Question about Whirlpool 24 in. GU940SCG Built-in Dishwasher
Water won't shut off, flooded kitchen
Water keeps running in even without any buttons pushed on.
  • 901 Answers
Check inlet water solenoid valve. May require cleaning. It's stuck and in open position or due to valve not getting seated properly inside valve body. Check incoming water pressure. If too high a pressure, this can happen.
It is advisable to close the inlet pipe **** after the days work.
Posted on May 28, 2010
Testimonial: "dishwasher is 10 years old, so I ordered a new inlet valve. I wouldn't trust the old one, and don't want to take a chance of another flooding.Thanks for the info!"
2003 Goldwing won't start...just one click when start button pushed
you may have blown the starter solenoid or even worst the starter motor
i cannot diagnose without seeing the bike properly
i strongly suggest you put in a workshop and get it diagnosed properly
Apr 12, 2013 | 2003 Honda GL 1800 Gold Wing
Maytag ice maker floods the kitchen when water does not shut off when filling the ice tray. What's the reason and fix?
What is the refrigerator model number? In most cases the dual water control valve with have a mechanical defect and cause the water to flow by the valve even when off. W10408179 Water Inlet Valve
If you can find your model number around the fresh food section door frame please post so I can insure I give you the correct part numbers, Thanks Sea Breeze
Dec 04, 2012 | GALAXY Microsystems 25.4 cu. ft....
Water won't shut off on my Estate washer
check clear tube that is inside machine.1st take off shell of machine look for clear tube about 1/4 inch diameter.it sometimes comes off,it pushes over nipple to load size water fill knob.if it came off the water will keep on flowing and over flow.if that's the problem just put a dab of silicon on nipple and push tube back on.
Feb 20, 2012 | Estate TAWS800JQ Top Load Washer
Water dispensor comes on by itself and floods kitchen
You need to replace the switch! You should do this before long to prevent it from flooding while you are asleep or away from the house. Please call us for parts! We will be happy to get this for you. Ella
Aug 25, 2009 | Maytag MSD2756G Side by Side Refrigerator
Dishwasher won't power off
Howdy. Flashing light on the switch, shows a glass? At any rate your overflow protection switch is activated. Probable cause; plugged or defective exhaust hose that does not allow pumping to go faster than water coming in, too high a water level. Clean the entire system first!
Is your exhaust hose going up to about threequarters as high as the machine? You must have this uphill twist and turn in the drain system.
A little water remains in the sensor and it thinks you are flooded. Force air through the pump in the floor until all is clear, a clean plumber's helper is ideal. Keep doing this until you get the last bit of water out of the sensor. When you get it running watch the machine (First time) carefully. You do not want a flood, that's why Asko put this safety device in place.
Jul 29, 2009 | Asko 24 in. D3112 Free-Standing Dishwasher
The water feed to the ice maker will not shut off.
Either the water valve has stuck open or the IM water switch is stuck. Unplug the wires from the water valve and see if the water has stopped. If yes it is the switch, if still running in the it is the valve.
Eric
Jun 20, 2009 | Hotpoint HSS25GFT 25.0 Cu. Ft....
The water wont shut off
Hi, It sounds like the mixer inlet valve has gone bad.
Did you try and shut the power off to the waser first with no results?
Please let me know so I can assist you.
Thanks
Vic
May 27, 2009 | Kenmore 24032\24036 Top Load Washer
Water continuously running to fridge, overflowing?
Hi, if the only way you could stop the water was to turn it off at the water source, you need to change the water inlet valve. Make sure you check the water fill line for any leaks before you change the valve.
If I canassist you in getting the vavle, please let me know.
Thanks
Vic
Feb 18, 2009 | Whirlpool ET0WSRXML Top Freezer...
Dishwasher refusing to run or running occasionally
fault is a leak you are right. to take off top, at rear just under top there are two plastic clips. push these with screwdriver and top will then come off. leak is prob main pump
Dec 05, 2006 | Bosch 24 in. SGS47E02 Exxcel Free-standing...
Whirlpool 24 in. GU940SCG Built-in Dishwasher Logo
171 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
