Have a Imagistic tm020 it is also a imagistic model df360 same maching, Moved it from office to home turned it on and all I get now is malfunction detected call for service cof32,,help I use this for prison ministry
  • 4,924 Answers
Just reset the printer ..and reinstall the driver for it ...be sure that the driver is the one that requires for teh operating system that you use..and it is well powered when installed ..and on ..after that it has to work ..
if it is a model that has a screen and menu ..look in the menu for reset settings ...with the arrows select one by one functions and devices..like drum and counter ..and reset them ..
Also you can check before doing all that if it all ok inside..( I think maybe there is something out of place during the moving ) ..check to be aligned..and the ink in place , than reset it ..and restart ..install the driver and it has to work if it is functional ..
Posted on May 28, 2010
  • 1 more comment
  • cchavers May 28, 2010
    When I turn copier on after warming up it beeps then I get Malfunction detected-call for service
    code COF32 I am not able to go to any resets. Have checked to see if everything is in tight nothing
    loose....
  • Catalin Turcu
    Catalin Turcu May 28, 2010
    this is a drum issue error code..and probably you will have to replace it ...just see on the internet cause they are available for all models...and pretty easy to change or ..just buy it and have someone to install it ..also you may want to get the unit with the developer also if you change it ...The issue is the drum counter sould be reset or it is beyond physical life ...if you ca not get into any of the menu to reset it ..than try to general reset by keeping down a few seconds (10) the button when you power it up...if it doesnt work than you should replace it ..Normally if it is a reset issue it should let you in the menu and look on the main menu ...reset settings ..drum counter reset..something like that ..and if you can reset will work a while until replaced..if not ..just replace it ..
  • Catalin Turcu
    bythe way ..cause it worked fine ...remove the drum and reinsert it ..I guess it may be the issue there ..and try to reset it after ...
Error code C0110 on imagistics copy machine which model number is C650
The only reference to that particular code is:
C011
Backup memory problem
Problem with thebackup memorydata.Defective backup ram.
Jan 21, 2013 | Pitney Bowes 460-4 Toner for Imagistics...
Reset Imagistic 2700 Drum Counter
Try this:
http://www.shopping.com/imagistics-ix2600-drum-counter-reset/products?sb=1
Please rate my solution.
Thanks for using FixYa.
Jun 23, 2011 | Computers & Internet
Codigo de falla CO500 en imagistic modelo 2520
la fotocopiadora presenta una averia y me sale cod c0500... quiero saber como puedo solucionarlo
Jan 30, 2011 | Office Equipment & Supplies
How to reset malfunction code C0500 of a imagistic im2020 copier
On the side of the control panel, there is a little hole, use a paper clip unbent to press the switch inside hole. The touch screen will restart. watch the left hand side 2/3 up, a little dot will appear, when it does, press 3. The login in is all zeroes. press trouble reset and then turn off and on using the switch at the left side, lower back edge of machine.
Nov 06, 2009 | Office Equipment & Supplies
Imagistics Error Code C-0B77
May want to check the stapling unit and hole punch. To reset open close front door. After openclosing finisher door
Jul 03, 2009 | Office Equipment & Supplies
IMAGISTICS 2620 Error code C0500
Feb 03, 2009 | Konica Minolta DiALTA Di200 Copier
Imagistic 2500 Fax problem.
On top of the toner cartridge there may be a blue slider for cleaning the charge wire.
If not, you have a bad toner cartridge (drum cleaning blade)
Sep 16, 2008 | Brother MFC-8220 Fax
Df-3035 copier
Hello flyersgirl68,
I truly wish I could help you. But , you would not believe how helpful it would be if I knew what brand copier you have. Canon makes a 3035 copier but they have no error codes that start with f. Mita "MADE" a copier (1986) that had an "f" in their error codes that indicated the feeder had a problem. I guess we might want to narrow it down a tad. Is your machine a ...........canon,olivetti,mita,ricoh,savin,oce,kodak,xerox,minolta,konica,nashua,pitney bose,danka,savin,gestetner,monroe,ibm,imagistic,panasonic,toshiba,lanier,brother,riso,......etc....
Apr 18, 2008 | Office Equipment & Supplies
Imagistic 3510/ sharp 350 scan
yes we have the product key for some units that serial numbers don't match.
we did not swap out the board in the scanner.
yes we know how to reset the hard counter.
what I'm being told by other boards I belong to is it's pretty hard to get around not buying another scanner kit. These machine come ready to scan if it has a nick card, but you have to spend another 400.00 if you want it to do it. I would be glad to pay a reasonable price for a trick around this.
Mar 18, 2008 | Office Equipment & Supplies
Key stick
okay first thing you want to do is unplug machine, get some rubbing alcohol and an old tooth brush. then dip the brush into alcohol do not make it too wet and brush the edges of the keys as well as you can. If that doesn't work then you need to take the control panel appart and remove the board from the plastic panel and wipe with alcohol and rag/brush. BE SURE TO THOROUGHLY DRY BEFORE PLUGGING IN POWER CORD.
Mar 15, 2008 | Office Equipment & Supplies
k24674
