Question about Canon imageCLASS MF5550 All-In-One Laser Printer
Canon MF5550 printer driver for Windows Vista
How can I install Canon imageCLASS MF5550 All-In-One Laser Printer driver on my Windows Vista? There is no support for this driver from Canon.
Thank you
  • 1 more comment
  • silvercircle Jan 11, 2009
    I've tried everones suggestion but can't seem to get it to work.  When I get to step 11 I can't find just the driver.  Vista runs the executable setup file.
    Any suggestions would be greatly appreciated.
    Thanks
  • mjbrooks Jan 23, 2009
    On step 5, I cannot find the "use an older program with this version of Windows".
  • mjbrooks May 11, 2010
    I cannot get it to work following the instructions. Any suggestions?
  • 3 Answers
I just found this solution TODAY! After trying for a whole year to fix this thing... It was right at my face the whole time!!!!
1) Uninstall your old Canon MF5550 driver.
2) Reboot your computer
3) Download the Canon MF5550 driver Windows XP version.
4) Open your Vista Control Panel, then click on PROGRAMS (not on Uninstall or something else...)
5) bellow "Programs & Features", click on "use an older program with this version of Windows". Follow the wizard.
6) Locate the program manually. (If you need to search the folder where you downloaded your Canon driver, just go to search file on C. It will probably download on your desktop or Downloads)
7) Open the MF5550 Folder where you downloaded the driver, and click on the setup.exe file.
8) Choose on the next screen Windows XP
9) If you need to change the display settings, go ahead. But I didn't change anything. I just clicked NEXT.
10) Fill in the box: RUN THIS PROGRAM AS AN ADMINISTRATOR and click NEXT.
11) Click Next again and let Windows Vista do its job.
12) If it worked... just click yes and finish. If it didn't, click NO and run it again.
I AM SO HAPPY THIS THING WORKED!!!
Let me know if this worked for you!!!! I know I've looked everywhere for this solution...
email me at [email protected]
GOOD LUCK! GOD BLESS!
Posted on Apr 14, 2008
I made several attempts that failed. I uninstalled and reinstalled the driver each time. After step 11, prior to testing the program to see whether it works, plug in your printer USB to your Vista computer. You will see the window detecting new hardware, then follow the instructions to install the new driver.
It still took me a couple tries, but finally got to the screen to search the computer for the driver and Vista found the MF5550 driver. I clicked install, and the rest is history!
It works like a charm.
Posted on Dec 19, 2008
  • maaadmoondog Feb 13, 2011
    the problem that people are having is if they have a 64 bit version of vista. you can get away with using the vista 32 bit version, but not the 64. that is the key. if you have a 64 bit version, you're just wasting your time trying to get this printer to work.
Thanks so much. Worked for my Canon MF5750 as well.
In fact, I took it a step further. New Vista drivers could not be installed as Vista stated "older MF drivers are installed and need to be removed" before proceeding. The installation disc was for XP and would not install. For the life of me, I could not find the drivers anywhere and even ran a driver removal program without solution. I followed your instructions to get the old XP drivers reinstalled and then fromally uninstalled them and put on the new Vista supported drivers supplied through Canon's drivers and downloads page. Worked like a charm. Thanks again!
Posted on Jun 25, 2008
Thank you so much ive been looking for this solution for month now thanks again
Posted on May 05, 2008
  • dvdsssss Feb 18, 2011
    Thank You, Thank You, Thank You!
    I kept going back to using XP, as the printer cost me more then the operating system. Also I refuse to buy anymore Canon products as they wouldn't provide any support. I looked for a fix for maybe 3 years and I finally found this.
    One thing I did different was on step 6 - following the wizard it allowed me to install the program from the cd.
    Thank You!!!
SOURCE:
Need to uninstall old mf drivers. how can i do is.
for windows XP....
  1. Click Start, and then click Printers and Faxes.
  2. On the File menu, click Server Properties.
  3. On the Drivers tab, click the printer driver that you want to delete, and then click Remove.
for windows vista or windows 7 it is much more difficult, so i will send you to a webpage with pictures.
http://www.petri.co.il/removing-old-drivers-from-vista-and-windows7.htm
Jan 11, 2011 | Canon imageCLASS MF5550 All-In-One Laser...
Cannot install drivers for Canon MF5550 on Windows 7 64 bit O.S.
Incompatible types and version of printer drivers when installed in Windows 7 can cause issues which might hinder the installation process thereby causing the installed drivers to become corrupt. The users of Windows 7 are therefore advised to verify the version and type of printer drivers before the installation and install only those drivers that are fully compatible with the Windows OS on the system to avoid these kinds of issues.
http://www.makeuseof.com/tag/3-resources-windows-7-printer-drivers-printer-working/
Jan 07, 2011 | Canon imageCLASS MF5550 All-In-One Laser...
Cannot run the Canon MF5550 printer (lack of an appropriate driver) running Windows 7. Any solutions?
Drivers for your printer and operating system can be found here along with Guides and Manuals:
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/imageclass_series/imageclass_mf5550#DriversAndSoftware
Uninstall your old driver; download the new driver for your OS and install.
Trust this is helpful. Please vote. :)
Dec 16, 2010 | Canon imageCLASS MF5550 All-In-One Laser...
I have a canon MF5550 printer that I am trying to use with Windows Vista. There is no compatible printer that I can find. What is recommended?
Canon isn't supporting this printer for Vista. You can try using the driver for XP. Available here: http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/imageclass_series/imageclass_mf5550?selectedName=DriversAndSoftware#DriversAndSoftware
You may need to use the Compatibility Mode on the installer as well as the driver. (Right click on the .exe and select Properties. Then go to the Compatibility Tab and check the box for the Run this program in Compatibility Mode and choose XP in the adjacent drop down.) Then right click again on the .exe and choose Run as Administrator to make sure the UAC allows the installer to work.
I hope this helps.
(a generic printer driver may install when you plug in the printer without installing the software first. If this happened you should uninstall that driver before trying the Canon version. If the Canon driver doesn't work, the generic printer driver in Vista will probably let you print but you may lose the scanner features. Please note that the buttons may or may not work to launch the software on the computer. Try opening the software and initiating scans from the computer.)
Jul 22, 2010 | Canon imageCLASS MF5550 All-In-One Laser...
How can windows xp install this printer in
probably not ... go to www.canon.com/support and get the driver you need to install this device on your computer, if it is supported under XP.
It is XP compatable, RIGHT? Check the microsoft compatability list for XP operating system.
Jan 15, 2010 | Canon imageCLASS MF5550 All-In-One Laser...
I do not have the cd rom windows can not find the MF5550 is there any compatable soft ware that can install this printer
You can download the drivers for your model from http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=239&modelid=9516
Be sure to select your correct Operating System, and the drivers will appear for download. There are also links to Manuals and other related Documentation listed there as well.
Once you download the file, double click to run the .exe file and follow the on screen prompts for installation.
I have just upgraded my computer and it came with Vista. I cannot find a vista print driver for a Canon MF5500 imageClass series. Can anyone help me?
Should have come with a installation disk to install the driver .
failing that,check the manual for the printer and visit the Canon web site.
Oct 02, 2009 | Canon imageCLASS MF5550 All-In-One Laser...
Canon laser printer 4122 all in one printer
Canon imageCLASS MF Firmware Update V062 Windows 2000/XP/Vista/Windows 7(all x32/x64) from Canon Multifunction .
Hi there
This is because you need to update your Firmware,
So what I have don for you I have found the Update you need and I have put it on my website for you to download, this is a update for Vista / Win 7 / All 32Bit and 64 Bit.
Click Link = http://www.4all2sell.com/driver/Canon-MF4150_FirmwareUpdateTool_V062.exe
All I ask is please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
All files on my website is only there foe a limited time.
Dec 27, 2008 | Canon imageCLASS MF5550 All-In-One Laser...
Canon imageCLASS MF5550 All-In-One Laser Printer Logo
11,060 people viewed this question
Clive
Clive
old marine
old marine
Ekse
