Emerson MW8107WA Microwave Oven Logo
Posted on May 28, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Power Setting how do I set the power to a "medium" setting?
William Miller
Level 3:
  • Emerson Master 9,179 Answers
  • Posted on May 30, 2010
William Miller
Emerson Master
Level 3:
Answers
9179
Questions
Helped
4481621
Points
21747
It depends on the brand and model, but usually it's something like:
Cook Time > 2 > 0 > 0 > Power > 4 > Start, where 4 is 40%, 5 is 50%, etc.
How do i change the power setting on a Sharp carousel microwave
Which model of Sharp microwave do you have?
For the SMC1441CB, after setting the cook time, press the power level button and then the appropriate digits for the percentage of full power to use. For full power, press power level then 1 and then 0. For 50% power, press power level then press 5.
For the SMC0710BB, after setting the cook time, press the Power button until you see the desired power level displayed on the LCD screen. Press Power once to get 100% power. Press Power 6 times to get 50% power.
For the R-659YW, you set the power before setting the cooking time. You press the Power button several times to get to the desired power level. Pressing Power 7 times will have the microwave cook with 40% of its full power level.
Many current Sharp appliance manuals are available on their product page or the Sharp support page. The current Sharp microwaves are listed here: http://www.sharpusa.com/ForHome/HomeAppliances/Microwaves/Models.aspx?facet:configurationfilter=Countertop . Other appliance manuals are available when you enter the model number in the search bar at http://www.sharpusa.com/Support.aspx .
I hope this helps.
Can't determine high or low on power control
put a cup of water in the cavity and set for 1 minute, after which time you can feel the temperature. Switch to the other power setting and repeat with a fresh cup of water. This will either be hotter than the first or much cooler. Most microwaves use 100% power for full and 30% power for defrost, with 50% usually being lower or medium power. Straight-forward physics. The more power the hotter the water becomes. Hope that helps.
2helpful
What is the highest power setting? choices are low, defrost, medium, roast and reheat. no high???
Most microwaves run high at default, if roast and reheat are given that is your high setting, take one cup of water and run for 1 minute in each setting, the water that is the hottest is the high setting.
4helpful
I have never used the power feature and now I need to and cant find manual. How does the power feature work. I need to operate the microwave on medium power for one minute.
1 Use the number buttons to set a cooking
time. You can set a time from one second to
99 minutes, 99 seconds. To set a time over
one minute, enter the seconds too. For
example, to set 20 minutes, enter 2, 0, 0, 0 .
2 If you want to set the power level to
something other than High, press the Power
Level button, then use the number buttons
to enter a power level.
Power Levels:
Level Cooking PL
1Warm10
2Low20
3 Defrost 30
4Medium Low40
5Medium50
6 Simmer 60
7 Medium High 70
8 Reheat 80
9 Saute 90
10 High Hi
Hope that helps.
Takes about 35 mins to get water to start to boil
Check your power setting. If it has been set lower, it will take longer to cook. Normally, the max power setting is used unless a recipe calls for a lower setting. Normally, the setting is at 10.
Best regards, --W/D--
1helpful
I have SUNBEAM microwave, model SM0701A7E--how do I set the power to MEDIUM? Thank you.
After a long search and reading I finally got it. To adjust power level follow these instructions:
1. Set timer for amount of minutes you want.
2. Hit "power" button"
3. Change the power from 100% to another percentage by hitting numbers 1-9
4. Press Start
3helpful
How do I set the power on my microwave to a "medium" setting, for example? (I have the Emerson MW8107WA.)
Here is the owner's manual for your model and it will tell you exactly how to change your power settings:
http://www.fixya.com/support/p113437-emerson_mw8107wa_1000_watts_microwave/manual-11318
Power setting, whirlpool microwave
My Whirlpool MD 377 is not headting. The light inside is blinking when open the door.
Top Emerson Microwave Ovens Experts
ZJ Limited
ZJ Limited
Paul Bade
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
