Question about Kohler Toilet - One Piece with Ingenium Flushing System - San Raphael by
Hi we have 2 Kohler toilets with The ingenium fluishing system. There is a polished trip lever externally. Internally there are 2 plastic lever atached the the plus by a chain. On one toilet the chain has snapped and causes the ring to stick leaving the drain permanently open and the cistern leaking. There is no distributor in Australia who has a replacement part for this particular toilet system. Can you help me. Kind Regards Pauline Hogg. Newcastle Australia
  • 12,061 Answers
Ok, you simply need to get another, any other length of chain, say like a Sink plug chain, any chain, will work. and attach it however you can. Binding, Glue, whatever it takes. It's only a method of attachment, one can even use a length or strong Copper Wire. As long as you can make it "Connect" with each end. it is NOT critical, in it's action. or how it is attached. As related as long as you can get it to function, it is really irrelevant, what you use, or how you attach it. As long as it works, you can use whatever it take to do so. So now, go forth and fix your cistern...
Posted on May 28, 2010
Kohler toilet troubles
The holes around the inside of the bowl may be clogged, try using some CRL and scrubbing the holes with a good stiff brush.
Apr 09, 2014 | Kohler Toilet - One Piece with Ingenium...
Ingenium toilet water will not turn off. The float is completely under water and still water is coming into the tank.
WEll, two thoughts come to mind. either your float has "sunk" or you have foreign matter in the inlet valve...Typically, you replace the inlet valve in this case.
Jul 18, 2011 | Kohler Toilet - One Piece with Ingenium...
After flushing the toliet makes a humming sound.
you have to turn the lever or knob in the reverse direction to plug the hole properly, the noise would go away.
Mar 19, 2011 | Kohler Toilet - One Piece with Ingenium...
Float does not trigger valve to stop water - continues to run even though tank is full
What kind of flush valve is it? kohler.com shows a couple of different towers with their ingenium toilets. Is it a Kohler item or is it a Fluidmaster?
Usually you adjust water height by turning a threaded rod that runs up and down. See page 5 of this pdf
http://www.plumbersurplus.com/pdf/1058802_2.pdf
Jan 29, 2011 | Kohler Toilet - One Piece with Ingenium...
Leaky fill valve
try phone 1-800- kohler warrany toilet
Jan 19, 2011 | Kohler Toilet - One Piece with Ingenium...
Plastic piece at top of tank spraying water after flushing all out of tank and everywhere! How do I repair or what can I do??
look at the bottom of the system there will be a small plastic U-bend about 1.5 inch long by about 1/2 inch widethat has dropped off silply insert it into the top of the system where the water is coming out of and push firmly.
Apr 24, 2010 | Kohler Toilet - One Piece with Ingenium...
Kohler Toilet year old do not have flapper. It has stright pipe
This is how it is meant to work!
Short push of lever for small flush, push and hold lever for full flush.
Aug 16, 2009 | Kohler Toilet - One Piece with Ingenium...
Toilet fill runs periodically works well but wastes water
Sounds like your flapper is leaking causing the water in the tank to lower until it triggers the fill valve. Replace the flapper (they're cheap and wear out easily).
Jul 03, 2009 | Kohler Toilet - One Piece with Ingenium...
How do you get the top plastic cap off the Kohler Ingenium flush
My Kohler Ingenium has no pins. The white cap is attached to the grey lever which must be lifted up before twisting both one-eighth turn counter-clockwise, and lifting off of fill tube. Turn the water supply back on and flush the tube out (cover with cup first!). Use a thin wire rod about 12" long to gently poke down into fill tube to clear any clogs. Also check where the small flexible fill tube exits from the main fill tube. Reassemble and cross your fingers.
Mar 26, 2009 | Kohler Toilet - One Piece with Ingenium...
Kohler Toilet - One Piece with Ingenium Flushing System - San Raphael by Logo
109 people viewed this question
Top Kohler Home Experts
Donni Steen
john h
Tim Whalen
Are you a Kohler Home Expert? Answer questions, earn points and help others
