Question about Refrigerators
Kitchenaid Refrigerator Superba
The water dispenser is leaking and filling a glass of water every 20 minutes (constant drip). Also, water is leaking from the ice maker inside into the ice cube holder then freezing. One expert said it might be the fill valve. What is the part number I need and is it easy to install. Thank you for your help....
KitchenAid Superba side by side (manf. 10/00)(Model KSRB25FHSS04)
    President:
  • Refrigerators Master
  • 2,651 Answers
Heres a part number for the valve, somple enougth to install just turn off the water supply and installe ne wvalve, exact replacement. soundsas if its not closingt correctly allowing water to tricklel in part number 4389177
Posted on Apr 08, 2008
Water dispenser leaks
Refrigerator Water Dispenser Leaks?
Refrigerator Water Dispenser Leaks show that the refrigerator's water system has a problem. To fix this problem, open the filter compartment and pull out the filter and push it back in so that it is secure in place. Push compartment cover until it clicks.
try to check this video.
May 13, 2014 | KitchenAid Superba Architect KSCS25INSS...
Water dispenser drips sometimes after filling a cup with water. Does not happen every time. If not addressed, the drip continues indefinitely. To stop the drip, I use my index finger to give a good poke...
When water leaks from the dispenser like this it will be caused by a defective water control valve that will not shut properly when off. The leaking water is the same as a leaking faucet. The KSCS25IN uses a=> W10247725-Water Control Valve or HERE
Sea Breeze
Sep 24, 2013 | KitchenAid KSCS25IN Side by Side...
Leaking water dispenser
The reason the water dispenser keeps dripping is because of a faulty water inlet that instead of fully closing yet it is staying open justa wee bit and seeping water through it. By replacing the water valve it will stop that drip.
The part number for that water inlet valve is W10247725 it could be purchased at your local appliance parts store or online at;
searspartsdirect.com
apdepot.com
repairclinic.com
apwagner.com
partselect.com
GENE
Oct 18, 2011 | KitchenAid Superba Architect KSCS25INSS...
Water dispenser leaks all the time.
Hi,the leakage in your kitchen aid all the time is due to the fact that the water inlet valve of your refrigerator,hence water keeps dripping from the dispenser always.
The only solution to the problem,is to remove the back plate which covers the compartment at the bottom of the refrigerator and replace the water inlet valve.
However,the component part number for your model is; 4389177
Thanks and good luck.
Jun 29, 2010 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid Superba leaks from filter housing
i would definately change the filter
they are usually only good for 6 mos
or 400 gals
without knowing if its dripping from the housing
i would start with changing the filter and see if that takes care of it
AP3182816
i just checked and thesea re on sale
30.00 is pretty cheap
appliancepartspros.com
i used to sell these off my truck as a maytag guy
for 48
let me knoe
Oct 17, 2009 | KitchenAid Superba Architect KSCS25IN Side...
Our KitchenAid just started leaking. it is coming from the front ice dispenser on door. seems many people are having this problem. there is also "snow" on ice maker and bucket. and the temperature...
Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
The excess frost on the ice maker and bucket can be caused by the ice chute door not closing all the way or a leaky door gasket letting air in.
Jul 01, 2009 | KitchenAid Superba Architect KSCS25INSS...
Leak in the water dispenser
Jun 30, 2009 | KitchenAid Superba KSRG25FK Side by Side...
Kitchen Aid Super Ba refrig..water dripping from water spout !
To stop the dripping now, turn the water off.
The problem is there is either mineral caught in the seat of the dispenser valve, or the dispenser valve seat has a bad place in it. Removal and cleaning/replacement is required.
Jan 18, 2009 | KitchenAid Superba Architect KSCS25INSS...
Water dispenser drips after filling glass.
sounmds like you have air trapped in tothe line( formiong pressure behind the line whe nnot in use forcing water drops out, remove the crisper in the refrig campartmant and look for the holding tank either there an air bubble trapped in ther or you havea small leak allowing air inot the system, usually happen right after replacing the filter, instraed of trying to rnn 5 secs on 5 secs off, try with a bigger contaienr to allow constantly running for longer periods of time to hopefully force out the air bubble
Mar 05, 2008 | Amana ACD2232HR Side by Side Refrigerator
Drain pan leaking?
there is a drip pan located underneath you ref but most likely your prob is a plugged drain line coming from the freezer. when you ref goes into automatic def the water doesnt run out into the drip pan but instead onto your floor..
you can clean the drain line by removing the rear cover in the freezer compartment and using hot water to thaw the drain below the evap coil.
Dec 08, 2007 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
398 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
