Question about Mitsubishi WS-65869 65" Rear Projection Television
Need a part DM 935-C9-39001 for a Mitsubishi WS-65869
  • 94 Answers
The part is NLA.
Posted on May 28, 2010
5551355 green light blinking capasitors are bad need to know number on capasitors
well, I fix it my ws-55517 and I changed 4 capasitor from DM Board, numbers :C81..C81a..C82b...C81c....1000ufd,16v,105c
Jun 21, 2014 | Mitsubishi WS-65869 65" Rear Projection...
Mitsubishi WS-65869 TV. I have no power whatsoever
If you do not have the service manual I can get you a link for a free online copy which contains a lot of information for free.
It can be either read or downloaded for free.
May 27, 2012 | Mitsubishi WS-65869 65" Rear Projection...
Blinking green light on my mitsubishi tv....model ws-65869
Replace the Capacitors on the DM board. You can get the WS55859 DM repair kit which covers your model from www.tvrepairworld.com which has the caps and the CD with repair instructions
Jul 14, 2010 | Mitsubishi WS-65869 65" Rear Projection...
Green blinking light following a power outage
I rebuild the DM power supply in these sets with about a 50% success rate. Sometimes changing the 7 1000uf caps on the small power supply in the DM will fix it, you'll also have to solder the small 8 pin ICs as well. Do this carefully as you do not want an accidental bridge. If this does not fix your problem, replace the DM-POWER board not the DM Assembly. It's about a 300 dollar difference. You'll need a mitsubishi authorized service center to order the part for you. Goodluck.
Jul 05, 2010 | Mitsubishi WS-65869 65" Rear Projection...
Have the blinking light of death on my Mitsubishi WS 65869
i would try unplugging the front control panel, it can also lock up the dm board.. i have a bulletin on it.. open up the panel behind the speaker grille and unplug dz connector.. then unplug the tv for 2 minutes, plug it back in and wait 2 minutes, and then try it with the remote. if it works, you'lll just have to go without front buttons.. it could be a dm board but thats rare. maybe he put in the wrong capacitors, he should have used 680uf @ 16v to replace the 1000uf caps
Jun 07, 2010 | Mitsubishi WS-65869 65" Rear Projection...
65869 blinking, Where is this board with the capacitors located ?
Try website like Tvrepairworld.com to buy the kit they'll tell u where it exactly located on the DM power supply board.
May 15, 2010 | Mitsubishi WS-65869 65" Rear Projection...
Not work ws-65869
The DM capacitors need to be replaced. Heres a link to the DM kit for your model which contains the replacement capacitors and instructions with pictures that show how to do the repair.
http://servicemanuals.vstore.ca/product_info.php/pName/v21v19-mitsubishi-dm-repair-kit/cName/repair-kits
Jun 13, 2009 | Mitsubishi WS-65869 65" Rear Projection...
Mts ws 65869
Replace the dm power board . Its inside the metal box on the left (looking at the back with the back removed). p/n 935C986002
Or if you can solder then replace the 7 electrolytic capacitors on the DM power board. value 1000uf16v
Nov 22, 2008 | Mitsubishi WS-65869 65" Rear Projection...
Ws-65869
Existen unos capacitores que con el tiempo fallan y te dan el sintoma que tienes en tu TV. Estos filtros o condensadores estan localizados en la placa DM (Modulo Digital)
Presione Aqui donde se encuentran instrucciones de como y donde se encuentran los filtros.
Las instrucciones estan en Ingles pero hay fotos tambien.
Aug 13, 2008 | Mitsubishi WS-65869 65" Rear Projection...
Blinking green light stays on and TV won't turn on.
Check for open pico fuse in power supply caused by bad convergence I.C.Get pro help-you have a good set to save.Remember--practice visual acuity technique!And,above all else,do no harm!!
Aug 26, 2007 | Mitsubishi WS-65869 65" Rear Projection...
Open Questions:
See all Mitsubishi WS-65869 65" Rear Projection Television Questions
Mitsubishi WS-65869 65" Rear Projection Television Logo
59 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
