Question about GE Spacemaker JVM1640SJ Microwave Oven
I have a GE Spacemaker microwave JVM1430BD002 There's a circular panel inside on the upper surface that's all greasy around the edges. It has arrows with 'open' close' on it but I can't get it to move. I'm afraid of breaking it. Does anyone know what this is and how I might get the panel off for cleaning?
  • GE Master
  • 9,047 Answers
That's the stirrer cover. It does need to removed and cleaned, and the stirrer parts above it, too. so that the grease will not eventually cause arcing and damage.
Your owner's manual should cover that. If you've misplaced yours, you can download GE owner's manuals and installation instructions here.
We're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer
Posted on May 28, 2010
Testimonial: "Great information, thanks!"
  • kari77kari Feb 03, 2013
    I still can't find out how to open the stirrer cover. Where is exactly in the manual? The grease keeps coming down.
I need to install my GE Spacemaker model # JVM1430BD002
You can download GE owner's manuals and installation instructions here.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Oct 16, 2011 | GE JVM1430 Microwave Oven
Where is the light that is inside the GE Spacemaker microwave?
with cord unplugged you can remove the main control panel and access to it
Aug 02, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Model is GE JVM1430BD002. Microwave works but range fan and lights do not. Unit "popped" when fan was turned on one time and hasn't worked since. Is there a fuse or breaker for the range hood functions?
Yes - there is an internal "special" in-line fuse. Most likely it is the fan that has caused it. Clean the fan with switch-cleaner spray and make sure it is smooth running. Replace special fuse with identical version.
Check lights before operation.
Replace all covers before test.
Oct 10, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
A piece of waxed paper caught fire and melted a 1/4" hole in top of microwave.
I assume you mean the interior of the oven.
Epoxy is available in white (I don't know if in both quick & regular versions however) and I suggest you trim and fill the hole so its edges are flush with the surrounding plastic. Mix the two component epoxy, use duct tape or similar and if a quick-set type of epoxy, I would put a generous blob in the middle of a length of tape, allow it to start setting up (should still be very pliable) and put the tape over the hole, pressing it firmly into it to ensure that some material flows inside around the edges to secure it. Make sure the epoxy has NO metallic content as this would worsen your problem. If done well, the new plug should be quite level to the surrounding surface.
Aug 08, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
My GE Spacemaker XL 1800 was working fine and
check fuse inside unit microwave has a fuse around 15 to 25 amps get at local hard ware store u should discharge capacitor before installing fuse not nessary in microwave
Jul 25, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Where is serial number located on GE Spacesaver?
If you open door and look at upper edge of cabinet it should be there.
Apr 22, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
My Ge SpaceMaker XL1800 Microwave Oven won't power on any more.
1.Check power outlet for working.
2.If it is than you have broken fuse inside the m/w.
3. To change the fuse you have to disconnect the power to m/w, take the upper grill off, take the screw on top of control panel, lift the control panel up and removed. The 20 Am fuse located behind this panel.
Dec 15, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
628 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
