Question about Sony DAV-SR2 System
My Sony DAV- SR2 System won't shut down
When I try to turn the system off it starts flashing "Standby" untill i pull the plug. Its starting to get annoying to have to pull the plug every time I accedentally turn it of. I think the reason is that the system has been on for too long (several months) whithout rest.
SOURCE: Blinking standby light system will not turn on
I was having a similar problem and determined that there was a short in the speaker leads for the center channel speaker. The leads to the speaker were touching, after being moved, slightly while housecleaning. Once short was eliminated, unit powered on and worked with no problem.
Posted on Dec 02, 2007
  • 3 Answers
SOURCE: my DAV-FC7 System squeals loudly.
If you can, use the digital optical connection....I had the same problem and switched to the digital optical connection and that worked for me....no more whine.
Posted on Dec 27, 2008
nuwan chinth
  • 111 Answers
SOURCE: Sony DAV-C770 Red Light Flashing but nothing is on!
power supply or power amplifire unit problem.give it to repair proffesional.
nuwan.
Posted on Jan 19, 2009
SOURCE: my sony dav-s-400 system keeps activating headphone port output.
Just had and fixed the same problem that hundreds of people are suffering with this system!!
Sony DAV s400 - same problem, won't play though speakers and display indicates that headphones are plugged in - when they are not. Fairly easy to fix and took me less than an hour from start to finish:
1) Remove top cover
2) Remove circuit board that has Audio In/Out phono scockets (to get access to Amplifier Circuit Board)
3) Remove Amplifier circuit board (has the speakers attached)
4) Turn it over and remove copper heat shield
5) Resolder joints where the big brown capacitor is and where the wires go to the front headphone socket...and any other dodgy joints that you find
6) Reassemble.
Posted on Apr 27, 2009
  • 15 Answers
SOURCE: how do i connect external DVD player to DAV SR2
SORRY, YOU CAN'T CONNECT AN EXTERNEL DVD PLAYER TO WATCH THE MOVIES.. BUT YOU CAN ENJOY THE AUDIO WITH OTHER PLAYER...
SONY DAV SR2 DOESNOT HAVE THE VIDEO INPUT... SO U CANT CONNECT VIDEO.. BUT U CAN CONNECT AUDIO INPUT FROM OTHER SOURCE THROUGH RC LEFT AND RIGHT PINS.. (ANALOG)
OR U CAN USE OPTICAL DIGITAL INPUT AUDIO.
ANY QUIERIES MAIL TO ME
kanny_amancha@yahoo.com
kanny-sounds.blogspot.com
Posted on Jul 16, 2009
Reset my dav-ea20 system,it comes on,but shuts down with blinking light
Your unit has DC Offset(a damaged amplifier) which is why it keeps shutting down. If you are interested in repairing your Sony, please visit my website at audioserviceclinic.com. Thank you.
Jan 13, 2015 | Sony DAV-EA20 System
Half way thru DVD the system shuts down and stand-by flashes
change the belts...the loader mechanism must be lubricated...
Jan 26, 2010 | Sony DAV-SR2 System
Getting sound to TV from DVD Home Theatre System
lght304su home cinema,how to connect to tv to get sound through
Dec 29, 2009 | Sony DAV-SR2 System
Sony HCD-BC150 As soon as I turn it on, it shuts
Change the audio amplifier IC are on short circuit and that´s the cause your device goes to protect mode
Aug 11, 2009 | Sony DAV-BC150 System
How do i connect external DVD player to DAV SR2
Jul 11, 2009 | Sony DAV-SR2 System
Sound for othe Units
Dear Kaza,
Switch on the sony system and PS3. Start operating. go to the menu of PS3 and convert the audio analogue output to DTS made ( optical out)
ramesh22
Jun 08, 2008 | Sony DAV-SR2 System
Shuts Down
power supplly printed bord faulty or power amp output stage heating more than the rated temperature can occure this situation.please check the ventilation system first and check the power and power amp section for loose connections.if youhave electronic knowledge .
nuwan.
Feb 25, 2008 | Sony DAV-C770 System
Speakers Crackling and system keeps going to standby.
It sounds like you may have a problem with the sound pc board. If the system shuts down or goes into a stand by mode, then it means the system is detecting an internal problem and is shutting itself down to avoid any further damage. You may need to have it serviced but that could be a little expensive. You can always buy a used replacement receiver if the speakers and sub is still working good.
Hope that helps.
Dec 31, 2007 | Sony DAV-BC150 System
Sony DAV-SR2 System Logo
85 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
