Question about Singer 3116 Simple
Needle wont stay threaded as i sew the needle looses the thread
    President:
  • 405 Answers
Try another needle and set the tension a bit higher.
Posted on May 28, 2010
4 Suggested Answers
  • 26 Answers
SOURCE: needle wont pick up bobbin thread
timing issue, need to have serviced.
Posted on Aug 22, 2009
  • 36 Answers
SOURCE: lower thread tension very loose
is the bobbin threaded correctly? the screw on the bobbin case is the point to adjust its tension.
Posted on Jun 02, 2010
Tally Girl
  • 1122 Answers
SOURCE: the needle wont stayed treadedwhile
My trouble shooting suggestions are:
check that the thread is in the thread take up lever eye correctly
Is the top tension set too tight, ie should be on 5
Is the thread catching somewhere in the thread path?
Is it catching on the thread spool itself, sometimes they have a little notch cut in the top edge to hold the thread tail but it could be getting caught in there during sewing. If so, turn thread spool up the other way or use a mushroom cap on top to hold the thread off the spool top edge.
just go through the top threading path checking thread is into all thread eyes correctly and not catching on anything and that it is threaded correctly, it should be one of the above causing this.
Posted on Jul 10, 2011
My needle will not stay threaded. Should I reset the tension? When it begins to sew lots of thread comes out and the thread becomes very loose.
Not sure if this will help, but is worth a try:
Remove the top thread from the machine (NEVER pull the thread up--ALWAYS clip the thread by the spool, raise the presser foot, and pull the thread DOWN through the needle from the thread tail end).
**ALWAYS RAISE the presser foot and rethread from the beginning. Verify the thread path is correct.
Test your machine and see if the top thread reels out smoother. If needed, adjust the top tension until the top & bobbin threads meet in the middle of the fabric.
Jul 08, 2017 | Sewing Machines
My stitch wont stay in the fabric what am i doin wrong
needle thread tension worng
no thread in the bobbin
neeld /hook timing is wrong
May 14, 2017 | Sewing Machines
Machine wont sew. Misses stitches
check for problems in the bobbin winding, ( in the wrong way so that the thread is not coming out correctly)
top thread tension too tight or too loose
vary the thread tension to see when it improves on a waste test sew
Aug 21, 2016 | Sewing Machines
Wont sew thread keeps coming out of needle
you have to hold the loose end for a couple stitches when starting off
Dec 16, 2015 | Sewing Machines
Thread keeps getting tangled in bobbon and wont sew
try a new needle
make sure the bobbin is inserted correctly,, counter clock wise
also check the upper thread tension, also check to make sure there aren't any loose thread or lint in the tension disc area
make sure the top thread has not come off the thread take up lever
check in the bobbin area for lint or loose threads
Dec 15, 2014 | Sewing Machines
Thread is not staying in the needle bar thread guide. It is slipping loose.
hi try to make sure the thread is in between the tension wheel as you thread and sometimes turning the spool over works hope this has been of some help
Dec 12, 2014 | Brother Se400 Computerized Embroidery &...
My thread keeps breaking and the bobbin tension is too loose
adjust the top thread tension one number or letter higher at a time
and sew on a scrap piece of fabric till the stitches look normal
The needle thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
Jan 15, 2013 | Sewing Machines
Needle wont stay threaded when sewing
have thread tails of 4 to 6 inches long & pull the thread back behind the needle before you start sewing
Mar 11, 2012 | Singer 4423 Sewing Machine
The needle wont stayed treadedwhile sewing. I have changed out the needle and changed out the thread and it keeps unthereading while sewing the bobber is working just wont stay threaded threw the neddle
Jul 10, 2011 | Brother Sewing Machines
Wont pick up bobbin thread
1.check needle to see if it's bent or blunt end
2.check bobbin & bobbin case for lint or loose thread
3.could be a timming problem- would have to be serviced
Jul 28, 2010 | Brother LS-2125 Mechanical Sewing Machine
Singer 3116 Simple Logo
127 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Level 1 Expert
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
