Question about Epson WorkForce 600 All-In-One InkJet Printer
I have paper jams when there really is no paper jam. No pieces or anything.
    Brigadier General:
  • 3,917 Answers
Thanks for contacting Fixya.com
It was the paper feed encoder wheel and sensor. Carefully remove the top scanner assembly. Look for a black cover on the left side of the print mechanism. Remove the cover and you will see a clear plastic wheel with marks on it. Look at the very bottom of the wheel and you will see a sensor. Blow the sensor out with canned air. Make sure the encoder wheel is pressed firmly on the shaft. Test and determine if it fixes the problem.
The black encoder cover was probably not made to remove while the print mechanism is installed. However, it will come out with a little effort. Also, the cover is not required during operation (the wheel may get ink mist or dust on it over time without the cover). The paper jam error appears to be very common, and I would avoid this and similar HP models.
If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred.
Turn off the printer.
Remove any paper trays. Inspect them for wrinkled or damaged paper.
Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly (see A). The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
If the paper does tear, try rotating the roller gears manually to free the paper (see B). Don't force anything, though.
Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
Thank You
If you donot have further queiries please donot forget to accept the solution.
Posted on May 30, 2010
HP PSC 1610 - Keep getting paper jam error with no paper jam.
Hi there ok Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 09, 2010 | HP PSC 1610 All-In-One InkJet Printer
Paper jam, but no jam + paper feed problem
check to make sure there aren't little pieces of paper jammed at the ends of the roller. if you can pop out the roller easily you may find tiny pieces of paper still lodged in there
Dec 29, 2009 | Office Equipment & Supplies
Brother 2920 Fax Machine keeps jamming every few pages
Please try this and let me know how it goes
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jun 09, 2009 | Brother IntelliFAX 2920 Plain Paper Laser...
Pixma mp480 jams paper!!! It occurs on the left side Ive tried different paper and it continues to do the same thing I really disappointing because I just bought 4 months ago and I thought canon was a good...
Please try this and also try cleaning the printer and the paper rollers that it has.
alternative :
Jun 09, 2009 | Canon Pixma MP480 All-In-One InkJet...
My canon mx310 keeps showing a paper jam alarm and there is no paper jam. how do I fix it?
give this a try
alternative :
Jun 02, 2009 | Canon PIXMA MX310 All-In-One Printer
Canon MP600 paper jam
alternative :
May 27, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Error paper jam
ellow bkadam,
there something little piece of paper stuck at you fuser there.that why appear paper jammed...try to open u fuser cover...maybe it can help
Nov 07, 2008 | HP LaserJet 2840 All-In-One Printer
Canon MP140 paper jam error with no paper jam
try this
alternative :
Oct 04, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Hp C5280 Paper Jam error - no paper + component fell apart
I am having a similar problem. An33651759-359a-4c42-a15c-e9b8d80fcfba.jpgyone know where this piece belongs? It came out when I cleared my millionth paper jam!
Sep 09, 2008 | HP Photosmart C5280 Printer
PAPER JAM THAT REALLY DOESN'T EXIST
make sure the back cover (black panel) is fully closed. If it is, remove the panel and shake gently to make sure nothing has fallen inside.
Mar 12, 2008 | HP PSC 1510 All-In-One InkJet Printer
Epson WorkForce 600 All-In-One InkJet Printer Logo
112 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
