Question about Yamata FY101-1A
Babylock espire bobbin sensor not working
I have a babylock espire. The bobbin sensor is not working -- it does not "sound" when I am almost out of bobbin thread. The upper thread sensor is working.
    New Friend:
  • 184 Answers
This is normally caused by lint in the bobbin area, the lint blocks the sensor causing it to be blind. Try cleaning the area and see if that helps.
Posted on Jun 03, 2010
How to change the thread spool pin on babylock model esp
Depends. Some spool pins simply push in and snap in place, but as many machine brands existing, there are probably double the different spool pins available...
http://www.sewingpartsonline.com/babylock-esp-sewing-machine-parts.aspx If you order from one of the online vendors, they will probably be able to advise how to install it.
Spool Pin for Brother Baby Lock X59053051 Old X59053022 X59053052
SPOOL PIN Babylock ESL ESP Espire Brother CS8072 PC2800 PC3000 PC6500...
Mar 24, 2017 | Sewing Machines
Babylock frozen tight its a eklure plus only used 6 time I've check bobbin cade changed needle although it was fine shut it off and turn it on. Bobbin winder on right side. It threw up a safety warning...
Sounds like it's time for a visit to the repair shop Babylock Ellure
is a fairly nice machine, it will be worth it...
Cheers,
Kelly
Embroidery Services
San Diego, CA
Nov 23, 2014 | Sewing Machines
The computer pressure foot button on the espire does not work
If it's an electronic presser foot lift you will have to take it to a babylock dealer for repair. If you mean the automatic stop/start button, make sure your foot control isn't plugged into machine first. If it still doesn't work, you will have to take it to a dealer for repair.
Oct 29, 2014 | Sewing Machines
Babylock espire thread cutter stopped working
Your cutting blade is dull. It needs to be replaced by a experienced technician.
Cheers,
K
Feb 27, 2014 | Baby Lock Espire
Bobbin jam babylock 1506
Ooo ouch! sounds like you have a pretty bad timing problem and or a damaged bobbin case. Since it is a baby lock I would suggest taking it in for repair.
Sep 08, 2012 | Baby Lock Sewing Machines
How do you unlock the safety device on a babylock espire sewing machine without going back to a dealer?
hi Katester.
not sure if you have the manual but if you go to this link it has the manual and you can read up on it.
http://babylock.com/ftp/whitepapers/Espire_BLSR_InstructionManual.pdf
or go to this link but i could not find much on there but have look.
How do you unlock the safety device on babylock espire sewing machine...
Jul 24, 2011 | Baby Lock Espire
I lost the power cord to my baby lock espire when I moved. How do I get another one?
Contact a local dealer and they can order you one. If you don't have one in your yellow pages, I believe you can find one at Babylock.com
Aug 11, 2010 | Baby Lock Espire
Tension settings for the babylock sewing machine
I found that the tension setting of 1 worked. The main problem was the machine had thread wound around behind the bobbin. I had to take the plates that are under the foot out, clean out the thread, oil the machine and use a spool of thread that had more weight than the little spool I was trying to use.
May 15, 2009 | Baby Lock BL1556
Embroidery bobbin problems.
Each manufacturer have their own bobbins.......not interchangable
Apr 28, 2009 | Baby Lock Sewing Machines
Sewing Machines Logo
165 people viewed this question
Top Yamata Sewing Machines Experts
Lyle Siemens
Lyle Siemens
Michael Kovalik III
Michael Kovalik III
Cleverer2
Are you a Yamata Sewing Machine Expert? Answer questions, earn points and help others
