Question about Thermador PD366BSS Stainless Steel Kitchen Range
Burner does not lite and has no gas
The left most burners with the extra low settings does not ignite. The ignitor does not start nor is there gas when you turn on the burner.
  • 12,061 Answers
Http://www.thermador.com/SupportCenter/DocumentDisplay.aspx
Above is the support center, below is a service manual, that should help with troubleshooting. http://www.servicematters.com/maytag_library/docs/16022514.pdf
Posted on May 28, 2010
Why wont the left and right burners lite using the electric ignitor?
Are the igniters for those burners sparking?
Aug 29, 2014 | Grilling
All pilots ignite when 1 gas knob is used on one burner
All igniters will spark when you turn on any burner but only the one you have turned on will allow gas through to ignite.
May 04, 2014 | GE Kitchen Ranges
I have the star burner model, w/ extra-low simmer. The center burner will not light at all by itself. The right rear burner will self-ignite if you turn it to low, and then slowly rotate the knob clockwise...
Center burner won't light: If there is a bright spark (check all ignitor points at night with the lights out and look for consistent brightness of the sparks) then it's likely that the burner slots are dirty or the air/gas mix is wrong. If you can light with a match, but the spark won't light, then go for cleaning the entire burner assembly thoroughly with a brass bristle brush (available at most automotive stores). The proper air/gas mix has to flow over the spark to ignite. Weak spark, improper air/gas or misdirected gas flow that misses the spark can all cause this issue.
RR burner lights only on low setting. Again, check the air gas mix and clean all parts. Something like a small spider web inside the air mix chamber (area between the orifice and the burner can cause this and is difficult to see. Disassemble, clean thoroughly, reassemble and test. Extra low simmer burners (two on the left side) use their own control module with electric gas valves and variable electric control switches. The burner works on low, so these are not likely the problem.
Most folks want to find a bad part, and that can happen, but stove tops get dirty and cleaning usually helps. If not, you have a clean top to work on.
The indicator lens and/or the retainer are either broken or the retainer is missing. It's best to replace these as they are not expensive. When the top is off while cleaning is an perfect time to replace the lens.
Mar 30, 2017 | Thermador 37 in. SGSX365 Gas Cooktop
Burner will not light
possibly the ignitor has a weak spark its making the jump to the burner but not strong enough to lite the gas did you check the lines for spider webs or other insects?
Jun 17, 2009 | DCS BGA27-BQ (NG) Grill
Extra low burner that won't ignite
Lowly what the potentior does is turn on the burner control system. When you turn on a normal burner you are opening a gas valve and closing a switch to generate a spark. Thus gas flow to the burner and spark. On the extra low simmer burner there is a electric solenoid between the burner head and the gas valve. this has to open as well for gas to flow. What the potentior does is signal the simmer control what level of flame you are requesting and telling the spark module to generate a spark. Once you go to the exlow setting the potentior tells the simmer control what level of heat and will cycle the flame on and off. So when the burner knob was between low and extra low, the flame would cycle on and off. You have to seperate the top section of the cooktop from the burner box to change the potentior for it sits on top of the gas valve for that burner.
Aug 10, 2008 | Thermador SGS36GS Gas Cooktop
Igniter problem
After the burner lights move the knob a fraction away from the lite position.
If that fails, replace the spark ignitor switches on each gas valve.
Jun 24, 2008 | Whirlpool SF325 Gas Kitchen Range
Igniters are not working right
when you turn any burner control to lite all ignitors should click this is normal industry wide. the ignitors are controlled by switches that are placed over the valve shafts they are wired up together so thats why they all click when you only operate one valve don't worry about it. the ignitor stays on untill you back the valve off a tad this is also normal.
Apr 15, 2008 | Cooktops
Ignitors click
thats normal long as they all quit after the one your using lites and you turn it off light
Mar 31, 2008 | Jenn-Air JGS9900BDS Stainless Steel Gas...
I have a 6 burner Thermador Gas Cooktop SGS456ZB. I have a problem with one of the ignitors. It keeps firing the entire time the burner is on. The other 5 ignitors and burners including the 2 extra-low...
Dear Kathynearing,
Hi. I have experience cooking in a burner like that it keeps on burning coz the ignition coil was press by your switch knob coz the spring was stack up try to release it so that it will not be ignited all the time when your cooking. This should be ignited at once. If it gives light already it should be released. Please reply if you have solved the problem so that I can give you more advices.
Mar 30, 2008 | Thermador Kitchen Ranges
Thermador PD366BSS Stainless Steel Kitchen Range Logo
162 people viewed this question
Top Thermador Kitchen Ranges Experts
Dan Webster
Dan Webster
butch welch
Are you a Thermador Kitchen Range Expert? Answer questions, earn points and help others
