Question about IBM ThinkPad T40 2373 Notebook
RM CY25 I have rebuilt the laptop as there was a power socket problem which I fixed. but now I can't get the wirless modem to turn on with the switch. I think it might be the fact that there is a wire with a white plug on the end which is situated next to or under the modem, but I can't find anywhere for it to plug into! The other end of the wire is fitted into a connector to the right of the motherboard around the area of the letter p on the keyboard. If anyone could let me know where the wire plugs into at the modem end of the motherboad I would be greatful. Thank you Wayne.
    Problem Solver:
  • 28 Answers
Posted on Apr 08, 2008
I have an acer aspireoneD255 and its not recognising erthnet connection on any modem so i cant configure it correctly also andriod will NOT set up
can you get wirless connection by sliding the switch over to the right
it is down on the bottom right of the laptop i believe
and when you plug the ethernet wire from modem to laptop via ethernet socket
it normally works just fine
Feb 22, 2011 | Acer Aspire One PC Notebook
Reset bios password rm cy25
There are 2 ways you can reset your bios2_bing.gif.
1. On the motherboard there is a small watch battery. Remove this battery along with the power cable from the power supply. Hold down the power button to fully discharge the system. Wait 2-3 minutes then reinstall the battery and plug in2_bing.gif your system. Your reset is now complete
2. Some motherboards have a 3 pin jumper by the battery. Lets say that the jumper is on pins 2 and 3. Remove the jumper while the machine is OFF and place onto pins 1 and 2. Power on your machine for a minute. (Note: Your system will not POST). Shutdown your machine and put the jumper back to pins 2 and 3. Your reset is now complete
This is a great troubleshooting2_bing.gif step for those of you having POST issues or no POSTing at all. Like other troubleshooting steps, this will not always work but usually will depending on the problem.
Please let me know if you have any further questions or concerns.
May 05, 2010 | Fosa CY25 Laptop
Compal RM CY25 Laptop. new battery won't charge.
Unfortunately, the charger socket in the motherboard does not drive electricity to the battery to get re-charge it. It is a typically motherboard problem(Do not confused with a power jack problem). I can not be repaired it.
Two options work always hook with power adapter or get ride of her.
Jan 30, 2010 | Computers & Internet
How to reset a laptop CY25?
Windows XP, right? Click on start, shutdown and then restart!
Is the laptop frozen? Hold down the power button for about 5-10 seconds until power shuts off. Just press the power on again to get it to start back up. Make sure you can NOT reset soft before cycling power on your laptop because you can lose/corrupt data during a cold boot.
Hope this helps,
Sep 04, 2009 | Fosa CY25 Laptop
Want to get on internet with my lap top via wireless what card do i need for the inspirion 8100
first of all you need to check with your internet provider to see what modem you can use. a wirless 802.11g card (the farthest range) if your provider has a wirless modem i would get it from them. and a wirless modem/router. i use bellsouth wirless dsl and bought the equipment from them. if you have a wirless modem/ router already then you just need the card and configure it.
Jul 26, 2009 | Dell Computers & Internet
Wireless networks not found
Sometimes Satellites get a little flaky when on battery power. If you haven't already, plug in the power cord with the notebook cold - meaning off for about a minute. Boot the notebook and try to do the setup with the power connected. If that solves it, it should work fine when you switch to battery power. If it doesn't, repost with your results.
Jun 11, 2009 | Toshiba Satellite M65-S821 Notebook
ok for some reason by running the game morrowind it fixed my display. Dont ask why, I dont know but thanks anyway. Maybe it has something to do with the mods that I have put on it.(morrowind)
Dec 14, 2008 | Fosa CY25 Laptop
My wirless is not working
The wireless switch is located just behind and to the left of the wireless LED. The wireless LED is located on the left of the bottom half of your laptop looking from the front between the battery, power and harddrive LED's and the audio jack sockets.
Aug 03, 2008 | HP Pavilion dv9000z Notebook
Compal cy25 laptop
You can find drivers and manual
Mar 24, 2008 | Computers & Internet
Rm cy25 service manual
Compal manufactured this computer and it was sold under many different manufacturers names.
To remove optical drive: Extract the two screws in the base that obviously attach to the drive. Remove cover from memory, roughly in centre of base, and you will see a screw that secures the drive. Remove the screw and the drive will slide out. Remove the bracket on rear of drive, attach to new drive and reverse above procedure. Memory is located under the said cover and also under the keyboard. Not too difficult to remove keyboard. Remove switch panel after removing screws in back of hinges. You will see several screws on rear of keyboard. Remove these (very small) and keyboard will swing upwards and out. Beware ribbon cable connector underneath as removing keyboard. You will then see second memory location. Max mem 1G
Jan 14, 2008 | IBM ThinkPad T40 2373 Notebook
IBM ThinkPad T40 2373 Notebook Logo
135 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
