Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Rca 56 green light comes on and goes out
  • rmicblack May 03, 2008
    Green power light comes on and goes off 3 times. It will not do anything for about 3 minutes then it will go thru the same cycle again.
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 208 Answers
If the green light comes on and goes off 3 times and then goes off for good you have a problem that will require troubleshooting by a qualified tech and there are several things that cause this unit to go into shut down. None of these issues can be corrected easily.
Posted on Apr 08, 2008
The green power light comes on and then shuts off on It's own, it comes on and goes off again. No sound or video comes through.
If your TV looks 3D, warped, or distorted it likely has a convergenge problem. If however it just looks dull, washed out, redish, or if it looks like objects on the screen have halos the fluid in the lens has soured. You can search google for parts or you can get the parts with repair instructions from sites such as www.TvRepairKits.com
Feb 25, 2011 | RCA HD56W66 56" HDTV
Hi I have a HD56W66 When turned on it has green light for about 5sec. and goes off with a squeal. sometimes the set comes on and stays. any answer? Tom
THe "Squeal" that you have mentioned is caused by a faulty ballast board(lamp driver). Its the board to which the two thick wires go from the lamp. Replacing the part would resolve your problem
Feb 03, 2011 | RCA HD56W66 56" HDTV
I replaced the lamp im my vivitek 56 inch dlp tv. But it still wont turn on. The light goes from green to red and it makes a sort of high pitch sound then stops
my vivitek RP56HD22A 56" dlp tv has a new lamp and will not turn on. when i push the on button is whines and wont come on
May 24, 2010 | Vivitek V37655 56" DLP TV
Screen will not come on
the green light flashing is telling you there is an electronic fault found in the cui and it needs to be looked at
Apr 20, 2010 | RCA HD56W66 56" HDTV
Tv turns on then right back off no pic or sound
It is in shutdown mode. You have an "overvoltage" (regulation) problem or their is a short in one of the many components causing it to be in "over current" mode. Could be as simple as a bad solder connection. This will take someone with some knowledge of the circuits and test equipment to diagnose.
Jun 25, 2009 | RCA HD56W66 56" HDTV
Won't turn on
id be calling the friend asking for a refund...what you have going on is pretty common but did you see it work prior to buying it or just take their word for it? you may have a bad flyback or transformer but it shouldnt be bad so soon after you happened to buy the tv and no it would not have gone bad from moving the tv
Jan 12, 2009 | RCA D56W20 56" Rear Projection Television
56 inch RCA rear proj T.V.
Sounds like the capicator on the high voltage is swelled,removing the back cover,make sure to unplug the unit first,there is a u shaped heat sink about middle ways of the board,inside that heat sink is a cap,it will be swelled on top of it,its a 2200 35v cap.
Jan 05, 2008 | RCA D56W20 56" Rear Projection Television
My tv power won't come on
does a picture come up. from what you have told.. i would think not so. after it goes off does the light flash. this unit has a processor that shut the set down when it "SEE's " a problem..high voltage..crt..theres about 20 to 25 different problems that can cause this.
Dec 09, 2007 | RCA D56W20 56" Rear Projection Television
Rca 56 promblem
Sounds like you have a bad screen asy,this is located under the plastic were the tubes come up thru the plastic,its in the right top corner and has 6 turn controls on it,part number is 204809,this part must be generic,the part has been discontinued by Thomson.
Dec 08, 2007 | RCA P56830BL 56" Rear Projection...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
56 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
