Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Green light flashing repeatedly / no picture or sound
Could this be the motherboard? Or something more simple like a sleep timer that wont go off without a certain code?
  • 175 Answers
Possibly dry joints in the pcb or bulb
Posted on May 28, 2010
Emerson lc407em1 sleep timer without remote
Without its remote control, you can't set the sleep timer. If you wish to buy its original remote control, contact the authorized service center, or authorized dealer to your device brand.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its user manual. Never accept a remote control, that hasn't both of this. If you see the site by "MOSAIC" view, will make surf easier.
http://electrohelponline.blogspot.com/
Mar 16, 2014 | Emerson Used Original LC407EM1 Remote...
Why does my tv turn off automaticly
Some tvs have a sleep timer on it and if it is accidently programmed the tv will turn off at a certain time. You may want to look at the users manual for more info. Or call a local place that fixs tv's for some more input before paying someone or getting a new tv. I had a tv once and it did the same think. I had to get into the menu with the remote and figure it out it had something to do with a set sleep timer so the tv would shut off at a certain time if the timer was set. It sucks if you dont have a remote though hopefully you do. Good luck. M Some tvs have a sleep timer on it and if it is accidently programmed the tv will turn off at a certain time. You may want to look at the users manual for more info. Or call a local place that fixs tv's for some more input before paying someone or getting a new tv. I had a tv once and it did the same think. I had to get into the menu with the remote and figure it out it had something to do with a set sleep timer so the tv would shut off at a certain time if the timer was set. It sucks if you dont have a remote though hopefully you do. Good luck. M Some tvs have a sleep timer on it and if it is accidently programmed the tv will turn off at a certain time. You may want to look at the users manual for more info. Or call a local place that fixs tv's for some more input before paying someone or getting a new tv. I had a tv once and it did the same think. I had to get into the menu with the remote and figure it out it had something to do with a set sleep timer so the tv would shut off at a certain time if the timer was set. It sucks if you dont have a remote though hopefully you do. Good luck. Malena!!
May 10, 2012 | Vizio Televison & Video
Sleep-timer grundig p37-060
i need the code of sleep timer on gruding tv please
May 04, 2012 | Televison & Video
How do I set the sleep timer? We got the tv from a friend and it had no manuel.
Programming the Sleep Timer:
  1. Press and release the TV key.
  2. Press and hold the SLEEP key for three seconds. The illuminated component name turns on.
  3. Release the SLEEP key.
  4. Using the number keys, enter the desired time in minutes (from 1-99 minutes). To set the timer to an umber under 10 minutes, first press 0 and then the desired number (e.g.,05 for five minutes). The illuminated component name blinks with each key press.
  5. Once the second number is entered,the illuminated component name turns off.
    Tip Any key press other than the number keys is ignored. If you don't enter the sleep time within 10 seconds after pressing the SLEEP key, you must start over at step 1. The illuminated component name blinks four times and then turns off, indicating your attempt to program the Sleep Timer has been unsuccessful.
  6. The Sleep Timer is now set.
  7. Leave remote aimed at the TV. Once the Sleep Timer is set, you can continue to use the remote without affecting the Sleep Timer. However, because the timing mechanism for the Sleep Timer is built into the remote itself, the remote must be in TV Mode and pointed at the TV to activate the Sleep Timer.
    Note: If the ON·OFF key is pressed, the Sleep Timer is canceled.
Aug 19, 2011 | RCA Rcr461 Remote Control
I have a Sharp 32"
try checking the system for timer or sleep mode operation try to setting it off
Jul 16, 2011 | Sharp 25R-S100 25" TV
Thinking of getting the TI150 3-in-1 Timer - Can it set to repeat a countdown over and over?
Review at Amazon seems to say the timer can repeat the same countdown each time button is pushed and countdown is activated.
Amazon review says:
http://www.amazon.com/General-Tools-TI150-Visually-Impaired/product-reviews/B001TOJG7Y/ref=dp_db_cm_cr_acr_txt?ie=UTF8&showViewpoints=1
The timer is easy to set. You just set the time, then hit the big "start/stop" button and the little "H" and "M" on either side of the timer display flashes.
To clear the timer, just hit both the "h" and the "m" buttons simultaneously. (so time has to be cleared)
To stop the alarm or to turn off the timer before the alarm sounds just hit the "start/stop" button.
On the back of the timer, there are 4 different on/off switches: flashing light alarm, sound alarm, vibrating alarm, and one for hours/minutes or minutes/seconds.
When I set the timer on my desk, it moved around when the alarm went off but when I turned off the vibrating function, the timer didn't move around.
If you need to turn off both the sound and vibrating alarms and use only the flashing light alarm, the light is quite noticeable by itself if placed nearby in your line of sight (within a foot or so). This would be very handy if you're near a sleeping baby! :) But if you clip it on a breast pocket, I would use both the flashing light and vibrating alarms. The vibrating alarm does make a sound, but it's not as loud as the ringing alarm.
Dec 27, 2010 | General Tools Hardware & Accessories
Over tv its getting aoutmatically off
Hello
Put your hand on the back of your TV to check for overheating, if your set keeps switching itself off without warning.
Many TV sets come equipped with a safety feature that switches the power off if the set gets too warm.
Check the cooling vents located at the rear of your unit. Vents can collect dust and dirt, resulting in the fans becoming blocked and failing to work properly.
Remove dirt from the vents with a damp, clean cloth. Ensure the air conditioning is kept at adequate levels in the room where your TV is located. Keep the drapes shut on hot, sunny days to keep the room cooler.
Check the sleep-timer function on your TV if it keeps turning off. A sleep-timer is used to turn a television set off after a certain period of time has elapsed. If the sleep-timer is not turned off, your television will continue to turn itself off after a certain period of time.
If the problem persists,then a heat sink has gone bad.
The on/off button simply toggles a low voltage circuit that powers your tv. If it is dusty, it may complete the electrical circuit and send a false signal.
Take a can of compressed air, open the back and clean the dust off the circuit boards.
NOTE;opening the TV VOIDS warranty!!
Dec 22, 2010 | Televison & Video
Can't set sleep timer on my mitsubishi cs-40505 tv. I do not have the original remote. How can I set the sleep timer?
U can't do it without the original remote.Go in the tv menu by the manual button control might could set the sleep timer.This is a extra option on most tvs.
Jun 07, 2010 | Mitsubishi CS-40505 TV
I have a 56' that wont show picture
Power board is bad.. I had the same issue.
Apr 13, 2010 | Samsung HL-S5679W 56" HDTV
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
179 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
