Question about Fisher and Paykel Washing Machines
My Fisher & Pykel GW712 won't drain and has burning smell
    Brigadier General:
  • 4,090 Answers
My general feelingf about F&P appliances that smell of burning is to advise pouring fuel over it and putting it to rest for ever!.
I suspect that your pump is jammed, so you will need to get into it and remove the inlet hose to the pump and fish out the item causing the blockage. This unit should have had a strainer over the outlet, but one gets what they pay for in quality not nessecarily the price they pay.
please rate my help++++Thanks for using FIXYA
Posted on May 28, 2010
I have a Fisher & Paykel GW712 (approx 2003), will work up until the first orange rinse light. It does a small drain but then the 3rd, 6th & 8th lights come on (left to right) & it beeps continuously.
thats an error code for the drain pump, if it drains a bit of water then stops the drain pump is faulty (usually overheating coils from corrosion especially if you get a hot metal smell when it happens) dont keep doing it as it has tendency to blow the control board, you will need to replace the drain pump
Feb 04, 2017 | Fisher Washing Machines
Washes then does not empty and spin
It has to drain first before it can spin. Put it on final spin & press start. If you can hear a humming noise that will be the drain pump trying to go. It will have a blockage.
Apr 02, 2016 | Fisher and Paykel Washing Machines
Intermittent Draining and Burning Smell
The water will not run in the machine.It will for a few second then stops. What could be the problem?
Aug 15, 2012 | Fisher and Paykel GWL11 Top Load Washer
Fisher and pykel EcoSmart won't start
You can find a service manual at the link below to assist in repairing your machine.
Download the smart drive mw511 manual
Link:
Mar 10, 2012 | Fisher and Paykel GWL11 Top Load Washer
MY FISHER AND PAYEL GW 712 WASHING MEACHAINE IS NOT SPINNING AT ALL
I have a Fisher & Paykel GW712 and had same problem and fixed it today the drain pump motor had failed although it worked for 1 full cycle. when I tried to wash a second load the water would not completly clear from the machine I finally replaced the pump and now works correctly the pump is easy to install ensure machine is disconnected from power first
Mar 27, 2011 | Fisher and Paykel (IWL12)
Water not pumping out F&P GW712
If you can hear your pump running then your drain hose might be clogged, if not it is probably the pump and will need more in depth troubleshooting.
Oct 25, 2009 | Fisher Washing Machines
Fisher & Paykel washer GW712 won't spin
There is an issue with your drainage area. Best to remove the pump and check for the obstruction in the line or at the impellar.(If the water is not completely drained, the pressure switch wont send a low level to the timer to allow a spin).
Sep 14, 2009 | Fisher Washing Machines
Washing Machines Logo
169 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Gerry Harvey
Gerry Harvey
michael_t919
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
