Question about Zassenhaus Knee Mill Hand Crank 156 Manual Burr Grinder
Grinding adjustments does not stay, but loosens during grinding. What should I do?
    Brigadier General:
  • 4,090 Answers
Use a small abount of your ladyfriwenjds nail varnish on the adjustment nut or screw to prevent vibration from lossening it.
Please rate my help++++Thanks for using FIXYA
Posted on May 28, 2010
How does one loosen the nut holding the grinding wheel? How does one hold the spindle to loosen the nut holding the grinding wheel?
Are you talking about halfshaft nut? Loosen the nut before you raise the vehicle, if possible. I don't know year--make--model?
Apr 10, 2017 | Cars & Trucks
Adjustsettings on Oregon 511AX bench grinder
there is a nut and bolt that holds the little shelf below the grinding wheel. Loosen it and adjust the shelf or rest to within approximate ly1/8 inch of wheel for safety.
Nov 27, 2014 | Oregon 511ax 115-volt Bench-mount Chain...
Why does washer make grinding metal sounds during wash cycle only?
When it is washing, look to see if the basket is moving at all. The basket should be stationary during the agitation cycle.
Nov 21, 2012 | Kenmore Washing Machines
How do I clean the bean grinder in a seaco royal profesionla machine?
These instructions come directly from the service manual. Notice the mention of a qualified technician. If you do this on your own be careful. If you don't follow the instructions correctly or you break something you've will have no one to blame but yourself.
-Clean the coffee beans container periodically; this operation should be accomplished by a qualified technician! Unplug the machine. Empty the coffee container and unloose the two fastening screws. Now, the container can be removed and cleaned.
-Carefully pull the adjustment lever upwards, previously writing the set grinding degree.
-Turn the adjustment ring counterclockwise, until the blue marks coincide.
-Now, it is possible to remove the grinding ring from the machine, slightly pulling it upwards.
-With the aid of a brush or a narrow vacuum hose, clean both the gear box and the grind ring support. Make sure the position of the grind ring does not shift. To reassemble the coffee grinder, carry out the reverse sequence, making sure the adjustment ring has not been shifted during cleaning. If that is the case, turn it until the blue mark coincide with one of the three notches. Assemble the grind ring support and make sure the blue marks coincide.
-Turn the adjustment ring clockwise, to make the red marks coincide.
-Fit the adjustment lever on the ring, until it coincides with the previously set grinding degree.
Nov 28, 2010 | Saeco Royal Professional Espresso Machine
Whatever the setting is at the grind is always fine. What can I do to re-calibrate the grinder?
Grind Adjustment Tools required: Large blade and medium Phillips head screwdrivers In order to adjust the grind, follow these steps (Refer to figure A): 1. Remove all coffee from the hopper. 2. Set selector knob to the finest setting (Espresso or Turkish) depending on the model. 3. Loosen both knob retainer screws in selector knob one turn only. 4. While pressing the bag switch, located behind the spout, press the START button so that the grinder will run during adjustment. 810 model - Press the ON or START button so that the grinder will run during adjustment. 5. With the grinder still running, turn the adjusting screw in the center of the selector knob slowly to the right until a slight clicking noise is heard. Immediately turn the adjusting screw to the left one grind setting. This is the finest grind obtainable. 6. Tighten both of the knob retainer screws. Once the ESPRESSO grind has been set (Turkish for Model 835, 875, 890), the other grind settings will automatically set correctly. 7. Press the STOP or OFF button. IMPORTANT: Always be sure the grinding burrs are not touching while the machine is running on the ESPRESSO/TURKISH setting. Otherwise serious damage to the motor may result. dr_buckhead.png
Nov 19, 2010 | Grindmaster 810 T Electric Burr Grinder
Grind & Brew Thermal™ 12-Cup CoffeemakerModel # CUI DGB-900BChas stopped grinding after it was cleaned. This has never happened before amd I am not sure how ti fix it. What should I do?
this is a cronic problem with the DGB900BC even after cleaning. the problem is the gate or trap to the grounds needs to open/remain open during grinding or all backs up and jams. my unit opens the door (correctly) during the rotation but closes just before grinding (over-rotation?). Cuisinart is not aware of this problem (800-726-0190). please call them; i just have.
Aug 22, 2010 | Cuisinart DCC-1200 Coffee Maker
Grating or grinding sound during drying cycle
there are screws that loosen and drag on the drum it happened to ours. they are on the top under the cover.
Oct 13, 2009 | Maytag Neptune MDE5500AY Electric Dryer
I don't know how to change the grinding blade on my makita angle grinder.
There is a nut that you release from the middle of the grinder wheel, (grinder blade)
This nut is flat and has four holes in it.
You will see you are providing a spanner wrench to remove this nut. The wrenches' actual name is Lock Nut Wrench. It has a U shaped end with two pins sticking out. On on each side of the U shape.
The pins are inserted into the holes in the flat lock nut, located in the middle of the grinding wheel. The wrench is laid flat against the grinding wheel, with the two pins of the wrench going into any two holes of the nut.
At the top of the Makita grinder you will see a Black button. The button is pushed down to keep the grinding wheel from spinning. Holds the grinding wheel in place, as you turn the lock nut loose. When you release the button, a spring inside pushes the button back up out of the way.
As you view the Makita grinder, Release Button towards the Back, grinding wheel towards you, the nut is turned to the LEFT, to loosen. It is a Left threaded nut.
The grinding wheel spins to the Right. Using a left threaded nut insures that the nut will stay tight, due to the direction the grinding wheel spins.
Oct 01, 2009 | Makita Usa Inc 9557PB 4 1/2" Angle Grinder
Grinding when Engaing PTO for the tiller-Troy Built Horse 8hp
It's likely that your clutch needs adjustment. To adjust, you just need to loosen the two screws on the plate and slide it a bit so the clutch better engages the rear dog clutch. Have you ever taken the tiller portion off the transmission to grease the clutch? If not, before adjusting it you might want to do that. It could be that the clutch isn't sliding back far enough to engage the rear end and a little grease is all it needs. This service requirement is explained in the owners manual for the tiller. One last point, the tiller must be in neutral when engaging the pto clutch. From your note, it sounded like you were engaging the clutch with the forward/reverse lever in the forward position. The lever must be in neutral when engaging the pto clutch.
Jun 14, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Solis Maestro Plus: Grinding Adjustment does not move and can not take out Grinding Ring
Hi
Sounds like you may have broken off the adjustment tabs on the outer ring. Contact Baratza for help.
Jul 12, 2008 | Solis Maestro G385 Electric Burr Grinder
Zassenhaus Knee Mill Hand Crank 156 Manual Burr Grinder Logo
157 people viewed this question
Top Zassenhaus Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Zassenhaus Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
