Question about HP 417035-001 - HP Pavilion dv2000 Series Laptop Full Featured Intel Chipset Motherboard
No power light on my 6735s hp laptop - HP 417035-001 - HP Pavilion dv2000 Series Laptop Full Featured Intel Chipset Motherboard
  • HP Master
  • 32,281 Answers
Check power adapter’s DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced.
If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard.
This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Posted on May 28, 2010
My ho 6735s orange light flashes 7 times when i plug it in but wont turn on ?
Hi,Thanks for using fixya,
Remove the battery, and unplug the A/C adapter and hold down the power button, for 40 seconds.Soon your laptop will reset,and run well.Now you will install all the accessories and start.
Hope this helps you.
Feb 01, 2011 | HP Compaq 6735s Notebook
I am an owner of an HP Compaq 6735s Notebook PC. I have experienced the notebook failure. I am unable to start the computer at all. It just happened when I tried to restart it. I have noticed the...
my daughters hp 6735s had the fan running all the time issue, having got fed up with this I decided to try to fix it. I downloaded the service manual from the hp website and dismanteld the laptop to remove the motherboard. The fan defuser had some dust but not much, so I removed the heatsink that covers the cpu and gpu. I noticed the cpu did have thermal compound that was in contact with the heatsink, however the gpu had compound on the chip but nothing touching the heatsink. I cleaned the heatsink, cpu and gpu with degreaser, then applied new silver themal compound from maplin. I made sure i also applied a thin coating to the heatsink. I refitted the heatsink and reassembled the laptop. I powered on the laptop and instantly noticed the laptop fan running at half speed which it should do, I installed a program from a dvd and left the laptop running and so far so good. If we had left this any longer I suspect the solder under the gpu would have become molten and then we could have had another issue which maybe we could not have fixed. I hope this helps you if you have similar issues.
Jan 19, 2011 | HP Compaq 6735s Notebook
My Compaq 6735s is not powering at all. it doesn't show any indication that light gets to it. I changed power adapter and battery to new one but the situation remain the same. pls help.
Have you checked the power receptacle where you plug the power adapter to the laptop? Does it seem to be broken or loose?
If it is broken, it will need to be replaced. If it is loose, it will need to be re-soldered to the laptop's motherboard. Either way, you will have to fully disassemble the laptop to gain access to the motherboard & do the fix.
Nov 28, 2010 | HP Compaq 6735s Notebook
Hi my hp 6735s laptop has just started turning itself off when knocked or moved slightly. When you try and power back up the orange light around where the power lead plugs into the laptop flashes about 10...
Check the power cord at the connector. Hp has a problem with the cords breaking internally. I had a problem with mine and found that if I played with the cord then it worked for a while. I ended up buying a new power supply.
May 26, 2010 | HP Compaq 6735s Notebook
Hewlett packard 6735s power up
Your battery is critically low. Didnt you recharge your battery? Try turning it on with the external power source connected.
Jan 14, 2010 | HP Compaq 6735s Notebook
HP 6735s laptop with AMD Turion X2, screen remain dark...
Try locating your memory sticks under unit, try taking them out and resitting them, try also resitting your hard drive.
if this does not work let us know
Jan 04, 2010 | HP Compaq 6735s Notebook
HP Compaq 6735s battery light orange blinking
Have you tried another power cord? If you try another power cord, and it still does the same thing, then I think your laptop is having a power problem. You need to take is to a technician to fix the problem for you.
Best wishes.
Nov 28, 2009 | HP Compaq 6735s Notebook
Hp 6735s screen blank problem
If you use it from the power cable does it work better? There is a known issue with the 6735s and power management settings from battery.
Oct 02, 2009 | HP Compaq 6735s Notebook
HP 417035-001 - HP Pavilion dv2000 Series Laptop Full Featured Intel Chipset Motherboard  Logo
498 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
