Question about KitchenAid KHMS155LSS 1000 Watts Microwave Oven
Timer of My Haier HR21BIC is getting reset when going to start. 1. After setting time and then pushing start buttong it is getting to 0:00. 2. Also a red signal is blinking on panel. 3. Just after switch-on for microwave its plate is started rotating without pushing start button or setting time.
5 Suggested Answers
jsrock516
  • 5911 Answers
SOURCE: door indicator prevents microwave from starting
This is usually an indication of a bad door interlock. Take resistance readings with the power turned off on the primary and secondary interlocks. You will need to remove the control panel to access them. There should be a wiring diagram somewhere inside the control panel to assist you in determining if the interlock is normally OPEN, or normally CLOSED. As you open and close the door the interlock should change states. Additionally, double all your connectors to make sure they are plugged in correctly. I had a similar problem once and it turned out to be a loose connection on one of the interlocks. I hope this helps you.
Posted on Aug 04, 2007
MicrowaveSvc
  • 9047 Answers
SOURCE: MICROWAVE CONTROL
The first thing to try is a "hard reset". Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again.
Let us know if the hard reset doesn't fix it.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Mar 31, 2008
kel1guy2002
  • 3740 Answers
SOURCE: always on
Most probable failure is this VERY expensive part:
http://www.appliancepartspros.com/part_details.aspx?part_id=4327040&image=1
This is what controls the Magnetron operation via the relay on the PCB. If the Magnetron is operational without programming it usually is the cause of the problem.
I would recommend that all wiring to the control board be verified before considering replacement of the board. The price of the board to me is off the charts in cost! Not sure what the original purchase cost was but the price of this board would make one consider unit replacement vs component replacement when you add in the cost of the service call.
I am sure this is not what you wanted to hear.
Thanks for using FixYa,
Kelly
Posted on Apr 12, 2010
  • 8909 Answers
SOURCE: When I set the timer
I think you have a dodgy door switch. I would get them checked.
Hope that helps.
Posted on Mar 17, 2011
How do I set the clock on my sanyo microwave
Usually, if there is a Time/Clock button on the panel, pushing it once blanks the display for timer input while pushing it twice makes the colon blink (the two dots) meaning it's expecting the time input. So, for 12:37 you would push Time-Time-1-2-3-7-Time.
Apr 26, 2015 | Sanyo Microwave Ovens
How do you stop, reset or change the remaining time on the Timer on the GE JES1142 microwave? Pressing Clear/Off does nothing. Do you just have to wait for the timer to run out? Manuel is wrong even on how...
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes.
Oct 27, 2013 | GE JES1142SPSS 1.1 cu. ft. Countertop...
I have a GE sensor microwave oven. Tried to heat food and sensor eror came on. Everything is running even the timer but no sound but the timer is running. Cant this be reset pls help
HELLO.
This is the solution to reset your microwave.
1 Pressing the clock button will display the time. You can also use this to know what time it is while cooking.
1. Set the clock by pressing the "Clock" button.
2. Turning the dial on the GE sensor microwave oven will display the hour of the day. Once you have found the correct hour, press the dial in.
3. Again, turn the dial to set the minutes of the day. When this is completed, you will need to press the dial in again on the GE sensor microwave oven.
4. When the time and minutes are set, turn the dial again for a.m. or p.m. Then you will need to press the dial in to save the settings.
5. Press the "Start" button to allow the clock to begin on the GE sensor microwave oven.
Thanks.
Sep 18, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
I have maytag advance cooking system(electric) and the oven will not work.The timer to set the oven and the time is not lighting up but the stove is working.any sugestion
try resetting the clock. If it is digital, push the clock button and then the number buttons untill you have the proper time displayed...then push the clock button again. If your clock and timer are manual, try pushing in the clock lever and turning it 1/4 turn. If this works it would indicate that your timer has a start and finish time and that the oven is not working because the clock has rotated around to the finish time.
Sep 09, 2011 | Microwave Ovens
My new Haier microwave isn't working! I just plugged it in for the first time, and set the clock on it. Then I tried to turn it on. No matter what cook time I enter, and then press start/30 sec., nothing...
When it times down but doesnt heat it is typically a problem with the door switches, especially one you just bought, may have been from shipping . A switch or connection may have been disodged when being shipped to you. Most machines have something like 4-5 wswitches, If 1 doesnt report right it will stiop the unit from running. But since some of them are closed it will accept the programing and try to operate. So a lot of times you get fan running and tray turning but no power to the secondary circuits. You will need to find out who does warranty for them or return it where you bought it as a defective unit.
Aug 14, 2017 | Haier Microwave Microwave Oven
When I set the timer and close the door, the door latches fine. When I push the start button the timer starts to countdown but the microwave doesn't start. If I push the door release in about 1/8 " ,...
If your model number is in the Sharp R-1500 series, then that's a problem with the bottom door switch or its mount.
See these files:
http://207.234.249.73/mwd/safety.txt
http://207.234.249.73/mwd/disassembly.txt
http://207.234.249.73/mwd/doorsw.txt
Jan 14, 2011 | Sharp R-1511 Microwave Oven
I am trying to set the kitchen timer on my older spacemaker microwave for 2 hours and am unable to do so ... Am I trying to do something impossible?
The first step is to set the clock. To do this, push clock, set the time using the key pad and then PUSH clock a second time.
Once that is done you can set the timer by pushing timer, putting in the number of minutes you want and pushing start.
Jun 07, 2009 | GE Spacemaker Over-the-Range Microwave
When i push start on the oven nothing happens but the timer is wo
bad relay on control board . not worth it cost to high ( ge board 145.00 to 230.00 ) and with the oven @12 years old i dont think you would find it at price SORRY . please rate this answer , i need the rate to get my "wings' thanks
Jan 16, 2009 | GE Advantium SCA1001SS Convection /...
Microwave oven (nn-sd997s) stuck in DEMO mode
Pressing "timer/clock" button 4 times turns on and off demo mode.
Apr 26, 2008 | Microwave Ovens
Keypad Problem?
look on the back panel for any hole with a "RESET" label next to it. insert a small pin to reset your microwave
May 25, 2007 | Emerson MW8168B Microwave Oven
KitchenAid KHMS155LSS 1000 Watts Microwave Oven Logo
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Stu Ungar
Darial Jr Lasaria
Darial Jr Lasaria
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
