Question about Dell E172FP 17" LCD Flat Panel Monitor
No power green light will not come on. checked all power cables. pc comes on fine. its about 18 mos. old. no problems before this
  • 472 Answers
In general the power problem you have is related to bad capacitors in the power supply. It is an easy fix if you are confident around electronics.
If not, your local tv repair shop should be able to do it for a reasonable fee.
Please be aware that voltages inside LCD monitors go far above what comes from your wall socket.
Posted on Apr 08, 2008
SOURCE:
A computer with a D101GGC motherboard does not start. There is no beep or monitor singal. The fan is okay. As soon as the power is connected to the computer, the red drive access light comes on, but not...
its a common problem with intel D101GGC motherboard, just open the case and unplug the dvd power cable and data cable, then turn on the PC it will work fine.
Jan 09, 2011 | Intel D101GGC Motherboard
Red power light, green wireless light, no internet access. Have done the reset and the power off. Nothing works.
I had the same problem on the Gateway 2701HG-B supplied from ATT. From searching the web, I learned these variety of modems apparently have an expiration date on the power cord at abotu 18 mos to 2 years. Mine is almost exactly at 2 yrs.
I replaced the power cord and now it works fine. You can order the OEM replacement from att e-store or try Radio Shack for a universal cord.
May 24, 2010 | 2wire (1000-000057-000) Modem
My 2wire has the power light red and the ethernet green and th wireless solid green and the dsl off and the internet off....what can i do
I had the same problem on the Gateway 2701HG-B supplied from ATT for use with their DSL service. From searching the web, I learned these variety of modems apparently have an expiration date on the power cord at about 18 mos to 2 years. Mine is almost exactly at 2 yrs.
May 20, 2010 | 2wire (1000-000057-000) Modem
(1000-000057-000) Modem: Modem will not turn all the green lights on...
I had the same problem on the Gateway 2701HG-B supplied from ATT for use with their DSL service. From searching the web, I learned these variety of modems apparently have an expiration date on the power cord at abotu 18 mos to 2 years. Mine is almost exactly at 2 yrs.
May 18, 2010 | 2wire (1000-000057-000) Modem
New TV 9 mos old, Won't stay on after power up? Remote or manual turn on, set keeps turning off after 1-2 second green on and brief screen flash.
I would try leaving the TV unplugged for 30mins so the TV can reset itself.
If that doesn't work, your TV should still be under warranty. I know 95% of come with a 1 year warranty.
The most common problem with Sylvania TVs made by FUNAI, the Backlight Inverter board fails to early in life. ( That's the part that powers the screen)
The Tv can't power up the screen and it turns off automatically. Basically called "Protection Mode" so it protects the other parts inside the TV.
Jun 01, 2009 | Sylvania LC320SS8 32 in. LCD Television
1996 Sebring died-but flashing light & ticking from steering col.
If your battery cables are corroded, I'm talking inside the casing , your battery is running the car and not getting much charge back from the alternator. The least expensive, but time consuming thing to do is replace both battery cables. Try this before any major repairs.
May 29, 2009 | 1996 Chrysler Sebring
Monitor problem
Hi...there,
It's turns blue to power safe mode (yellow) it's prevent futher damaged to your monitor. It's seems you got a busted backlight inverter. Need to replaced a new one...Since you only got it for a few months, send it back to Acer for a replacement of a new backlight inverter... Have a nice day!
Oct 17, 2008 | Acer AL1916W 19" LCD Monitor
Remotes no longer work
I had this exact same problem. After a week or so it started responding to the remote control again. Then after a couple of days it stopped responding. This problem came and went for about a month, then one day the entire TV went dead. When I powered it on, the green light appeared for 2 seconds followed by a sequence of 6 flashing red lights that repeated. I brought my set in to a repair shop and they replaced the power supply board. That fixed the problem and now the TV powers up and responds to the remote control again. Total charge was $250. That was very disappointing for a $1,500 TV that was only 18 months old. I'm going to let Philips know how disappointed I am in their product!
May 28, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
Monitor keeps blank even the power lLED is on green
Try replacin a new display card. If it is fine working.ok
If not try fixing for cold solder in the video section.
I suggest video section according your report the light green LED lighted that shows the power section is doing fine.
Apr 22, 2008 | Proview PL913S 19" Flat Panel LCD Monitor
Dell E172FP 17" LCD Flat Panel Monitor Logo
Ekse
Clive
Clive
Alun Cox
