Question about Max-Fridge STC55926 / STC55927 / STC55928 / STC55929 Beverage Cooler
Hello there fridge keeps tripping power every time i switch it on
If random then the compressor has earth leakage when under load. Compressor is faulty. If water flow is disrupted and water filter light comes on for replacement for ice maker/cold water then this can cause an earth leak that will trip the rcd
Posted on Mar 07, 2011
  • Tokenmint Mar 07, 2011
    When water runs dry and icemaker area freezes solid. Will cause earth leakage and can cause damage to compressor.
    Refrigerator Malfunction Symptoms and Solutions
    Appliance Doesn't Run and Light Doesn't Come On
    No power to fridge? Check that it's plugged in; check circuit breaker.
    Electric cord damaged or loose? Test cord.
    Light Comes on but Appliance Doesn't Run
    Temperature control turned off? Turn on control.
    Compressor overheating? Clean condenser coils.
    Compressor bad? Replace or call service company.
    Condenser fan bad? Replace or call service company.
    Temperature control bad? Test control.
    Defrost timer bad? Test the defrost timer.
    Overload protector bad? Replace or call service company.
    Appliance Starts and Stops Uncharacteristically Quickly
    Quickly Tripping Overload Protector? Check voltage at outlet.
    Compressor bad? Replace or call service company.Condenser coils unclean? Clean condenser coils.
    Appliance Doesn't Cool Properly
    Temperature control set overly high? Lower setting.
    Refrigerator refrigerant leak or contamination? Call service company.
    Door isn't closing completely? Refrigerators are designed to shut automatically from the half-open point. Raise front levelers until this happens.
    Evaporator fan bad? Service, replace or call service company.
    Evaporator clogged with ice? First defrost the refrigerator, then test defrost timer, test defrost limiting switch, and test defrost heater.
    Door seal bad? Test around door by closing the door on a piece of paper. Is there sufficient tension when it's pulled out? If not, replace the gasket.
    Appliance Gets Too Cool
    Temperature control not set high enough? Adjust control.
    Appliance Won't Cycle Off; Keeps Running
    Too much frost built up? Defrost refrigerator.
    If fridge has exposed coils or evaporator plate and they're dirty, clean them with warm soapy water.
Fridge keeps tripping the house surge protector switch what would cause this temp curcuit board has been replaced but it still trips the switch
there is a problem in the wiring insulation of the fridge or moisture in an electrical control of the fridge
get an electrician in to check it out
Feb 17, 2016 | Refrigerators
What would cause my Maytag MSD2432GRW fridge to trip the breaker? I have narrowed it down to either the defrost thermostat, the defrost heater, or the adaptive defrost. How would I check each of these
It is more than likely your power supply that steps down you your 120V to 24V. This is usually located right rear bottom inside of your fridge but locations vary.
Sep 19, 2014 | Maytag Refrigerators
I have a fisher and paykel fridge freezer model e372b my power kept tripping a few days ago and I didn't know why we switched the power box back on and it tripped again we turned it back on and it tripped...
Check the power cord on the fridge to make sure it is not broken or frayed. There is an electrical short somewhere. Check the recepticle that is used for the fridge by plugging something else in it, such as a lamp, to see if the receptacle has a short in it.
Apr 27, 2014 | Refrigerators
Fridge/freezer keeps tripping
Try to plug into different circuit, if it trips that breaker on the board then the appliance is probably at fault.
I must assume that you have not acquired something plugged into the same circuit as the fridge.
Sep 26, 2017 | Beko Refrigerators
Whirlpool fridge freiezer keeps tripping power
Does it run for a while than trip the power or does it trip it as soon as it is turned on?
Jan 30, 2013 | Refrigerators
My fridge is tripping the power out in my house. do i need a new motor?
It might not be the motor, it could even be the door switch, but first unplug the fridge, disconnect the wires from the motor, insulate them, switch on and see if your house power trips out. If the house does not trip out it is the motor. It is still trips out, look at the wires to the switch and the light and also the thermostat. Good luck and remember to unplug the wall socket whenever checking any circuit.
Feb 13, 2011 | Whirlpool Refrigerators
Hi, my fridge freezer keeps making the electric trip out. help!!!
Try this:
Turn your thermostat as warm as it will go, you are trying to isolate the compressor and keep it from turning on. If your fridge has an "off" position, then turn it off. Reset breaker, plug refrigerator back into the outlet. If the fridge trips while "off", then you are likely looking at a damaged cord / wiring.
If the breaker doesn't trip, unplug the fridge, and move the thermostat to the warmest position possible. Plug fridge back in, If the breaker holds, then you are on right track. Slowly move the thermostat to a cooler setting. You want to just reach the point where the compressor tries to start. If breaker holds here, then you are in good shape so far. It indicates a problem with the defrost heater (if equipped), or the ice maker (if equipped). If the breaker trips as soon as the compressor tries to start, your compressor may be damaged (bad and expensive).
Aug 17, 2010 | Refrigerators
Hello, my hotpoint FF187E fridge freezer keeps tripping my electric off, sometimes it will stay on for a couple of days other times it does this straight away, any idears would be appreciated, thanks...
you may have a burned wiring which when wet trips off you electricity. the location may be in front of your unit between the doors if you have a two door fridge. if you have a singole door unit it may be located on lower area of the fridge body which where the water flow down when you have excess water dripping infront of your fridge. those two location are most likely because the wiring installations from thermostat, heater, and ligth are there. ofcourse you have to check first the compressor and it's auxillaries
Jan 13, 2010 | Freezers
The main rcd keeps tripping off round about the same time everyday
do you have a fridge with a defrosting cycle? quite often when a fridge goes into defrosting mode it can dump some voltage to earth which trips the RCD. The other possibility is an electric pump turning on doing the same thing. or it could be a trouble with your power source. if you give me more information i could possibly help you more.
Oct 27, 2009 | Electrical Supplies
Max-Fridge STC55926 / STC55927 / STC55928 / STC55929 Beverage Cooler Logo
434 people viewed this question
Top Max-Fridge Refrigerators Experts
Dan Stewart
Dan Stewart
Level 1 Expert
Tom Chichester
mike simpson
Are you a Max-Fridge Refrigerator Expert? Answer questions, earn points and help others
