Question about NorStar M7310 Corded Phone
Headset When i plug the headset into my 6 line phone, the customer can hear me but i cannot hear the customer. Help! dianne
    Problem Solver:
  • 6 Answers
Do you have a headset button programmed on your phone?
Posted on May 13, 2008
I have AT&T cordless phones (4). All of a sudden, they all say "no line". Please help
Dianne:
The phone cradle that is plugged into the telephone line coming from the outside of the house is having problems. Check the wall plug where you plug the phone charger into the wall (not the power plug... the telephone wire plug) check to see that both ends of that wire are plugged in properly... One plug goes into the wall, and the other plugs into the charging unit.
Oct 01, 2015 | AT&T E5865 5.8GH Cordless Phone with...
I have the C555 wireless headset. It is breaking up while I am on it. Either I hear crackling sounds and can't hear the caller or they can't hear me without static. I already moved my headset...
It might be that the a/c adapter is not plugged in correctly? Is it on an electrical plug with a switch leg? Could be that the base is not functioning correctly, you may need to purchase a new headset.
Good luck from Headsets Direct - 800-914-7996.
Aug 12, 2011 | Plantronics Radio Communications
Plantronics M175 headset makes crackling noises when speaking with it on and is not loud and clear.
The 2.5mm jack on your phone, that the M175C plugs into, is more than likely causing you the problem. The phone manufacturers do not dedicate a lot of power to the 2.5mm jack, so sometimes people have a hard time hearing you or you hearing them. If you are using a cordless phone, you could use a Plantronics CS55H wireless headset. This headset is intended for only one phone line, not multiple lines. The CS55H's TR1 plugs directly into the wall jack instead of your cordless phone. This eliminates using the 2.5mm jack on the handset that is causing you problems. The headset come with a one year warranty.
Plantronics CS55H Wireless Headset
Good Luck from Headsets Direct!
Jun 22, 2011 | Plantronics M175 Headset
How do I acitivate it
Charge your headset
Charge the headset's battery fully before using the headset for the first time.
1 Put the headset in the supplied charging case and close the cover.
2 Plug the travel adapter into the case's charging socket.
Put your headset in pairing mode
1 Ensure that the headset is off (see Turn headset on/off below).
2 Press and hold the Multi-Function button until the indicator light turns on in blue (approximately 8 seconds).
Turn on Bluetooth on your phone and pair with headset
1 Set your Bluetooth phone to discover the headset by following your phone's guide.
Typically, the steps involve going to the Settings, Connection, or Bluetooth menu on your phone and then selecting the option to discover Bluetooth devices. Your phone will find the Samsung WEP200
headset.
2 Select Samsung WEP200.
3 When the phone asks if you want to pair with it, confirm by selecting Yes or OK.
4 Enter the headset passkey or PIN, 0000.
Your phone and headset are now paired and ready to make and receive calls.
1 Place the headset over your ear.
2 On your phone, make a call to the number you want.
3 If your phone and headset are successfully paired, you will hear ringing on the headset
After you have successfully paired your phone and headset, you do not need to repeat these initial setup steps each time you use the headset.
To turn the headset on
Press and hold the Multi-Function button for4 seconds until you see 4 blue flashes on the indicator light, then release.You will hear a tone and see the indicator light flashes while the power is on.
To turn the headset off
Press and hold the Multi-Function button for 4 seconds until you see 2 blue flashes on the
indicator light, then release.You will hear series of 2 tones and see the indicator light stops flashing.
http://ars.samsung.com/customer/DownloadAnsTempl?AT_ID=70171&SEQ_NO=2
Jun 07, 2011 | Samsung Bluetooth?® WEP200 Headset...
Hi, I have a Panasonic KX T7431 and have just attached a headset. I have changed the programming and i can pick up lines and hear people but they cannot hear me! i have tried another headset from the same...
Headsets on the 74xx series phones come in different flavors than the universal headsets of the 76xx and 77xx phones. The old Plantronics M bases and P headsets used to have a couple of adjustment dials on the bottom of the interface box that you had to play with in order to match the microphone to the phone system. If yours has those dials, try turning them until you can hear yourself in the earpiece.
Carl
Feb 15, 2011 | Panasonic KX-T7431 Corded Phone
Can't hear anything in my bluetooth headset, mic is working
Hi--First, make sure your "mute" function is off.  Try holding both volume buttons at the same time for a second or two.  If that doesn't help, while you're having a conversation, either with or without bluetooth, make sure your phone's volume is turned up.  On a lot of phones the volume button will control both ringer and conversation volumes, but turning it up without the phone in use only affects the ringer volume.  My husband thought there was something wrong with his bluetooth until we noticed his phone volume was set too low--not as noticeable on handset, but bluetooth apparently needs volume up pretty high!
Sep 29, 2008 | HTC Touch P3450 Smartphone
Best Buy: Plantronics Problem
James, plug the phone cord that comes out of the back of the CS55 base into the handset port of the Cisco phone, not the headset port.  Then plug the coily cord from the cisco receiver into the front of the CS55.  Don't use the "Headset" button on your Cisco phone, just lift the receiver off.
Mar 21, 2008 | Plantronics PL-CS55 Wireless Headset
Lost pairing?
First when ya call connects, hit the Menu key (three lines inthe center) choose USE HANDSET.
Second Make sure the Bluetooth is fully charged, andit seems to lose charge fast.
Dec 15, 2007 | Motorola Mobility H300 Wireless Headset
Logitech headset, new vista operating system
either the headset is not supported by Vista, or you need to right click on both speaker icons, normally coloured red and black and in the properties you need to see if your headset is listed as one of the microphone input devices, if you need to make the Logitech headset the default mic and not the windows generic mic. If you do not see it in the properties then it may not be recognised by Vista.
Aug 13, 2007 | Logitech Internet Chat Consumer Headset
NorStar M7310 Corded Phone Logo
Top NorStar Lands Phones Experts
george  peters
george peters
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
