Question about Nokia 5310 Cellular Phone
Nokia 6130i not charging - Nokia 5310 Cellular Phone
  • 99 Answers
Dear customer
If ur handset is not charging then check by other charger,charging connecter,charging diod & resistace & wash the component by tooth brash with PCB cleaner.If u are technician then send me testomonial for jumpering solution.if u are not a technician then its better to go ur nearest NOKIA care.If u are saticfied by my solution then VOTE me and ranking me.Thank you for ur visit.
Posted on May 28, 2010
Nokia 1202 not charging
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Oct 09, 2012 | Nokia 3110 Cellular Phone
I have nokia 5800d when i plug charging it show not charging plz i need help on this phone
I have nokia 5800d phoneb when i plug the phone in charging its show the charging indcator but the battery didnot getting charge please help me
Jun 20, 2012 | Nokia 5800 XpressMusic Smartphone
Nokia 6610i not charging
NOKIA 6610 NOT CHARING PROBLOM
Sep 17, 2010 | Nokia 6610
Nokia 1112, not charging
First Option:
Secend Option:
Aug 30, 2010 | Nokia 1112 Cellular Phone
Nokia phone
First Option:Please change The Phone Bettery and charger and check The check The Phone charging
IF Charging Problem will Not Solved So
Secend Option:Your Phone charging IC Fault SO Please change charging IC And charging Problem will SOlved
Jul 08, 2010 | Nokia 1600 Cellular Phone
Hi,my nokia n95 wont hold charge i have a new battery and new software,do you know what the problem could be,also when it charges it doenst cut out when it is charging it just keeps charging,thank you
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Dear user,
Such issue may appear when Nokia charger adapter CA-146C is used with incompatible charger to charge Nokia N97. Currently compatible chargers for N97 with CA-146C are Nokia Travel Charger AC-4 and Nokia Compact Travel Charger AC-5.
Spangley, just plug it into your PC. If your battery needs charging, it will charge slowly simply while being connected to your computer. Nothing else to do!
Goodluck :)
Dec 11, 2009 | Nokia N95 Cellular Phone
I need to know how to connect it to my phone
The owners manual for the Aris21 Bluetooth Headset is available here:
http://files.anycom.com/documents/manuals/cc3101-manual-en.pdf
Specific instructions on how to connect it will depend on your Bluetooth mobile phone model. Typically, this has to be done by going to a setup or connect menu and then selecting the options to discover Bluetooth devices.
Before you start the process, make sure the Aris21 is fully charged and the charging cable is disconnected from it and while the
Aris21 is powered off, press and hold S1 for 10 seconds: red and green LEDs flashing alternately will indicate that the headset is in pairing mode.
Then follow the operating instructions for your Bluetooth mobile phone to start the pairing process. Bluetooth may take several seconds to establish a connection.
Your phone's display should indicate that it has found the “ANYCOM ARIS-21” headset and asks if you want to pair it. You should confirm this. The phone's display would prompt you for a passkey or PIN. Enter a sequence of “0000”.
The headset LED will flash green every 3 seconds, indicating successful pairing. Usually the phone will also ask whether
you want to change the headset's name. It is recommended to approve the ANYCOM ARIS-21 name and not change it.
If pairing does not occur as expected: Turn the headset and the phone off and wait for 10 seconds. Turn the headset and phone on again and repeat all steps from beginning. Pairing does authorize the devices like mobile phones and headsets with each other and only needs to be performed once.
After successfully pairing the ARIS-21 and the mobile phone, you may need to establish a Bluetooth link between them according
to the operation manual of your mobile phone. To establish the link, press S1 shortly. Use Nokia 6130i as an example, the mobile
phone will show „Do you accept ARIS-21 request for connection?” Select YES to establish the link. You are ready to make and
answer calls on the Headset. For other phones, please follow the operation manual to establish the link.
Aug 30, 2009 | Anycom Aris21 Bluetooth Headset Wireless...
Nokia N73 Music Edition Charges Forever
try factory reset ...... if that does not work get it checked with the nokia service center
Mar 07, 2009 | Nokia N73 Music Edition Smartphone
Not charging
Nokia chargers are pretty notrious so I recommand you check the charger first :)
Sep 30, 2007 | Nokia 3220
Nokia 3250 charging problem
it sounds like a problem with the charging port (where you actually plug the charger into your phone). unfortunately, you may have to replace the phone, as switching batteries or chargers wont solve the problem.
Sep 24, 2007 | Nokia 1100
Nokia 5310 Cellular Phone Logo
213 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
