Question about Remote Start System
Viper Remote Start wont work properly
Hello, I have a viper 5902 installed on a 2002 Chevy Tahoe. Everything works properly except the remote start. Once installed it would work for about 15-30 minutes but after driving off it will not remote start anymore. it trying to crank and goes through all three cycles unsuccessfully. What could be the reason for this problem and how can i correct it?
If it cranks and wont start then its probably the bypass the module thats not working correctly
Posted on Jan 20, 2011
I changed my blinker switch in my 2001 Montana and the remote start won't start the van it turns the lights on but won't crank over then turns off then blinks then trys again
Posted on Nov 23, 2014
MY VIPER 4105V REMOTE START STOP STARTING THE CAR. I NOTICE THAT IT TRY TO START TWICE BUT JUST WON'T TURN OVER. EVERYTHING WORK EXCEPT THE REMOTE START. STOPPED WORKING AFTER 4 MONTHS.
I would highly recommend you have the Viper removed from your car permanently by an experienced professional or you will most likely have other problems later as a result of this item being fitted (if you ever get it working again which I doubt).
Nov 30, 2015 | Viper Vehicle Parts & Accessories
Remote start wont start the car
try hitting function twice so its at level 2 code and hit the unlock button, that sends it into remote valet mode. if that isnt it make sure the valet toggle switch is on and connected
Dec 01, 2012 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Everything on my viper 5601 system install on a 2006 Dodge Ram 1500 works except the remote start
Check the toggle switch, usually mounted under dash. It's simple on/off switch. Or it's your hood pin switch.
Or tell me how many times your parking lights flash when you push the remote start button and I'll def tell you the issue.
Aug 12, 2010 | Viper Security and Remote Start System...
Alarm light in dash blinks constantly, remote start doesn't work, and occasionally truck doesnt start. Have an Esi Viper remote
did your install it yourself or did someone do it for you if either way man you may need to get someone to look at your wiring make sure everything is tired in right to your vehicle your power sources your ground everything your relay may be gone on the remote start in that case you can have that problem check your relay leading to your remote start
Nov 11, 2009 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
VIPER 160XVL remote start stopped working
sounds like the unit has lost power. i can't tell you where the relay is located for that device but it may have failed.
Oct 19, 2009 | Viper 160XVL Viper 160XVL Remote Start...
Viper works but remote start and keyless entry does not
On the remote start part, it might be as simple as relearning the tach. To do this, crank the car with the key, press and hold the valet switch until the led lights and stays solid now release.Try the remote start. Need to know what kind of car to comment on doorlocks.
Jun 14, 2009 | Viper Security and Remote Start System...
Won't start my car anymore. everything else works.
Check to see if any fuses are blown on the alarm brain.
Mar 28, 2009 | Viper Security and Remote Start System...
The vehicle starts , but immediately dies.
I would look at the tach wire it is probly not getting signel back to the remote starter usaly a purple wire on remote starters
Mar 01, 2009 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Remote Start System  Logo
1,158 people viewed this question
Top Viper Vehicle Parts & Accessories Experts
Kevin Daniels
Tre Elkins
Shehu Pro
Shehu Pro
Are you a Viper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
