Question about LG WFT1071TP Top Load Washer
Manual for LG wd-8016c . cold water is not going into machine
  • 343 Answers
If you have cold water pressure to the machine and the valve filter is clear you probably have a failed cold water inlet valve. Replacing the inlet valve unit should fix the problem....Not unusual. Not a big job........Good luck....Nomess
Posted on Jun 02, 2010
Not sure how the spring goes on lg 8016c washing machine door handle
http://laundry.manualsonline.com/manuals/mfg/lg/lg_washer_product_list.html Go to this sight and find your manual and the directions should be there
May 07, 2011 | Washing Machines
Water will not enter the machine on the cold water setting on my lg priviledge washer dryer combo model wd-3243rhd.i here a humming noise but know water.
I have a similar problem with my LG WD-3245RHD. I had a repairman come out to look at it and he said I needed a new circuit/control board. I have not been able to locate this replacement part to date. RepairClinic.com has one listed, but it is not in stock.
Nov 03, 2010 | LG WD-3243RHD Front Load Washer / Dryer
Where is the lint filter for the LG Intellowasher 7.5kg (model WD-8016C)?
Hi just read your posting.I have worked on these machines before and I don"t recall this model having a lint filter.I know it has a drain pump filter and filters in the inlet hoses.Are you getting a lot of lint on your clothing?I will endeavor to find out definitively whether your model of machine has a lint filter and I will re post the solution.
Sep 18, 2010 | Washing Machines
Door wont open on LG WD-8016C
mine either. The handle seems to break easily. Try getting a butter knife and pushing in from the left hand side, this will undo the latch.
Jan 31, 2010 | LG Washing Machines
I bought my LG Intellowasher WD-8016C second hand and have no manual. Does it need to be washed occasionally with washing sda. There is a bit of mould around the seal. How do I clean this.
Manual suggests Exterior with household detergent. Do not use methylated spirits, diluents or similar products.
For internal, dry around the washer door and run washer through a complete cycle using just hot water... and repeat if needed.
Not sure about mould.... not in manual.
Nov 02, 2009 | LG WD-16115FD Front Load Washer
Top loader door wont open
Something has caused the washer to not release the door. Is there an error code that is flashing (FE?). A locked door can be due to too much water in the basket, suds causing false water detection (should be using HE), or perhaps the drain is clogged.
If you are sure that the water is not going to spill out on floor, then you might be able to get door open by unplugging the unit and waiting a few minutes (mine took an hour) for the electric lock to release.
Sep 15, 2009 | LG WD-16115FD Front Load Washer
Lg washing machine error message
Possible that water solenoid valve died. Unplug the unit to clear error code, and try to fill using only hot water. Try the same procesude using only cold water.
May 02, 2009 | LG Washing Machines
LG WD-8016C Front Load Washer leaks from the bottom
Crawls, usually all leaks are visible. Im surprised the repairman did not actually get to the source of it. Your drain pump sits on the bottom and it possibly could be the filter cap, hoses to the pump or pump itself. Another area to check is the despensor. There are a number of hoses to this which could be leaking. The bellow itself could have a cut in it somewhere along the bottom. I would call the repairman back and have him at least get to the source of the leak...Catriver..post back.
Aug 14, 2006 | LG WD-16115FD Front Load Washer
LG WFT1071TP Top Load Washer Logo
506 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
