Question about Microwave Ovens
I can understand what the range is in a thermostat with the following values: Range: +53 deg F / +17 deg F Differential: 13 deg F But what is the differential
  • Microwave Ovens Master
  • 4,924 Answers
The differential is to take in mind when you need a certain temperature for a job..the actual temperatures that the oven will have ..may be with a 13 F degrees higher or lower from the actual setting ...is specified cause it is not a surgical instrument to be point accurate .. and this is the difference that can be achieved in some cases..-/+13 F
Posted on May 28, 2010
  • Catalin Turcu
    Catalin Turcu May 28, 2010
    if you are not familiar with this system ..the actual difference that will be possible to get between the set temperature and achieved one it about 5 to 7 degrees Celsius so its not something to worry about in cooking ..
Cannot turn microwave off. Help
Only happens when cooking a big pot under the microwave? Hosing thermal fuse / thermostat kicks in to cool the microwave. Is the micro. Installed proper height above the range? Are you using the fan when cooking on the range?
Apr 30, 2016 | LG Microwave Ovens
Microwave fan goes on by itself without burners being on or used
It sounds like you understand that the exhaust fan is SUPPOSED TO come on when the microwave oven gets hot when exposed to the heat of the range below it, since you mentioned that no burners are turned on. So in that case, I'm pretty sure that you have a bad fan thermostat. It's usually located behind the control panel on the bottom (inside bottom) of the microwave floor.
Dec 26, 2014 | Kenmore Microwave Ovens
My microwave oven model 721.85033111 vent fan stays on
You probably have a bad fan thermostat. This thermostat is supposed to turn on the vent fan if the microwave oven gets too hot (caused by cooking too much or having too many burners turned on on the range beneath the microwave oven). It should shut off in about 15 minutes after your turn off the range burners. But if it comes on for no reason, or won't turn off, then You probably have a bad fan thermostat.
Aug 10, 2014 | Kenmore Microwave Ovens
My child lock on my Frigidaire is constantly beeping... The door is not locked but it is beeping...
Hello Shelley, thank you for your inquiry!
I understand your Frigidaire is constantly beeping while they door is unlock, however do you have a range or microwave Frigidaire appliance? The serial tag for a range, which lists your model number, is typically located in the storage drawer, on the right side and the serial tag for a microwave is in the lower left corner as you open the door. With this information I can better address the issue at hand. Thank you!
Oct 22, 2013 | Frigidaire Over-the-Range Microwave
Electric range with es 100/105 electric oven, getting no heat to oven or broiler. how to fix this problem
My lights turn on Range works but the oven and broil doesn't. Is this the relay or the Thermostat??
Jul 16, 2011 | Frigidaire Microwave Ovens
Jenn Air Microwave builtin oven has no display and will not turn on. Had the power to the oven checked and it's ok. The oven stop working when it was on. The oven is 17 years old.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You should check the internal fuse as well as the oven cavity thermostat / thermal cutout and the magnetron's thermostat / thermal cutout.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Aug 23, 2010 | Jenn-Air JMC7000 Microwave Oven
Whirlpool microwave/oven model RM286PXV3
Just so I understand, you replaced the fuse inside the oven? If so, I would suspect a bad thermostat attached to the magnetron. This device interrupts power when the unit gets too hot. I've included a representative photo. After so many years your magnetron may be bad, too. Once you get the oven working, if it cooks and doesn't trip the thermostat again, it may be okay. PLUS - It looks like this model has manual rotary controls. If so, it's common for those to develop bad contacts after so many years. I would consider that my third suspect. Those controls are called the thermostat (not to be confused with other part by that name that I discussed above) and the selector switch. One could easily be bad. You can check part prices at Sears online at http://www3.sears.com (the "3" is supposed to be there) Some other things that can cause a "dead" condition: - bad connections on the small circuit board where the fuse is mounted (if such a board is present) - bad connections in the wiring Good luck.
Nov 04, 2006 | Whirlpool MH1140XM Microwave Oven
Microwave Ovens Logo
20 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
