Question about Orion HCCA-D5000 Car Audio Amplifier
Amp how to install a car amp with dual power and ground connections
    Sergeant:
  • 300 Answers
Both power and ground connections must be used for proper operation. Connect 4AWG wire from both +12V connections to a fuse block with a 250A inline fuse, which will then connect to the battery. Ground both ground connections to a good, close point on the chassis.
Posted on Apr 08, 2008
Connected a Dual XPA2100 300 watt amp to the battery and connected ground to chassis of vehicle. Vehicle is 2004 Saturn Ion with battery located in trunk area. Amp does not power on, all connections are...
The remote wire DOES need to be connected to the head unit. You can see if thats the problem simply by touching the remote wire to the power wire. The unit should come on. The head unit should either have a remote lead, or a power antenna lead, and thats what you need to turn the amp on and off. BE SURE your ground is solid, and its usually best to take that to the battery as well to prevent unwanted engine noise. Hope this helps!
Sep 25, 2011 | Dual XPA2100 2/1 Channel 300 Watt...
Bought a hitron 3200b secondhand. installed the amp and no sound I have a 06 gmc I am using an aftermarket radio it is a lo line model made by I think dual 50 bucks at walmart all connections are good...
Bypass the amp with a small speaker or tweeter to make sure your rca input is working. Is the amp light on. Got good power, ground, and remote? Have you tried a different set of speakers on your amp?
Sep 04, 2011 | Hitron HA20002 Car Amp
Amp want power off
Hello
If your Dual Car Amp refuese to switch ON check the following.
+12V wire is not connected or incorrect voltage.
REM wire is not connected or incorrect voltage.
Ground wire is not connected.
Fuse(s) are blown.
If the fuse blows repeatedly, check whether the +ve voltage wire touche the chasis of the vehicle. If it is OK, the fault is with the univt itself. That is, the output of the unit has a short. Check for any output IC failure. OK.
May 11, 2011 | Dual XPA2100 2/1 Channel 300 Watt...
I have my amp hooked up right to two 12 inch subs but the red protect light comes on wht does this mean?
Check all your cable work.
Power is connected tight? Ground is attached tight - on both ends (my guess is it is the ground) Remote cable?
Is the ground a proper ground?
Mar 01, 2011 | Dual XPA2100 2/1 Channel 300 Watt...
I install wire from the battery to the amp ground the amp then i installed the audio jack from the reciver to amp an then the speaker wire an nothin
Power amps must be connected + battery wire to the amp +b terminal with a gauge 8 or bigger depending on the power rating, - ground to the car chassis as short as possible,connect cords from head unit to power amp with good groundings, and remember to connect the speakers and the remote trigger from head unit to turn the amp on.
Aug 27, 2009 | Performance Teknique ICBM-772 Car Audio...
Installation Guide for Car Subwoofers
MOST OF THE TIME AMPLIFIED BOXES ARE EASYER THAN REG AMPS, ALL U HAVE TO DO IS RUN UR RCAS FROM THE BACK OF UR HEAD UNIT TO THE AMP, THAN UR POWER LEAD, FROM UR BATTERY TO THE AMP, THEN UR GROUND MOSTLY ON THE FRAM OF THE CAR OR ON THE BRACKETS ON UR SEATS, THATS MAINLY ALL U NEED TO NO.
Jun 18, 2009 | Pyramid - PS46KX 35 Amp Power Supply Car...
Dual SBX554
POWR TO BATTERY FOR WHAT?DOES THE SPEAKERS HAVE AN AMPLIFIER? NEW RADIO? SPEAKERS ALONE ARE NOT CONNECTED TO BATTERY ,UNLESS THEY ARE POWERED SPEAKERS,USALLY SUB-WOOFERS HAVE THEIR OWN AMP.iF YOU ARE CONNECTING A AMPLIFIER START WITH A FUSE SAME SIZE AS THE AMP,CONECT 1ST TO THE BATTERYTHE TO THE FUSE RUN A SIFICIANT GAUGE POWER CABLE TO THE AMP.GET THE GOUND FROM A PART OF THE CHASSIS CLOSE TO THE AMP,ALSO SAME SIZE OR LAGER GAUGE WIRE.THEN YOU HAVE TO RUN A REMOTE SWICH WIRE FROM THE BACK OF THE RADIO TO THE AMP.iF RADIO DONT HAVE REMOTE ,CUT INTO THE POWER ANTENNA WIRE .RUIN YOU RCA CABLES TO THE AMP AND WIRE YOU R SPEAKERSMbUT FIRST DISCONNECT YOUR GROUND FROM THE BATERY MOST IMPORTANT.ANY '?'S.WRITE BACK RATING PLEAse.
Oct 26, 2007 | JC Whitney - Dual Blue Led Speakers Car...
Amp
Make sure the amplifier is turning on. Remember ther is three wires that power the amp Battery constant, Ground which in a fiberglass boat run ground to battery not motor, Plus make sure the remote wire is hooked to power, generally it is switched power. But if the amp is not turning on temporarily hook remote and power together to battery and see if the amplifier turs on. Second be sure you have a good set of RCA cables hooking the radio to the amp. And finally check and make sure the gain is turned up on the amplifier.
Aug 31, 2006 | Dual 2-Channel Bridgeable MOSFET Amplifier...
Connection
schematic & instructions on deck red (+) - power - 2 amp's power inlet power (+) black (-) - ground - 2 amp's power inlet ground (-) deck yellow wire - remote - 2 the remote amp deck outputs 2 the RCA amp inputs amp RCA outputs 2 speakers it is wise that a pro will install the system it will give u less concerns and u will have warranty on the installation this will save u the money u will spend for fixing a bad installation
Feb 03, 2006 | Jensen A300HLX Car Audio Amplifier
Orion HCCA-D5000 Car Audio Amplifier Logo
107 people viewed this question
Top Orion Car Audio & Video Experts
Tygh Duval
Tygh Duval
Steve Sweetleaf
Steve Sweetleaf
Are you an Orion Car Audio and Video Expert? Answer questions, earn points and help others
