Question about Olympus AS-2300 PC Transcription Kit
"E" vs. "T"
Are you saying there's a way to install the "T" using the "E" version?
  • tonycollins Jan 30, 2009
    I am having the same problem, how are the digits different? I am told it is only a matter of transposing a couple of 0s with 1s
  • 3 Answers
No, you need the serial number with the T on the label.
This disk which comes with the DS-2300 and the disk which came with the AS-2300 is the same.
With my serial numbers the digits were not much different.
Posted on Apr 09, 2008
SOURCE:
I can't play the plants vs zombies . it always asks me to purchase it. how can i play or install the full version of it?
It seems the trial version you downloaded has expired.
Buy the game to install the full version or play it online for free at: http://www.popcap.com/games/free/pvz
Mar 14, 2011 | Video Game Consoles & Games
Tip
Windows Installation Disc VS Windows Upgrade Disc -NOT THE SAME-
Having Trouble Booting To Your Windows Upgrade Disc?
...Upgrade discs aren't bootable discs. To repair a windows installation, you must use either a system repair disc or, better yet, a windows installation disc (genuine Retail/OEM discs are pretty much your only option to completely reinstall your windows operating system, unless you own a previous full installation disc of a previously released Windows version (such as XP or Vista), in which case you could install that windows operating system and then upgrade to a newer windows OS like windows 7. however if you ever need to reinstall windows 7, you would either need to reinstall the older windows OS, then upgrade to the newer one.
If that isn't clear, I'll sum it up....
Let's say you bought a computer, that computer had windows xp home edition. Maybe you wanted to upgrade from Windows XP/Windows Vista or Windows 7?
Well in order to switch from Windows XP/Vista to Windows 7, (or even from Windows 7 home premium- to windows7 Pro or Ultimate), then you must either:
A) Buy an upgrade disc and upgrade to the newer desired version.
B) Or, Buy a Retail Copy of the version you want to install. (keep in mind that a retail Windows 7 disc can be used to perform an upgrade rather than to competely wipe the hard disc and perform a clean install (delete partitions, reformat, and perform a new windows installation), if you so choose.
The bottom line is, you cannot Install a fresh clean copy of windows using an upgrade disc. OEM (Original Equipment Manufacturer) and Retail Windows Operation System Installation Setup Discs are "Bootable Discs". Windows Upgrade Discs are NOT bootable. (unless one where to "modify that particular disc, which is not legal).
on Jul 06, 2010 | Computers & Internet
Sir, I have visual studio 2008 professional installed in my system(compaq) with windows 7 os.now i want to install vs 2010 ultimate in my system.what should i do? Please suggest.
VS 2010 sould install aver the older version of VS08, all you will need to do is insert the cd that you got with the product, and wait for the auto run to kick in, after that you can hit install (it may ask if you want to remove the old version or just install the new one) what you click there is up to you. Id suggest upgrade so that your tools are still the way you like them :)
but that really should be all you need to do after a few next and yes clicks you should be done
hope this helps
Feb 15, 2011 | Computers & Internet
I NEED TO KNOW WERE TO BUY A DMU 6-3 6v3ah BATTERY
I have the 500,000 candlepower version which uses the same battery.
Interstate batteries says they have one but need at least a 30-day lead
time (!). www.BatteriesSpec.com called me back last night and said
their TR2-6 was close: approximately the same size but rated at 2 AH
(vs. 3). I commented it would just not run as long.
Ordered this morning; the gentleman I talked to at BatteriesSpec was
Ron Evans and he requested I get back with him after installing the
battery for feedback. HTH,
Jan 24, 2011 | Vector 2M Pwr Rch Spotlight
There is no opening file for raw vs smackdown 2011
how can i install the game on pc smakdown vs raw 2011
Jan 15, 2011 | THQ WWE Smackdown vs Raw 2011 for PSP
I am hooking up an HD box with hdmi on an Emerson LC320EM1F, the sound lags or has a buffer. What is my issue? I just purchased 2 of these TV's and they do the exact same thing. My other TV's that were...
It could be the version of hdmi cable you are using. It could also be what version hdmi the television is vs. what version hdmi cable you are using vs. what version hdmi the hd box is. See if you still get this problem when you use component.
Dec 02, 2010 | Televison & Video
Print Shop 21 will not work on Windows 7 operating system is there a fix?
When a ‘clean’ install is done of Print Shop 22, exactly as described in this FAQ
'Clean' Install on Win98/Me/XP/2000/Vista/Win7
Print Shop 22 should install on a 64-bit version of Windows 7, with two incidents.
1. If .NET Framework 1.1 is not already installed on the computer, the "Program Compatibility Assistant” in Windows 7 will display this message
this program has know compatibility issues
To continue with the installation, select "Run Program". After .NET Framework 1.1 is installed, the necessary updates will be pulled from the Microsoft Windows Update Service.
2. After .NET Framework 1.1 is installed, the "Program Compatibility Assistant” in Windows 7 will display a message which says that there are compatibility issues with Print Shop 22 on Windows 7 64-bit. To continue with the installation of .NET Framework 1.1, select "Run Program".
NOTE: Even though the Print Shop 22 Vista patch, which can be found here
Download Vista Patch For The Print Shop 22 and PrintMaster 17 Disk Versions
can be installed on a 64-bit version of Windows 7, the patch will not fix the problem with the Amyuni Document Converter, as it does on a 32-bit version of Windows 7 (see above). So, it will not be possible to use the 'Save As PDF' option with Print Shop 22 on a 64-bit version of Windows 7. Instead, it will be necessary to install an alternate PDF driver, then Print to PDF, as is described in this FAQ
Save as PDF vs File | Print to PDF
So far, the only other known incompatibility with Print Shop 22 on a 64-bit version of Windows 7 is that Print Shop 22 cannot be run from a shortcut on the Dell Dock that is provided with many Dell computers. A Print Shop 22 shortcut can be placed on the Dell Dock; but, attempts to start Print Shop 22 from that Dell Dock shortcut will cause several incompatibility messages to be displayed
Aug 04, 2010 | Broderbund The Print Shop 21 Deluxe Full...
How to solve the upgrade patch problem for vs2005
Please send me complete details including your operating system and visual studio service pack version. If you are getting this error for windows vista then you can try later version of VS which works fine with vista and also i want to tell you you can use microsoft visual web developer express or microsoft visual c# developer express edition for the same purpose and also they consume less resources than VS.
Thanks
Jun 24, 2009 | Microsoft Visual Studio 2005 Professional...
How to install wwe smackdown vs raw 2009 ps2 game on pc
For PS2 emulation: You can play by using PCSX2 0.9.5 latest version, but your pc must be strong enough to hold it. You can download it at www.pcsx2.net.
You need the game to use the emulator. Also understand you need a powerful computer to run these games on your computer.
Apr 26, 2009 | THQ Video Game Consoles & Games
Help
I had the same issue.  I finally upgraded to the current version of Outlook.  That seemed to solve the issue for me.  Syncing a palm is not easy.  I will never buy a Palm again.
Oct 21, 2008 | Palm Tungsten E2 Handheld
Olympus AS-2300 PC Transcription Kit Logo
432 people viewed this question
Top Olympus Audio Players & Recorders Experts
Ekse
leoz
Level 1 Expert
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
