Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
How to replace an ink cartridge on Epson Dx7400.Cyan has run out TO712.I have lost my user manual and I cannot remember which button to press to get the Printer part to the right spot for changing the cartridge
    Scholar:
  • 94 Answers
On your printer and then click on the start menu goto Printer and Faxes. After that goto your default printer Epson Stylus and right click the printer then click properties. Dialogue box was appear click on the maintenance and then click replace cartridge their was dialogue box will also appear. Just click the next button and read the instruction when you press the Next button. After that open the cover of your printer when the cartridge are at the center thats the time you can change the cartridge. Then close the cover when your finished to change the cartridge. Then click the next button and so on to finished.
Posted on May 28, 2010
Testimonial: "Thank you for such a speedy reply.Your instructions are superb.Very clearly written and easy to understand.how lucky we are to be in touch with clever people like you.Thank you Works a treat"
Can you tell me how to change ink on an epson stylus cx400
The Epson Stylus CX6400 is an all-in-one printer that also features a scannermag-glass_10x10.gif for scanning and copying. The Epson CX6400 prints with ink via four separate ink cartridges in black (high or standard capacity), cyan, magenta and yellow. The cartridges sit in slots in a cartridge holder underneath the scanner. As cartridges run low, or cartridge print quality problems arise, ink cartridge replacement become necessary. As each cartridge snaps effortlessly into the cartridge holder, changing cartridges doesn't require much effort beyond unsnapping the old cartridge from the holder and replacing it with a new one. jQuery('.intro .thumbnail').each(function(i,e){ jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); }); }); Instructions
  1. Step 1 Turn on the CX6400.
  2. Step 2 Check the ink levels for each cartridge. Press the "Setup" button to enter the setup mode. Press the topmost button on the left side of the LCD repeatedly until you reach the Ink Levels screen and then press the "Color" button to see the ink level percentages (for example, 0 percent or 50 percent) scroll across the screen for each cartridge (C for cyan, M for magenta, Y for yellow and K for black). Press the "OK" button to exit.
  3. Step 3 Select the empty cartridge or low cartridge option on your printer. If you're dealing with one or more empty cartridges, press the "Color" button. If you've decided to replace low ink cartridges, press the "Setup" button, press the topmost button on the left side of the LCD repeatedly until you reach the Replace Ink screen and then press the "Color" button.
  4. Step 4 Reach into the slots on both sides of the printer under the scanner unit. Lift the scanner unit up carefully to reveal the cartridge holder on the right side of the printer. Lean the scanner back to rest on its hinges.
  5. Step 5 Grip the unhinged end of the cartridge cover near the back of the printer and then pull the cartridge toward you. If this is done correctly, the cover should flip back and hang slightly out from the printer on a hinge.
  6. Step 6 Press your fingertip against the grooved tab on the cartridge that you're changing to unlock the cartridge from the holder. Once it is unlocked, pull the cartridge straight up and out of the printer and set it aside for disposal.
  7. Step 7 Shake the new replacement cartridge in its sealed packaging four to five times using a rapid side-to-side motion and then remove it from the packaging without touching the green circuit boardmag-glass_10x10.gif.
  8. Step 8 Insert the replacement cartridge in the holder and push down on it until you hear the grooved tab click, locking the cartridge in place. Remove and replace any other cartridges as needed.
  9. Step 9 Flip the cartridge cover over the cartridge holder and push down on it to lock it in place. Grasp the sides of the scanner unit and lower it gently into its previous position. Wait for the "Charging" message to disappear from the LCD and then begin printing.
Read more: How To Change Ink Cartridges for an Epson CX6400 | eHow.com http://www.ehow.com/how_6656725_change-ink-cartridges-epson-cx6400.html#ixzz0tZtUa2CB
Jul 04, 2010 | Epson Stylus CX6400 All-In-One InkJet...
How do i install my new ink cartridges in my printer epsom
Be sure you have a new ink cartridge before you begin. Once you start the ink cartridge replacement procedure, you must complete all the steps in one session.
  1. Make sure the EPSON Stylus CX5400 is turned on and not printing. The LCD screen tells you which ink cartridge is low or empty.
  2. If your EPSON Stylus CX5400 is low on ink, press the left Menu button until you see Change Cartridge, then press the Color Copy button.
    If your EPSON Stylus CX5400 is out of ink, press the Color Copy button.
    The ink cartridges move to the replacement position.
  4. Lift up the scanner.
  6. Pinch the tabs on the front and back of the cartridge, lift it out of the printer, and dispose of it carefully.
  8. Before you remove the new cartridge from its package, shake it four or five times.
  10. Unwrap the new ink cartridge and lower it into its holder, then press down on the top of the cartridge until it clicks in place.
  11. Caution: Don't touch the green circuit board on the back of the cartridge; you may inhibit normal operation and printing.
    If you need to replace other ink cartridges, repeat steps 4 through 6 before continuing with step 7.
  12. Carefully lower the scanner and press it down until it clicks into place. The EPSON Stylus CX5400 begins charging the ink delivery system.
  13. The On light flashes and the EPSON Stylus CX5400 makes noise. Charging takes about 30 seconds. When it's finished, the On light stops flashing and stays on.
    Caution: Never turn off the EPSON Stylus CX5400 while the On light is flashing, unless the Stylus CX hasn't moved or made noise for more than 5 minutes.
Oct 27, 2009 | Epson Stylus CX5400 All-In-One InkJet...
How do i eject the ink carrier?
hi there,
  1. Look at the Epson printer's LCD screen to see the ink levels for each cartridge. If your cartridge is completely empty, simply press the "Color" button. If your cartridge has a low ink level, press "Setup". Hold down the button on the upper left side of your LCD screen until the words "Replace Ink" appears, then press the "Color" button.
  2. Wait until you see the words "Open the scanner" on the LCD screen. Then lift open the printer top by pulling up on the side grips next to the scanner unit. Make sure that the scanner lid remains closed. The ink cartridge holder should move to the far right of the printer.
  3. After the cartridges have completely stopped moving, pull the cover of the ink cartridge holder up and toward you. Press in the tab of the cartridge you need to replace. Lift the cartridge straight up to pull it out of the holder.
  4. Unwrap the replacement cartridge and insert it securely into the holder. Press straight down until the cartridge snaps into place.
  5. Close the cartridge holder cover and make sure it clicks into place. Close the scanner unit and wait while the printer charges the new replacement cartridge. Wait until the word "Charging" disappears from the LCD screen before using your printer.
Do not turn off your Epson printer while the "Charging" message is still on the LCD screen because this may cause your inks to not fully charge. Turn off your printer only if there has been no response for over five minutes.
Clean up any ink spills with soap and warm water.
Replacement ink cartridge: Black (T048120); Cyan (T048220); Magenta (T048320); Yellow (T048420); Light Cyan (T048520); or Light Magenta (T048620)
Hope this initial info/idea helps.
Let me know for further instructions.
Thanks
Apr 29, 2009 | Epson Stylus RX500 All-In-One InkJet...
How do I make the cartridge move to change position on Epson C44 Plus
To replace an ink cartridge using the maintenance button, follow these steps. Turn the printer on, the power light should be on and not flashing.
Open the printer cover. Press the maintenance button (ink-drop symbol). The print head moves to the black ink cartridge replacement position first. Press the maintenance button again to switch to the color cartridge replacement position.
The on-line user guide can be found here:
http://esupport.epson-europe.com/ProductHome.aspx?lng=en-GB&data=FGQ8MBMpKlvPPGPcU002FJ8CcV1DwZfroADi&tc=5
Please take a moment to rate this solution, thanks.
Apr 17, 2009 | Office Equipment & Supplies
Epson dx7400 printing green
one of your people advised me that it was most likley a bad cartridge i changed it and it worked ,thanks
Feb 04, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Epson printer: print head not moving to replacement position
Click on Epson, then Monitor status then Properties then replacement. A page will come up saying To get carriage into position click O.K. on this page. When you do that the carriage moves into position and you can take out the old cartridges and replace them
Jan 17, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Epson Stylus DX7400 - Ink cartriges
Lift the scanner up to expose the inside of the printer. Thers a button "stop" top left face of printer, press and release and the print cartridge holder will move, press again and it will stop at the colour that needs replacing, press again (total four times) to show if other cartridges are ok. Press again and the cartridge carrier will return to right of the machine. Lift the lid (grey colour) to show the cartridges, remove and replace the ones that have been shown to be empty. Close the lid, it should click. Close the scanner down again. Press "start" to recharge the cartridge. ANy other problems try the epson support site. Good luck.
Aug 31, 2008 | Epson Stylus C86 InkJet Printer
Cyan will not print
Try replacing the cartridge. Sometimes they do get clogged and won't clear no matter how many cleaning cycles you run.
....John
Mar 07, 2008 | Epson Stylus Photo R1800 InkJet Printer
Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
464 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
