Question about Xerox Fuji Media Drawer and Tray - 550 Sheets Printer
Cannot print & error message show "006-370 Turn off. Reboot Printer" This error message meant wha?
  • Xerox Master
  • 12,061 Answers
Unplug from the Wall, leave for say 5 mins, reconnect.
Posted on May 28, 2010
Why my canon ir1133 printer is showing e733/0000 error message?
ERROR E733-0000 Stops printing and shows sign "Turn ...
www.fixya.com/support/t21602993-error_e733_0000
Nov 20, 2013 - ERROR E733-0000 Stops printing and shows sign "Turn main power ON". Error ... error message when printing d1350 imageclass. Jan 03 ...
Oct 29, 2015 | Canon imageRUNNER 1133 Laser Multifunction...
Error 49.23F9
. Press CANCEL JOB to clear the print job from the printer memory. 2. Turn the printer off, and then turn the printer on. You can try reprinting the job to see if it was a temporary error. 3. If error persists, try printing a job from a different software application. If the alternate job prints, go back to the first application and try printing a different file. (If the message only appears with a certain software application or certainprint job, try upgrading the printer driver and / or firmware.) 4. If the message persists with different software applications and print jobs, disconnect all cables to the printer that connect it to the network or printer. Turn the printer off and delete the print queue. Then reboot printer AND computer, reconnect cables, and try printing again. 6. Remove all EIO devices from the printer (JetDirect cards, hard drives, etc.). If 49 error goes away, turn printer off, re-install EIO devices one at a time, and reboot printer each time to determine which EIO device is failing. 7. If printing still fails with all EIO devices removed, remove all memory DIMMs or third-party DIMMs from the printer. (Do not remove the firmware DIMM-- printer won't function without this installed.) Turn the printer on with DIMMS missing. If the error no longer exists, install each DIMM one at a time, turn printer on, test printer. Replace a DIMM if you determine that it causes the error. 8. Remember to reconnect all cables that connect the printer to the network or computer. 9. If the error persists, replace the firmware DIMM. 10. If error persists, replace the formatter.
Mar 19, 2014 | HP CP3525N Color LaserJet Printer
Laserjet 2605 49 error
Error 49 is a firmware error. Try following these steps:
1. Press CANCEL JOB to clear the print job from the printer memory. 2. Turn the printer off, and then turn the printer on. You can try reprinting the job to see if it was a temporary error. 3. If error persists, try printing a job from a different software application. If the alternate job prints, go back to the first application and try printing a different file. (If the message only appears with a certain software application or certainprint job, try upgrading the printer driver and / or firmware.) 4. If the message persists with different software applications and print jobs, disconnect all cables to the printer that connect it to the network or printer. Turn the printer off and delete the print queue. Then reboot printer AND computer, reconnect cables, and try printing again. 6. Remove all EIO devices from the printer (JetDirect cards, hard drives, etc.). If 49 error goes away, turn printer off, re-install EIO devices one at a time, and reboot printer each time to determine which EIO device is failing. 7. If printing still fails with all EIO devices removed, remove all memory DIMMs or third-party DIMMs from the printer. (Do not remove the firmware DIMM-- printer won't function without this installed.) Turn the printer on with DIMMS missing. If the error no longer exists, install each DIMM one at a time, turn printer on, test printer. Replace a DIMM if you determine that it causes the error. 8. Remember to reconnect all cables that connect the printer to the network or computer. 9. If the error persists, replace the firmware DIMM. 10. If error persists, replace the formatter.
Mar 10, 2014 | HP LaserJet 2605dn Printer
Printer offline
You did not specify if printer was formerly working, the model # of the printer, or what version of Windows you are using. All this information is needed for successful troubleshooting. However, the below is general resolution for your problem:
"Offline" means your computer cannot "see" the printer as connected and powered on.
In order of things to try:
1. Turn printer OFF. Unplug USB cord from printer (or other end from computer). Wait at least 30 seconds. Plug USB cord back in. Turn printer back on. Does it still show as "offline" under Start --> Devices & Printers?
2. Try replacing the USB cord (yes, they can and do go bad).
3. Turn printer off. Unplug USB cord.
Under Windows Start --> Printers and Devices:
RIGHT click the Konica printer icon. Select "uninstall" (or "remove device") and follow through until printer is successfully UNinstalled. If there is other Konica software installed, remove it also (via Start --> Control Panel --> Add/Remove Programs -or- Programs & Features).
4. Reboot your computer. Follow manufacturer printer installation procedure, step-by-step (consult mfr website if you do not have a printed installation manual). Do not plug in USB cord or turn on printer until instructed to do so.
If all else fails:
Ignore any manufacturer installation instructions.
Do # 3 only above.
Reboot computer.
Plug in printer and connect it to computer.
Let Windows try to automatically install it (in most cases, Windows can install the "basic" print drivers, which are smaller and sometimes more stable than the fancy drivers and excess software the manufacturer wants you to install).
If still no go, you probably have a dying or dead printer. Consult manufacturer website for help.
Mar 07, 2014 | Konica Minolta Office Equipment & Supplies
4730mfp error 49. turn of and on, but not resolved
Dec 18, 2012 | HP LaserJet 4730x MFP All-In-One Printer
When im trying to print a document using an hp laser-jet p1005 the printer doesnt respond but i get an error message one of the usb devices has malfunctionedand windows does not recognise it wha should i...
unplug the usb from the computer. try uninstalling the printer from the control panel.
then reboot the computer and plug the usb back in so that it will reinstall.
this may help. try this first.
Mar 28, 2011 | HP Hewlett Packard LaserJet P1005 Printer
The printer shows an error message of "lower the
  1. lift the paper exit tray
2. lower the paper exit tray again 3. press the select button 4. Resend your print job to continue.
Dec 27, 2010 | Dell 962 Photo All-In-One InkJet Printer
Error message 49 on my HP CP 2025 (printer shuts itself off and truns itself back on to see error message 49)
Firmware error:
Nov 22, 2010 | HP Hewlett Packard LaserJet 3000dn Printer
I have DCP-585CW and get the following error message "Unable to print 70". Would you let me know how i may clear this problem? Thank you, Farzam
Unplug the Printer from the wall and PC, now reboot PC, when at desktop next, plug in the printer to the wall, and turn ON, now after a bit, you should be able to go to printers and find your printer, or right click on the printers icon, choose properties, & open, now print a test page to see if you have connectivity too. make sure you driver is installed too. This link below, will show toy step by step, in detail how to do it all. http://support.euro.dell.com/support/topics/topic.aspx/emea/shared/support/dsn/en/document?c=ae&l=en&s=gen&docid=B1C81A9461454AFF9F20F5305385C6CA&journalid=87F86FEAA411F5EDE040AC0A64E9621D&Query=&SystemID=&ServiceTag=&contenttype=&os=&component=&lang=&doclang=&toggle=&dl=
Jun 07, 2010 | Brother DCP-585cw All-in-One Wireless...
Refuses to print in XP - no error messages
Try going to 'add & remove hardware'. Remove the COM ports. Reboot your computer. Windows should find your hardware and install the COM ports. If not, add the COM ports manually. Leave the printer COM port settings on COM port 1 or COM port 2, whichever you prefer.
Jun 24, 2008 | Datamax Prodigy Plus Thermal Printer
Xerox Fuji Media Drawer and Tray - 550 Sheets Printer Logo
409 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
