Question about AEG Dishwashers
How to clear blocked siphon for AEG dishwasher
After 6 years of once-a-day family use my AEG OKO_FAVORIT 6281i dishwasher starts up OK but a few minutes into the cycle begins flashing error code 20. At this stage there's a litre or two of cloudy water sitting at the bottom of the machine. A non-AEG repair guy took one look and said it's the logic panel. How can I tell if he's right? According to page 32 of the user instructions, error code 20 means the 'siphon is blocked' and I should be able to clean it myself - but how? (Not by sucking on it I hope! Yecch!) The diagrams do show a 'drain hose' but nothing labelled as 'siphon', so I'm assuming they're exactly the same thing. Is there a wimp-friendly way of cleaning the siphon?
3 Suggested Answers
taran_2005
  • 10515 Answers
SOURCE: After 6 years of once-a-day
20 indicates a drainage problem. Now, if the appliance has drained it would indicate a problem with the pressure switch.
If the machine was laid on it's back or side water could enter the pressure switch.Remove the side panels and locate the pressure switch and tubing. (right hand side if memory serves me correctly), disconnect the pressure tube and blow down it to clear any water, debris or blockage. If any water drips out of the pressure switch, get the hairdryer on it and thoroughly dry it out. Basically it's not detecting that it's empty. Please note, it could be the main PCB at fault but it's best to rule out everything else first.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Jul 08, 2010
  • 3247 Answers
The easiest way to empty the dishwasher would be to use a small container and empty most of the grubby water. Then take a towel or two and dry it out.
Now about the error code - does it come back when you turn the power off and on again?
Posted on Jul 02, 2010
Electricity tripping within seconds of closing the door of my AEG Oko Favorit dishwasher. Eventually gets going after about 3 attempts.
there has to be a short in the wiring check and make sure that the wires are connected correctly "White to White, Black to Black and Green to Green the green is the ground"
May 22, 2014 | AEG Dishwashers
Aeg favorit 40010vi dishwasher won't fill with water
I have a similar issue on oko favorit 50700. I have checked the flow from the inlet hose into a bucket and it really seems ok, so I think maybe a problem at the inlet to the machine? Plea update if you get a fix!
Mar 24, 2013 | AEG Dishwashers
Aeg oko favorit 40300 service manual
AEG OKO FAVORIT 40300 When switching dishwasher on no water is flowing into the the dishwasher
Please help
Jan 11, 2012 | AEG Dishwashers
After 6 years of once-a-day family use my AEG OKO_FAVORIT 6281i dishwasher starts up OK but a few minutes into the cycle begins flashing error code 20. At this stage there's a litre or two of cloudy water...
Jul 02, 2010 | AEG Dishwashers
We dont know how 2 turn it on just moved house n no instructions aeg oko favorit dishwasher
Looks like what you need is available at
http://www.serviceforce.co.uk/pdfs/U20206.pdf
Good luck with the new house. Hope the dishwasher works well for you.
Try to run it with dishwasher cleaning kit (no utensils) to make sure everything is clean - that way you will get more life out of it. The cleaning kit (usually Finish) is sold in the supermarket in the detergent section.
Jan 31, 2010 | AEG 18 in. Favorit 54750Vi Slim-Line...
AEG OKO FAVORIT 6050 trips earth leakge
This is typical of a water leak onto electrical connection OR the electrical element has shorted internaly . Check this with a Ohm meter and itshould show the problem
Dec 20, 2009 | AEG 24 in. Favorit 60830 Free-standing...
Aeg dischwaher model oko favorite
This seems like the anti flood system (polystireen float / micro switch) at the base of the washer is triggered,\. This puts the washer in pump out mode and stops inlet of water via the inlet solinoid. Dry the water on the base and then check for any water leaks. (pipe leak
Nov 15, 2008 | AEG 18 in. Favorit 64800 Free-standing...
Drain pump keeps running AEG oko favorit
Aug 29, 2008 | AEG Favorit 50500 Built-in Dishwasher
Dishwashers Logo
702 people viewed this question
Top AEG Dishwashers Experts
paulcarew
Kolbrun...
Mike
Are you an AEG Dishwasher Expert? Answer questions, earn points and help others
