Zanussi turbodry 1000 W1042W doesn't spin or empty the spin water. Help. I've taken the back off and one of the sides. It's on its side now lying on the floor. I replaced the big belt a year ago and that's fine still. The filter is not clogged, though suspiciously for about 3 months very little fluff etc has been collecting in there, almost nothing, is this suspicious? Machine is used every 3 days or so. Can anyone help? P.S. You're dealing with the adventurous but mainly ignorant here, so please don't assume too much of me as you explain, but I'm more than game for it. Many thanks for your time. Appreciate it!
  • 269 Answers
Sounds like a blockage in the sump pipe to drain pump or something stuck in the drain pump or drain outlet blocked.Lack of fluff depends on the type of wash not that suspicious.Be careful when lying the machine on its side never lie it on the side the programmer is on as water can get into the electrics.Can you hear the pump turning when you put knob to spin/drain or just a buzzing if latter then the pump is jammed or faulty either way it will need investigating.
Hope this helps.
Posted on May 28, 2010
Testimonial: "Thankyou for getting back to me. Sorry it's been a while, have had pc problems. You were right, drain pipe problem. I hate to admit having stripped things down, tested pump motor and about to order new bushes on main motor, even though it worked, that the real problem could only have been the pipe not pushed down the tube far enough! Still I learnt a few things. Have to change the bushes one day soon as they are very short. You get full marks for a correct diagnosis. Thankyou!"
AEG Lavamat 16830 won't drain
The simplest way is to lay the washing machine on the right side so that you filter closer to the floor and from bottom of the washing machine is accessible drain pump. It can be fixed by three screws
or just turn pump counter clockwise and pull out.
Dado
Mar 29, 2017 | AEG Washing Machines
Hi i need a manual in english for zanussi 1140m am in denmark but only read and speak engish
Hi!!
Try the following link to download your manual. http://www.nodevice.com/user_manual/zanussi/washing_machine5/w1042w.html
Scroll down, enter the code on the box and click DOWNLOAD
Good Luck!! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa!!
Feb 16, 2011 | Zanussi W1042W Front Load Washer
Zanussi jetstream 1000 turbodry door remained locked this morning. Emptied machine through filter port and cleaned filter. Door opened ok. Machine will now not start any program although the power light...
the drain pump is jammed .........remove the filter at the bottom left of the machine get down and look in the hole and you will likeley find something in there if not you need a new pump
Feb 26, 2010 | Zanussi FJS1225W Front Load Washer
Stoping under process on every step from begning to ending
its very common for front load washers to have the water pump to freeze up.
ever washed something with sand or little rocks or rubber bands?
flip the washer to the side, then locate the water pump. take the filter and the hoses around the water pump. sometimes the water pump too, to make sure that the fins on the water pump are free and not stuck. put everything together and try the cycle. when the water pump is stuck it will cause the error and will not go into the spin cycle.
Aug 14, 2009 | Zanussi ZJD1219 Front Load Washer / Dryer
Hotpoint wma37 washes clothes ok but wont drain or spin
the hotpoint has a saftey factor built into it if the water does not drain it will not spin , the fault is the pump is blocked or broke or the sump hose is block this leads into the pump
to fix take the drain hose the grey one and put it in to a bucket and it will empty the water
if not the sump hose is blocked
if it emptys lie the machine on its side if poss with power off , if it will not lie on its side disconect the water hoses
look under the machine u should see the pump and the sump hose u can remoe this hose put lots of old towels down to catch the water check in side the sump hose for blockages
the pump this on the new models has hex bit screws on it to open check to see if it move freely it should spring back slightly
try this any problems let me know the model number
Jun 28, 2009 | Washing Machines
What is E 40 on Zanussi Turbodry 1200?
E40 indicates the doors not closed properly. Sometimes it can be the lock itself or the main control board
Nov 24, 2008 | Zanussi FJS1225W Front Load Washer
Zanussi Turbodry 1200 spin problem
if this washer is used alot then it will more then likely be the carbon brushes which u will need to take the lid off undue 4screws out where it joins front to the back screws at the back to the bottom and 1screw either side of the bottom where the panels join together behind a little cap which will have an hole in the middle of it to get it out u will then be able to get to the motor to replace the carbon brushes
Nov 22, 2008 | Zanussi ZJD1219 Front Load Washer / Dryer
Zanussi turbodry 1050
this may sound silly but check the waste outlet pump electrically, some models are wired up so if the pump fails the water will not enter the machine, this works on the theory that if it fills up it can not empty also check the solenoids for open circuit electrically, double check the water supply to the machine, it may have been fine but you could have kinked the pipe placing the machine back where it should go?
Oct 04, 2007 | Washing Machines
Zanussi jetsystem Turbodry 1200
It appears that you may have a faulty door interlock or a faulty PCB. pcb is not really a DIY job as some boards require proramming on certain versions. Regards Advisor
Oct 30, 2006 | Zanussi FJS1225W Front Load Washer
Washing Machines Logo
613 people viewed this question
Top Washing Machines Experts
