Question about Kenmore 61282 / 61284 / 61289 Top Freezer Refrigerator
Kenmore refrigerator 106.61282100 won't cool. Fans are operational and I hear an occasional clicking sound (relay?) I measure 120V AC out of the run capacitor (part #2169373) ofter every other click (0V otherwise). The compressor is warm but not turning on. My wife reported a burning smell before she noticed the fridge wasn't cooling. I can detect a slight smell as well but I can't locate it. Can you suggest any other debug steps, or do you think the compressor needs to be replaced?
3 Suggested Answers
  • 116 Answers
SOURCE: Sears Kenmore 53652300, doesn't cool
This usually indicates that the compressor is working too hard and drawing too much current. The click that you hear is a safety shut-off. Possible causes of this are numerous and usually require having a professional come in to fix the issue, it can range anywhere from a faulty compressor to a bad start relay.
There is in most cases a temporary fix, it is called a hard start relay/capacitor. It is usually available from an appliance parts retailer for around $15 to $20. Installation instructions are included, just be sure to unplug your refrigerator first and make sure that someone following you can repair from where you left off. This relay assembly can normally get you up and running but it should not be used as a permanent fix. This will not correct for a refrigerant leak in the system.
Check your refrigerator owners manual before making any repairs or modifications to your refrigerator, there may be an extended warranty on the sealed system and compressor.
Posted on Aug 01, 2008
  • 6 Answers
SOURCE: Refrigerator not cooling
Clicking sound is most likey the overload on the compressor. You could have one of 2 problems,The compressor relay and start capacitor may be defective therefore not sending the correct power to start it up properly, this is a common part that burns out on any refrigertor. Worst case scenerio... It may also be a bad compressor. If the compressor mechanically seizes up it will try to start and draw high amperage.
The only way to test which one is the problem is buy using a compressot test kit or you can try your luck and change the start relay and capacitor which will run you about 40-60 bucks give or take.
Posted on Feb 22, 2009
Kenmore elite refrigerator, both are "luke warm"
Sounds like your start relay/capacitor is fubar. The clicking is caused by the Klixon shutting down power to the compressor when it does not start properly. When it cools it resupplies power only to overheat and click when it shuts down again.
Jun 12, 2017 | Refrigerators
I have a Kenmore side by side, model#106.52572. My power went out Wednesday night and the freezer & refrigerator sounds like it's running but it won't cool and the icemaker even sounds like...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 26, 2011 | Kenmore 57029 Side by Side Refrigerator
My bottom freezer refrig. Kenmore 596.72214200 - suddenly smelled weird burning smell from back of frig., hear occasional clicking sounds. Everything seems to be working. Smell seems to happen when...
heatman101
May 31, 2011 | Whirlpool Refrigerators
Refrigerator not cooling, freezer not freezing. Can hear fan running continuouisly and an occasional buzzing noise that lasts for about 20 seconds then ends with a clicking sound.
the buzzing and click noise is the ptc overload relay on the compressor,its bad,unplug it off the compressor and obtain a replacement and plug in the new one
Mar 24, 2011 | KitchenAid Superba KSRG25FK Side by Side...
I have a Kenmore fridge model 53542300 the fridge and freezer are not cooling I can not hear compressor running nor is it hot. I do see the fans running for Fridge and freezer. I went to check the start...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
heatman101
Dec 28, 2010 | Kenmore Refrigerators
My Kenmore complete stop working. no lights on the from ice dispenser, no fans, no cooling.
heatman101
Dec 27, 2010 | Kenmore Refrigerators
Not cooling; relay clicks; compressor runs for 5 sec then stops.
Is the compressor actually starting or is it humming? If it is humming, then it is probably your capacitor, which would end up costing about $20 for the part, much cheaper than a new refrigerator. I feel that this is most likely your problem. If the compressor has a starting relay, this could also not being operating correctly. If you carefully disconnect the capacitor, you can check the mfd rating with a multimeter. You can also check the starting relay (if applicable) with the multimeter set to measure continuity. Hope this helps. BTW... A new starting relay, called a CCR, or Current Coil Relay, will probably run you about the same, $20.
May 22, 2010 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Hear relay clicking on and off, refrigerator is
I would suggest repairing the unit . For less than $ 75.00 , compared to the cost of a new refrig . The problem is the overload/relay , which is plugged onto the side of the compressor , with 2 or 3 wires going to it . This is easily replaceable . If you had given the model number , I could have given you a part number . Be sure to take it ( model number ) with you , when getting the part , so you get the correct part .
Nov 22, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Kenmore Coldspot Side by Side Model 51559101
Unplug the Ref for 15-20 min., plug it back in and listen for the compressor to start. You will need to be behind the Ref so you can tell if the compressor or the fan is running. It will help to take the cover off so you can see the compressor.
Compressor not running but you hear a clicking noise. The relay needs to be replaced.
Compressor runs but not cooling. Low on coolant
Feb 06, 2009 | Kenmore 53642 / 53644 Side by Side...
Aug 01, 2008 | Kenmore 53642 / 53644 Side by Side...
Kenmore 61282 / 61284 / 61289 Top Freezer Refrigerator Logo
202 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
jackdo2
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
