Question about Coleman Propane Grill Stove 9921-700
Coleman propane stove, tank got very cold. why?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 91 Answers
As propane is used it can create frost on the tank or just cause the tank to feel cold. this is normal. this will be worse when the tank is almost empty.
Posted on May 28, 2010
  • 24 Answers
This is normal. As gases expand, they get cooler, and the faster they expand, the greater the cooling effect. If you run the stove with all burners going full blast, you'll get the greatest chilling effect, and under certain conditions frost may even form on the cylinder and regulator, such as on a cold, damp morning.
Mechanical refrigeration - your home refrigerator and the air conditioner in your car - take advantage of this effect.
Posted on Jan 28, 2013
5 Suggested Answers
SOURCE: Propane tank
yes, you need to buy an accessory cord that connects your tank to the regulator
Posted on Jul 17, 2008
  • 89 Answers
SOURCE: Coleman propane stove problem
john about every coleman stove ive ever had is like that. the purpose of it is to keep the burner closest to fuel tank cooler to avoid heating up fuel tank.cook on one warm on the other hope this helps you out
Posted on Aug 23, 2008
  • 3 Answers
SOURCE: coleman instastart propane stove regulator wanted
Check to see if Coleman has an attachment to replace the regulator, so that you can use a five gallon cylinder with your stove and your own regulator.
Posted on Jun 29, 2008
SOURCE: Black soot on Coleman propane burner
Had same problem. Coleman tech support said, " clean with pipe cleaners". No directions....I would think they would provide a step by step protocol. So, I chose to take the knobs off and use the pipe cleaner where I could. I was able to take one of the two burner control knobs apart. After sticking the clean in every nook I could find, I put back together, and the flame on that burner is back to normal,
Good Luck--Daryl in Burnsville, MN
Posted on Oct 25, 2009
How do you connect the propane to the stove
Assuming you are referring to the Coleman Campers Grill Stove which is a side by side grill and stove unit than it is a pretty simple set up. All portable Coleman stoves set up basically the same. There should be a arm known as a regulator that came with the stove. The narrow end of this attaches to the right side of the stove and screws in. Then the propane bottle screws into the other larger end. make sure all connections are screwed together tightly. For more clarification check out these instructions:
http://www.ehow.com/how_2106008_use-coleman-stove.html
https://www.youtube.com/watch?v=dbYil-YQ8-Y
Good Luck!
Jul 07, 2014 | Coleman Campers Grill
Can I buy a replacement grill?
You could try Coleman, they might be able to supply one.
The Coleman Company, Inc.
3600 North Hydraulic
Wichita, KS 67219
1-800-835-3278
TDD:316-832-8707
Jul 03, 2014 | Coleman Vintage Bernzomatic Deluxe Propane...
Need hose&tanks for model TX850
You could try Coleman directly.
Wichita, KS 67219
1-800-835-3278
Feb 23, 2014 | Coleman Vintage Bernzomatic Deluxe Propane...
Can a 20lb tank be hooked up to a Coleman 2 Burner Stove 5430A
Yes. There are multiple adapters made to fit this application. Your local walmart most likely will have them. http://www.walmart.com/ip/Coleman-5-High-Pressure-Propane-Hose-and-Adapter/19897422
Sep 18, 2013 | Coleman 2 Burner Propane Stove 5430E700
Coleman 5423b701
Try Coleman directly.
Wichita, KS 67219
1-800-835-3278
Sep 01, 2013 | Coleman Camping Stove 2 Burner Propane W/...
Connect propane to stove for popup
Try canadian tire they sell these hoses take it with you as a guide
Feb 13, 2012 | Coleman Grilling
Why does my coleman stove regulator leak gas from the hole on the top of the regulator
Its a safety feature of the regulator. The regulator is designed with a pressure release valve. This has happened to me twice: once with a carbon dioxide tank for my kegerator and once on my propane stove. In both cases I left the regulator (designed with a max pressure rating of X psi) attached to a full bottle in the sun. The heat caused the pressure to exceed the limit of the regulator and the release valve popped. A welding supply store may be able to reset/replace the mechanism but in my case I just bought a new regulator for about $15.
Aug 14, 2011 | Coleman 2 Burner Propane Stove 5430E700
Coleman Propane Stove 2 Burner 5430E700
Ho cold waas it out? remember that when its cold out the presswure of the propane tanks are real low and you have to warm them for the pressure to go up. if your by your car then you can place them inside with the heater going till they warm up ofr now worm them up inside first. good luck
Sep 06, 2008 | Coleman Propane Grill Stove 9921-700
Coleman Propane Grill Stove 9921-700 Logo
321 people viewed this question
Top Coleman Grilling Experts
Paul Carew
Charles T Nevin
Charles T Nevin
john h
Are you a Coleman Grilling Expert? Answer questions, earn points and help others
