Question about LG KU990 Viewty
Screen says insert sim card when the sim is fitted correctly.this phone worked ok for 6wks . i have tried the sim in an other similar phone and it works ok ,i have tried a different sim with same results phone is a lg ku990
    Scholar:
  • 94 Answers
Your phone are not open line. That was only one network can be used. You are exclusive on that netword only.
Posted on May 28, 2010
Insert sim card
Do you want to insert other network sim or if your Blackberry Curve 8350I displaying insert sim card,if already sim card inserted.Don't worry i will help you.You can insert other network sim card in the phone by unlocking the phone from current network lock.To unlock Blackberry Curve 8350I use unlock code.Visit the site Wickedunlock.com get unlock code and unlock it easily.Then insert any GSM network sim card.If the phone displays insert sim card even though sim card is already in the phone.Please remove the sim card and replace it correctly.It is because the phone didn't detect the sim correctly.After inserting if it is display invalid sim or sim not valid message on the screen.It is locked to some network,you need to unlock it.To unlock use unlock code.Get code from online site and unlock it.
Jul 30, 2013 | Blackberry Curve 8350i
Nokia 7230 is shutting down when a sim card insert
Hi.Is your sim card is OK ? Before you contact mobile repairing shop try to insert other sim card.Sometimes if the chip inside the sim card is damage the similar problem happened.Good luck.Thanks for visiting fixya
Feb 21, 2012 | Nokia 7230 Cell Phone
My phone is displaying insert sim card even if i fit the sim card correctly
Try removing the sim card then cleaning the golden plated are on it. You can also clean the area where you place the sim card in your phone just in case. Afterwards just place it back in and try turning on your phone.
Jun 13, 2011 | Cell Phones
My phone shows "please insert
You could try to remove your sim card.
Install battery and turn on phone without sim card.
Use phone without sim card and do some operations.
This will check if you phone is working correctly.
Turn phone off and install sim card.
Made sure sim card is install correctly.
If this does not work, it could be the sim card is bad.
Jan 15, 2011 | Cell Phones
Phone says insert sim card with sim card already inserted
First, make sure you have the SIM inserted in the phone correctly. If you do - and the phone still doesn't recognize the SIM card - you may need to replace the SIM card.
This is a common problem with some phones especially when the SIM has been transferred from one phone to another.
Just about the only way to correct it is to replace the SIM card with a new one.
You can purchase one on eBay for a few dollars instead of paying $25 at a retail outlet. Once you receive it, carefully pop it out of the card it is attached to and correctly insert it into your phone.
Put in your battery and turn your phone ON. You should see a 'No Service' message on the screen. If you do, then your phone can now recognize the new SIM card.
Look on the larger card you removed the SIM from and get the SIM number from the card. Then call your service provider and inform them you have replaced a defective SIM card with a new one in your phone. Give them the new SIM card number and in less than 1-minute your phone will be working again.
When it does, the message on the screen will change from 'No Service' to the name of your cellular provider.
Mar 29, 2010 | Samsung Beat SGH-T539 Cellular Phone
IT SAY SIM LOCK AND ASKING THE CODE
This may not work on all Samsung phones!
THIS IS THE TEMP UNLOCK CODE FOR A SAMSUNG PHONE
Do this at your own risk:
Instructions
Press *#06# and write down your IMEI
Unlock Codes
Code 1: *2767*688 then your IMEI and then press #
For example *2767*688352708000828246# (Everything before the / for C225)
Code 2: *0141#
Code 3: 00000000 (8 zero's)
Entering the Codes
1. Switch your phone off. Remove the original SIM card 2. Insert another SIM card from an alternative network. Power up your phone. You should now see the "Wrong Card" message. 3. Type Code 1 into your phone, if this is entered correctly your
phone screen should now turn black and reboot itself. (C225 doesn't go
black but does reboot) 4. After the phone reboots the SIM card will be recognized and your
SIM will work. Be patient while your phone reboots and DO NOT press
any keys. At this point the phone is "Temporarily" unlocked.
5. Now at your idle screen type in Code 2 (*0141#) and hit the call button.
This should give you a message saying the phone is "Personalized". 6. Power off the phone and insert the original SIM, then power up. 7. At the SIM code prompt, it will ask you to enter a password. At
this stage enter Code 3. 8. After entering hit "OK" and your phone should complete initialization.
[/b]Instructions[/b]
Unlock Codes
Code 2: *0141#
Entering the Codes
any keys. At this point the phone is "Temporarily" unlocked. 5. Now at your idle screen type in Code 2 (*0141#) and hit the call button.
Your phone is now Permanently unlocked.
Another easy way is you put in a foreign sim put in the code *2767*2878# much easier and works just the same.
*2767*688 <your IMEI number>
Jan 09, 2010 | Samsung SGH-X820 Phone
Nokia N83 Not Working
Carrier named on SIM card probably not same as Carrier this phone is locked too. If so, get correct carriers Sim Card. Carrier can be seen on powerup splash screen pic. Or, unlock phone.
Sim cards for all carriers can be found on ebay. They are usually pay-as-you-GO phone no contract SIMs. but once you activate SIM, just call carrier and switch your number and/or choose one of their minutes plans. Not problem. They change your number over the wireless, and your contract over the phone..
Mar 02, 2009 | Nokia 3110 Cellular Phone
Phone doesn't recognize the SIM card
The sim card holder has a tiny slide mechanism. After inserting the sim card and pressing it against the body of the phone, place your finger over the card and slide it gently forward. The tiny plastic part that holds the card will snap it into place. Hard to explain, but it will work.
Dec 17, 2007 | Motorola Mobility V66 Cellular Phone
Problem no sim card inserted
try to clean the contacts of your sim-card and also on your phone
if not see if your sim-card bends a little try to flatten it. ok...
peace!
Dec 01, 2007 | Nokia 8801 Cellular Phone
LG KU990 Viewty Logo
264 people viewed this question
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
