Question about Kenneth Cole Reaction - REACTION SILVER & BLACK CRYSTALS WATCH RK2203
My bag has a three number lock, how do I reset it so I can get it open?
    President:
  • 2,501 Answers
I assume that the lock is a mechanical type.
With most combination locks you can pull on the ends and you will see a gap opening at one end.
While maintaining a gentle pull on both ends (using your 3rd and 4th fingers), rotate the tumbler that is furthest away from the gap. When the code number on that tumbler is is reached you should be able to feel a slight give in the mechanism.
Continue the same process with the second tumbler and then the third. The lock should then open.
Posted on May 28, 2010
I have a tommy hilfiger bag.. The lock code was 000 but somehow it is not opening. Can you please suggest a way to open the bag as it is really urgent
Uhhhhh yeah! If the bag only has a 3-digit lock code, that means there are only 1000 possible combinations for the lock. In the time it takes you to wait for an answer to this question that won't be coming, you could probably have tried more than half of them. If, after exhausting all possibilities, the lock STILL won't open, THEN you have a real issue, since the only way to get in the bag will be to break the lock or cut into the bag. Thank you Captain Obvious.
Nov 13, 2016 | Tommy Hilfiger Watches
Battery size for emporio armani ceramic ladies watch
  • To determine battery type: open back
  • Locate battery holder and identify type. Note battery mounting
  • Place opened watch in plastic bag to keep it dust-free while you obtain a replacement battery
  • Remove watch from plastic bag and install new battery
  • Check operation
  • Install back
Finally, reset watch as necessary
Aug 28, 2016 | Emporio Armani Watches
How do i change the time on the three small dials
Hello Garrett,
"Three small dials"... My guess is that we are talking
a chronometer... (stopwatch)... "ZERO Process".
Not only are the three sub-dials usually settable... but also the sweep second hand.
Trouble: After resetting the watch... the hands go back to the same position...
Solution: You want to "ZERO" your dials... one by one.
These watches typically need to have the stem out to the third position... then press the top "start" timer button... observe ONE of your dials is moving. As it approaches the desired number release the button and step it into position with single button pushes.
Go to the bottom "stop" button... Repeat the process!
Push the stem in to the middle "set" position...
Repeat the process!
Again... press the top "start" timer button... zero
and finally press the top "stop" timer button... and zero.
Set the time and date... push that stem back into the home position... and record 35 seconds on your watch... stop and reset...
If everything does not come back exactly to ZERO...
Then that is called an iterative process (do it again).
Fine tune it!
Good Job.
(comment me back if I didn't hit the spot)
Horology Wikipedia the free encyclopedia
Feb 10, 2016 | Watches
How to change hours
Timex Watch setting
Make sure you are in the hour/minute/second mode. Press "set" -- the seconds will flash. Then press "mode" again and the right minute number will flash. Press "mode" again and the left minute number will flash. Press "mode" again and the hour will flash. Press "mode" again and the month will flash. Press "mode" again and the date will flash. Any time any groups of these numbers are flashing, you can change the numbers by pressing the "start/stop" button. When you get the numbers you want, press "set" to lock in those numbers.
To change from 12 to 24 hour, get the hour numbers flashing and press
"split/reset." Then press "set" to lock in either 12 or 24 hour time...
Mar 14, 2015 | Timex Indiglo Watches
Clock Manuals
leave it running when it gets to 12 oclock it wiil reset itself
May 02, 2013 | Watches
XQG65-908E
Power up the machine and press TEMP, FABRIC SELECT, TEMP, FABRIC SELECT, in that order, within 30 seconds of powering up the machine, this will enter service mode and t01 will display on the control panel...
Hold in the delay button for 3 seconds, this should reset the codes....
If doing the above does not work after 3 attempts, there is a fault in the circuit relating to the fault code,,,(COMPONENT) good luck. the code is a stuck door. Hopefully you didn't try to pry it open.
May 03, 2017 | Watches
Cant reset time casio wvq-201hu
you need to look at the user manual that
you can download a soft version of the user manual on below link. .when you open the link just write the 4 digits code on the back side and click searched on the URL below
Hope this helps! Take care and please Remember to rate/vote and
give me 4 Thumbs Up for me to continue for Helping out the Community :)
Thanks
CASIO Watch User Manual Archives
http://world.casio.com/wat/download/en/manual/
Use this page to download a copy of CASIO watch manuals in PDF format.
To download a PDF file, enter the four-digit (or three-digit) module number marked on the back cover of your watch.
Oct 05, 2011 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
Have small 3 x 6 x 12 metal money box and it has a three wheel combination lock in the face of the box. How do I open this box there is not any manufacturer's name on it on one little probably 1/8 inch...
Is it a cheap three wheel combination? Like on a briefcase? If it is then take the lever that opens it and put pressure on it. Like you are trying to open it. Then start with the one closest to it and slowly click it from one number to the next and it should feel just a little bit different when it gets to the number. Then go to the next one, then the next. I hope this helps.
May 21, 2010 | Watches
How do i set alarm on a gap sport watch?
For setting Time & Date...
1. Push "MODE" button three times (change Mode to TimeSet)
Time -> StopWatch -> AlarmTimeSet -> TimeSet -> Time ->...
2. Flashing Second Number Digits
3. Push "RESET" to select...
Second -> Minute -> Hour(12hr<->24hr) ->...
Date -> Month -> Day of Week -> Second -> ....(repeat)
4. Use "START" to set each item...
For setting Alarm ON/OFF
1. Push "RESET" button then Push "START" same time...
Alarm ON -> Alarm OFF -> ... (repeat)
Jan 09, 2009 | Columbia All Sport Digi Watch l
Watches Logo
360 people viewed this question
Top Kenneth Cole Watches Experts
Jimmy Accardi
Ansel Alberto
Ansel Alberto
Are you a Kenneth Cole Watch Expert? Answer questions, earn points and help others
