Question about Dryers
Belt sliped off dryer
How do i put it back on
  • vicpowell3 May 26, 2009
    the pulley came off and i don't know how to put it back
  • 135 Answers
If u can acess the motor there will be an idler pulley, usually with a spring that you will have to pull tight. Wrap the belt around the pulley, then the motor shaft. Release the pulley and try it.
Posted on Apr 07, 2008
Drer heats but drum does not turn
Hi, it sounds like the drive belt is sliping,broken or something connect with the drive is sliping or broken. If you can see the motor and belts turn it on and the fault should reveal itself
Good luck
Aug 04, 2014 | Kenmore Dryers
Drum is hard to turn. When running, there is a loud high pitched squeal. I oiled the pully area in the back, and the noise stopped and the drum turned, briefly. Now, the drum doesn't turn at all. ???
if you got oil on the belt or the part of the pully where the belt rides then the belt is sliping and wont turn the drum.
you will need to get the oil off of the belt or buy a new one and you will need to get the oil off the motor pully and the idler pully and if any oil is on the drum.
This is where I would start given the information you have given.
Oct 06, 2010 | Kenmore 83042 Electric Dryer
The dryer is not turning where do and how do get to check the belt, if it is broken or maybe sliped off?
you will have to remove the front panel. screws are on the inside of the door, may be two on the bottom corners, with a flat tip screw drive gently pry up on the top corners. remove panel disconnect door switch, the belt goes around the drum to the motor and has rollers on the back of the drum. I even think on the backside there is a rest button. Hope this helps Tim
Aug 30, 2010 | Maytag Dryers
Vauxhall vectra back seat belt malfunctionback
sounds like the recoil has gone or sliped out of the belt unit get a second hand one from a breakers yard becuse if you open up the belt unit you will be finding bits all around your garage for weeks,
Nov 16, 2009 | Graco Snugrider Infant CarSeat Stroller...
Dryer heats up but the inside doesn't turn.
a dryer will not turn if the belt has fallen off the motor or if it has been broken    replace the belt
Nov 05, 2009 | World Imports Belle Foret N30002TB...
My kenmore dryer's drum does not spins. I checked for the belt and it's fine. Where do you suggest I check?
the drive motor if its not turning then the drum wont turn, also if its sliped the belt off thats another reson why and one more thing to look at is how tight is the belt on the drum,,, is it just sliping round it? is the drum very tight to turn by hand? are the drum bearings jamed up, is any thing stuck behind the drum? ??? like one of the kid's?
i hope this is helpfull to you
Oct 23, 2009 | Kenmore 63942 Dryer
Dryer takes a least two cycles to dry a load and just started making a strange noise.
hi,if you belt runs blower and tumbler,it could be lose belt,or worn out. the blower creates draft in dryer,and tumbler to fluff up. if the speed of tumbler or blower is not rite it will take long time to dry.and the nosie is the belt sliping.
May 29, 2009 | Dryers
Removing the back of the dryer
to get at belt you will need to get true the front of dryer.When you have top up there should be 2 screws on both inside corners on front panel remove them and lift up and towards you the front panel should come off.After that look under drum .Sounds like your belt sliped off the idler pully you can then put belt back on and reverse the steps.If any more help needed feel free to ask hope i fixya:)
May 21, 2009 | Kenmore 64852 Electric Dryer
Dryer is noisy. rollers are new. sometime the dryer starts fast
I would say the belt may have sliped off the pully.Make sure the belt is on correct.
May 08, 2009 | Kenmore 73952 Gas Dryer
Dryers Logo
113 people viewed this question
Top Dryers Experts
