Question about Kyocera FS-3900 DTN MONO LASER PRINTER
Kyocera FS - 3900DN creases the paper
Kyocera FS - 3900DN produces a crease on every sheet of paper often the whole length, I have looked extensively for a small paper jam but have found nothing
  • Sheri McMichael May 28, 2010
    Is the crease in the centre of the page or at the sides?
  • mazjanus May 28, 2010
    The crease is on the right had side of the paper
  • 241 Answers
If even a very small piece of paper is in the paper path it could cause this issue. You may need to have a technician take the printer apart to see what the cause is. If you can indicate exactly where inside it may be causing the paper to crease it would indicate whether one of the rollers is causing the issue or not, you may have a roller that is needing to be replaced. If you haven't had your printer looked at by a technician in a while it may be time to get a maintenance cleaning done which would resolve your issue and also indicate if there is any major problems going on with your printer.
Posted on May 28, 2010
Crease in paper when printing
Your information is a bit limited but we'll try anyway.
If the crease is a corner fold or a pressure line down the page, it will often be caused by something in the paper feed path close to the main drive bar in an inkjet or near the fuser in a laser printer. Have a look at the leading edge of the paper as it exits the printer for a nick or mark that may give a clue where to start looking. If there is a fold or crumple line down the length of the page, look at the paper pick up mechanism in an inkjet (usually the paper tray is a good start) or if it is a laser printer you should remove the fuser and check the fuser sleeve and pressure rollers. If you could let me know what the machine is and where the crease is I may be able to give better advice.
Jul 09, 2015 | Office Equipment & Supplies
Paper keeps creasing during printing. have moved guides out as far as they go
Creasing is usually caused by pare skewing so guides must be as tight as possible against the paper if it's still a problem you will need a new fuser a unit more than likely
Mar 12, 2015 | Kyocera FS-3140MFP Plus Black & White...
Why does paper keep creasing up
can I get a little more info what do you mean creases is it jamming or just coming out crinkled if it makes it through the machine check the guides and the paper type the tray is programmed for if it stops around the fuser and folds like an accordion replace the fuser
Aug 05, 2014 | Kyocera Office Equipment & Supplies
I have Kyocera FS-3900DN , it shows on the display error code (call service 6030:1022274) thanks
This problem is caused by a poor contact in the fuser connector terminals.
Check both sides of the connection (in the printer and fuser unit) In most cases we will find small pieces of paper inside printer connector causing poor contact between printer and fuser unit connector.
Hope i was of any help. If i was, please rate me.
Thank you.
PcSimples
Mar 14, 2011 | Kyocera FS-3900DN Laser Printer
The printer is creasing the paper, usually a couple of inches in from the right margin. This happens for the first few pages after the printer has been idle for a while.
This problem usually occurs due to moisture absorption by paper sheets. If the printer has been idle for some time, then prior to printing either remove a couple of top sheets (which absorb more moisture) from the sheet holder, or dry the entire lot of sheets by placing under hot air drier or incandescent bulb or room heater.
Dec 10, 2009 | Kyocera FS-4000DN Laser Printer
What does mean Kyocera FS-3900DN Call Service 7410:0020192 ?
take out your paper tray... drum and developer and then pull out the paper
Mar 26, 2009 | Kyocera FS-2000D Laser Printer
Kyocera Ecosys FS-3900DN in HP emulation mode
Right click on the printer icon and choose properties. Your emulations are listed there.
Jan 14, 2009 | Kyocera FS-3900DN Laser Printer
Kyocera fs-3900DN
Very weird message! Pull down the by-pass tray in the front of the printer and insert a sheet of paper , then print.
Printer Kyocera FS3820N
remove cassette and look for a black plastic lever hanging down, check if broken or jammed.
May 15, 2008 | Kyocera FS-3900DN Laser Printer
Kyocera FS-3900 DTN MONO LASER PRINTER Logo
467 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
CheckitRight
CheckitRight
Henry Gertcher
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
