Install a brand new needle (make sure it is compatible with the thread and fabric). Remove the top thread from the machine. ALWAYS RAISE the presser foot and rethread from the beginning. Verify the thread path is correct. Set the top tension to the midway point and retest your machine. Tweak the top tension until the top and bobbin threads meet in the middle of the fabric.
Usually thread breakage is a result of incorrect threading or the thread tension set too tight.
Install a brand new needle.
Remove the upper thread. RAISE the presser foot and rethread from the beginning (verify the threading sequence is correct).
Check that the tension is set at the midway point between the high and low numbers.
Retest. If still breaking, there are other less common problems (thread/needle incompatibility, burrs or knicks catching the thread, etc) that may be the cause. Check the following web sites:
Here are a few sites that may be helpful in diagnosing your problem:
NUMBER ONE SUGGESTION--install a brand new needle. Sewists are known to be very frugal about changing needles but it is usually the easiest and least expensive fix for a lot of problems.
Remove all the thread from your machine, clean the bobbin area of any lint, threads, etc. Be sure that you RAISE the presser foot BEFORE you thread the upper thread. This releases the tension disks so the thread will seat properly. Now, re-thread from the beginning verifying you are following the correct threading sequence (consult your manual).
The standard factory tension setting is the midpoint, ie of the range is 1-10, set the tension at 5 and then adjust from there.
you need to check the thread tensioner
set to like 1 and if the thread then spools out and runs ok but spolls out too much and sags
turn it up 1 at a time
thick thread ~ 3-4 is usualy ok with lighter thread cotton will need 1-2
The top thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
8. Try a different spool or cone of thread
