Question about Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
Flashing F28 My dryer is flashing F28. The cycle is done i think but the door will not open to get the clothes out. What do i do and what is the problem?
    Brigadier General:
  • 4,090 Answers
This is an MCU board unit failure.
To get the door to open so you can remove the clothes UNPLUG the unit from power source. You may have to wait awhile for the unit to reset.
However the unit should receive attention as this board is part of the main control. If the machine is under warranty it will be replaced free. This is common to this model.
Please rate my help++++Thanks for using FIXYA
Posted on May 28, 2010
Kemore Elite Front Load washer was flashing F11 and i repeated the drain, spin cycle several times. now flashing dL and F . The door is locked so I am unable to remove wet clothing.
Try lowering the drain hose onto the ground and see if the water comes out. Turn off at the wall and then back on again a few minutes later. See if the door unlocks this time. Most front loaders wont let you open the door if it thinks its still full of water.
Mar 21, 2017 | Washing Machines
What does f23 error mean?
Display shows an error code - Front-load washer ' Whirlpool ...
https://www.whirlpool.com/...error-code...w...
Whirlpool Home AppliancesCheck the following answers for error-code related issues you can correct: ... Duet SportTM washer - F01, F11, F23, F24, F27, F28, F29, F30, F31, and F33.
What does error code f23 flashing mean on a Whirlpool ...
Nov 30, 2015 | Washing Machines
Finished, wash and spin lights flashing. Door
I just had this problem! To get the clothes out, open door manually (follow answers on other threads here about opening toe panel and gently pulling down on door release). But as it turned out, I didn't need to remove the clothes, and now my washer is working again.
A local repairman gave me this advice over the phone. Make sure dial is switched to off. Unplug your machine, then plug it back in. Hold down the rinse and delay buttons with one hand. With the other hand, switch the dial from off to cold or warm or whatever cycle you want. All the buttons flash a few times, then just the start button flashes. The second time I tried this, my washer worked afterwards. I've done several loads today with no problem.
Jul 19, 2010 | Bosch Nexxt 100 Series WFMC1001UC Front...
I washed a large load in our Whirlpood Duet Washing Machine and it stopped with a flashing F28 code. I unplugged it for 5 minutes and it still will not run a cycle without stopping with a flashing F28...
The error code F28 means one or both of these parts are bad.
Motor Control Unit (8540135)
Microcomputer Machine Control Unit (8540788)
It would be a good idea to order both, as both components have been problematic for error code F28
If you find either the MCU or the CCU(Microcomputer Machine Control Unit) fixed it.
You can download the online repair manual in the below link
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/6545d78b3f479480852571650061b1ba/$FILE/8178558.pdf
On page# 4-20 it shows how to access your MCU.
Jun 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have a Whirlpool Gas Dryer LGR6646BI-12 the clothes feel warm but not hot and they are still damp
The Dryness Level allows adjustment of how damp or dry the clothes are at the end of the cycle.
  1. Make sure the correct Cycle has been selected for the type of fabric being dried.
  2. If the correct cycle is selected and the clothes are still coming out too damp, use the Auto Dry Level button (Kenmore) or Dryness Level button to increase the Dryness level.
  1. If the highest Dryness Level setting was selected and the clothes are still damp, the Customer Focused Drying Mode settings that are built into the machine can be adjusted.
Dryers come from the factory set to Drying Mode 1 (default). Drying Modes 2 and 3, include additional drying time.
Note: This change will affect ALL Auto Dry cycles.
  1. Machine MUST be in Standby mode before beginning. (Standby mode = Plugged in, Power off)
  1. To select drying modes, momentarily press the Auto Dry Level button (Kenmore) or Dryness Level button (Whirlpool) again. The dryer will beep, and the display will flash and show the next drying mode number.
  1. With the door open and the display flashing the desired drying mode number, press the Start button to save the drying mode and exit diagnostics.
  1. Press the Pause/Cancel key at any time to cancel changes and exit from this mode.
Hope this works............
May 01, 2010 | Dryers
Machine thinks door is open and won't run a cycle!!!!!!!!!!!!!!!!
There is a catch latch on your dryer door and that may be softening up when the dryer gets warm and the clothes tumbling against the door is enough to push the door out to the point that it thinks it is open. Try this exersize... The next time you wash clothes place a chair sideways against the doon with your clothes basket on it and see it it completes the cycle If it does then your door latch and actuating arm / post need replaced.
Jan 13, 2010 | Dryers
During the drying cycle, the dryer door opens
Chances are the little plastic latch keep is broken. Look at the door and locate a peice that will press into the front area where the clothes go in.
Once you see it, check the keeper and see if it is broken. The door should not just pop open.
Feb 25, 2009 | Dryers
Hotpoint wd440 flashing dryer heat button and onoff button !
I had to have a tech come out for the same problem two weeks ago. They had to clean the lint collector which you cannot get to on your own. He said now that this has been done everytime I use the machine, take the clothes out and then run a rinse spin cycle.
Aug 04, 2008 | Hotpoint Aquarius WD63 Front Load...
Aquarius
i have the same problem if you find out please let me know...... think may need a new program for machine would be cheaper to buy new one all together
Jul 22, 2008 | Hotpoint Aquarius WD640 Front Load...
Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer Logo
110 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
