machine will not spin
Nov 28, 2011 | Washing Machines
"LG Tromm WM2277HW will not
Hello & Welcome to FixYa
LE error in your LG front load washer is displayed when either the motor is not working or the control board thinks that the motor is locked up. A Hall effect sensor is used in these washer which monitors the speed and direction of the motor and then forwards this information to the control board. Hope you understand by now that this LE error is displayed when their is an issue with the motor or when the hall effect sensor sends wrong signal to the control. Conclusion is you'll have to check both motor and hall sesor and replace the part# that is bad, usually I have seen the sensor going bad. Please get back to me if you have any other questions.
Kevin
Mar 27, 2011 | LG WM-2277HW Front Load Washer
Not completing cycle error IE
IE is a water supply error. turn water off to machine and unscrew your 2 water hoses on back of machine and clean inlet screens with old toothbrush. if they are clean, you probably have a stuck closed water solenoid.
Jul 25, 2010 | LG WM2277H Front Load Washer
LG Washer Model #wm2277hw
It is a motor error
• The connector in the LEAD WIRE ASSEMBLY is not connected to the connnector of STATOR ASSEMBLY Reconnect or repair the connector • The hall sensor is out of order/defective. Replace the STATOR ASSEMBLY
Apr 19, 2010 | LG WM-2277HW Front Load Washer
My Tromm washer model WM2277HW won't spin and flashes ''LE'' Help!
try to open the back of your machine wher you can have an access to the motors, see if it is running or the belt is in right place, you can turn it on while looking at it , just don't get closser, a few feet away woul be enough for you to see it
Nov 06, 2009 | LG Washing Machines
LG TROMM displays LE
LE stands for Load Error,
First try unplugging the machine for a few minutes and then retry a cycle. If you still get the LE error:
The Hall sensor (part number 6501KW2001A) has failed. The hall sensor is rather easy to replace, and is covered by a seven year part warranty (in the US). Take the back cover off. Take the big nut off and remove the motor rotor. Remove the bolts holding the motor windings. Remove the electric plug on the sensor and unclip it from the motor winding. Snap new sensor on and reassemble. Usually takes under a half hour. On a difficulty scale of 1 - 10, it might rate a 4. This should be a Fix-Ya for your machine, and at basically no cost!
In the US, find a service provider using your zip code at http://us.lgservice.com/index_b2c.jsp or call LG at 800-243-0000
Jun 21, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LE error
try using a-fresh its should help you out.
Oct 12, 2008 | LG WM2688HWM TROMM SteamWasher
Tromm Washer Model # WM2277HW by LG
will it spin after it washes if it does not then your belt might be broke
Feb 12, 2008 | LG WM-2277HW Front Load Washer
Washing Machines Logo
263 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
