Question about LG DLE5955 Dryer
How do you get into the dryer to change the natural gas connector to a propane connection?
    Brigadier General:
  • 4,090 Answers
Not sure what country you are in, so I am unsure that the same conditions apply.
The gasline from the meter must be interrupted. Propane bottles connection pipe can then be brazed to the copper line . By law a propane regulator must be fitted between the bottle and the gqas line going to the dryer.
This must be fitted by a licensed gas fitter ( plumber) so if any problems occur your insurance will pay out on fire or other faults.
Placing the propane bottle line directly to the dryer without a regulator and inside a building is dangerous and unlawful, as most dryers are not vented correctly to deal with propane.
Please rate my help++++Thanks for using FIXYA
Posted on May 28, 2010
How do you convert to propane a kenmore elite model # 79671622310
You have to get the conversion kit. Mostly the burner gas nozzels has to be changed. Propane has a higher BTU value than natural gas. So the burner nozzle has to be smaller with propane.
You have to have the right nozzle kit for your dryer. Normally the propane nozzle kit comes with the new dryer. It is attached in a plastic seethrough bag and attached somewhere in the back of dryer.
Also you have to adjust the air opening in the burner for propane. Propane need more air than natural gas to burn properly. If you buy the conversion kit or find the conversion kit in the back of your unit, it will clearly give instructions how to do it.
Sep 26, 2014 | Dryers
Natural gas to propane
the pilot and/or burner orfices need to be changed.depending on your model the gas valve may also need to be converted.
Sep 27, 2007 | Whirlpool GGW9250PL Gas Dryer
I'm converting my natural gas dryer over to LP gas. I've changed the orifice but it is saying to close the regulator. It says the same thing with Natural gas but that doesn't make sense because it isn't...
I know from working on piles of restaurant equipment, that when you change over from natural to propane, you have to change the orifices and the regulator. Most natural gas equipment needs 3.5-4.0" of W.C. (that is, water column) and most propane gas equipment needs 9.0-11.0" W.C. The density and specific gravity of the gases are different. If it is glued so as you can not make any adjustments to the pressure, change the regulator to a propane one. Most natural gas regulators can not be adjusted to the propane pressure needed. Please be careful as working with gas can be dangerous. Natural gas is usually lighter than air and will rise but propane is heavier and will "pool" or "puddle" in low areas and can cause explosions in the right circumstances.
Dec 05, 2017 | Kenmore Dryers
On a model 62841, how do you switch from propane to natural gas
Natural gas usually runs on 4 ounces of gas pressure. It is regulated at your gas meter. If you had an orifice in your propane line all you should need to do is remove it.(inside a connector by the dryer intake for gas) Just make sure you look at the back plate of your dryer or user manual and check the pressure rating.
Jan 07, 2011 | Kenmore Dryers
I DO NOT HAVE NATURAL GAS AVAILAABLE WHERE I LIVE/
You can order an LP conversion kit to change it over to propane. Most kits cost between 30 and 60 dollars, and require you to take the drum out of the dryer to access the gas valve for the change over.
May 07, 2010 | Kenmore 73952 Gas Dryer
Propane to nat. gas dryer
Good day,
Yes. Two reasons. The orifice that the gas comes out is a different size, and the regulator that determines gas pressure is disabled when using Propane, since propane has the regulator on the tank.
See here.
http://fixitnow.com/wp/2009/03/13/converting-a-gas-dryer-from-natural-gas-to-propane/
If you are not 100% sure what your doing, call a qualified company to perform the conversion. Isn't worth the gamble.
Propane is, unlike natural gas, heavier than air. It can pool in a low spot then ............
Dec 25, 2009 | Whirlpool GGW9200L Gas Dryer
Convert propane hook up for dryer back to gas
the oriface size for propane and natural gas is the same it only has to be changed if you will be useing butane it should hook up and work the same but the propane will have a stronger sulfer smell than natural gas always connsult you gas provider if you are concerned they usualy will send tech to inspect if youhave questions for your safety
Nov 17, 2009 | GE Profile Harmony DPGT750EC Electric...
How to convert my new kenmore 600 natural gas dryer to propane
Hi!
You will need a conversion kit for converting your dryer from natural gas to Propane. Please see this link for converting your dryer from natural gas to Propane---
Kenmore 600 natural gas dryer to propane
Please ask for further clarifications.
Please rate this solution as Fixya if found useful.
Thanks
Rylee
Mar 13, 2009 | Kenmore Dryers
I moved and after hooking up my gas dryer to gas tank it will not heat up....
were you on propane b4 the move or natural gas? A natural gas dryer will not run on propane nor a propane one run on natural gas
Jan 14, 2009 | Kenmore 73932 Gas Dryer
LG DLE5955 Dryer Logo
91 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
