Question about Car Audio & Video
Colour codes for 83 corona, wiring stereo
Just bought an 83 corona,trying to put headunit in and i dont no the wiring colour codes for the car any help would be great thanks
  • 1,868 Answers
Hello!
POWER
Constant +12=Blue/Yellow...Switched +12=Gray
Ground=Brown...Illumination=Green
SPEAKERS
FR+ Light Green
FR- Blue
FL+ Pink
FL- Purple
RR+ Red
RR- White
RL+ Black
RL- Yellow
Guru............Saailer
Posted on May 28, 2010
1990 toyota corolla stereo wiring codes i just purchased a sony stereo and i took out the old radio in my 1990 toyota corolla but i cant figure out how to connect the wires i need the color code for...
what you need is to buy a wiring adapter for your car.it only cost about 15 bucks and plugs right in to your original plugs that were connected to your factory radio.the great thing about this adapter is that you dont hava to cut your original plug off just in case if you ever want to reinstall your original back.also the wires that go to your new headunit are color coded to match the exact colors that you connect to your stereo.you can't mess your connection up because all you have to do is connect each wire to the right color,tape them up,connect your stereo and you have music with all of your speakers working like they should and without any headaches.i hope this info helps.take care and good luck, manny
Jul 12, 2010 | 1990 Toyota Corolla
Stereo Wiring Colours
2006 Ford Focus Car Stereo Wire Color Codes
Car Radio Battery Constant 12v+ Wire: Yellow/Green
Car Radio Accessory Switched 12v+ Wire: Orange/Black
Car Radio Ground Wire: Black/Green
Car Radio Illumination Wire: Orange/Black
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): White/Black
Left Front Speaker Negative Wire (-): Gray/Black
Right Front Speaker Positive Wire (+): White/Red
Right Front Speaker Negative Wire (-): Gray/Red
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): White/Green
Left Rear Speaker Negative Wire (-): Gray/White
Right Rear Speaker Positive Wire (+): White
Right Rear Speaker Negative Wire (-): Gray
Jul 11, 2010 | 2006 Ford Focus
I am trying to exchange the stereo in a 2005 saturn view and wiring colors dont match the new stereo...How do I know what is what?
You should buy the the wiring harness for your vehicle and then you wont have a problem because it will have the proper color connections for your new headunit. You can purchase the wiring harness at any car stereo or electronics store that sells car stereos.
Jun 01, 2010 | Car Audio & Video
Colour codes for 83 corona, wiring stereo the colours are grey/black grey/red Brown Purple/green Grey Blue/yellow blue white/black any help would be great thanks!
Hello! I'm having a hard time reading your colors...So, I'll give you the 1983 Corona wiring...
POWER
Constant +12= Blue/Yellow Switched +12= Gray
Ground= Brown Antenna= Black/Red
Illumination= Green
SPEAKERS
FR+ Light Green
FR- Blue
FL+ Pink
FL- Purple
RR+ Red
RR- White
RL+ Black
RL- Yellow
Guru...........Saailer
May 30, 2010 | Pioneer AVH-P5700DVD Car DVD Player
What colour wires do i need to use to wire up rear speakers on a pioneer 2000mp headunit
should be listed on the unit itself, however if youre attempting an install there are vehicl specific plug-n-play kits available that cure these headaches with out breaking the bank, and they can be found starting around 10.00 and you dont need to hack up your factory harness to install after market equiptment
Jan 17, 2010 | Pioneer DEH-2000MP MP3 CD AM/FM Car Stereo...
Wiring colours
Not sure of your setup re hedunit.
the plug from the old sterio should have the following:
Black- Earth
Red - ignition (only supplies 12v when key is in the ACC position.
Yellow green (12v all the time) even if key is in the off position)
you can check the speakers by using a 9v battery and QUICKLEY toutching the wires on the terminals to distinguish what two wires run to what speaker.
Then use the same sequance for wiring the headunit making sure thar all the solid colour wires are used as the positave connection for the individual speaker wires.
Dec 05, 2009 | Car Audio & Video
I have a 1995 f250 it had a tape factory player and trying to put a single factory cd player that came from a 1996 ford areastar van but the wiring is diffeent is this possible?
yes. more that likely if you look at the stereo it will give you a colour code as to what colour wires do what. if they dont then a simple google search for a stereo wiring diagram for each vehicle will be even better. if its just your speakers that are messed up then a neat trick to remember is if you take a AA battery and put the + side of the battery to the + side of a speaker wire and the - to the - then that speaker will come out. If the poles are backwards then the speaker will go in. good luck
Nov 23, 2009 | Buck Ford F250 F350 2002 02 Radio/stereo...
Installin used headunit in 97blazer dnt know wat wires go where?
you need wiring harness for your truck to the radio go to your local bestbuy or car audio shop then follow color coded instructions for the wiring
Aug 13, 2009 | Pioneer DEH-2000MP MP3 CD AM/FM Car Stereo...
I need the pin out for the wiring harness for the vrcd 500 sdu stereo i have the unit but no harness i can make my own if some one can tell me what wire gos were it has 2 rows of 8 pins top and bottom i...
it would be easier to remove the harness from the car and wire direct red and yellow from headunit to car live, black to earth,4 coloured pairs (eg purple/purple and white, blue/blue and white) will be speaker wires single blue is your remote wire (not needed unless adding an amp) hope this helps
Aug 12, 2009 | Car Audio & Video
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
