Question about Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835)
Ineed to lock acess on 2 ports off a 8 port wired router.
    Problem Solver:
  • 6 Answers
The best solution is the reset the Router, this will unlock it, there should be a little hole in the back of the router that you can poke with a paper clip, power on your Router while poking the hole, this will bring your Router to the state it was when you first bought it,
then you should have all the ports open, and be able to reprogram it.
Posted on May 28, 2010
How do I hook up my 2wire router?
Run a 2-strand or 4-strand telephone-wire from your telephone wall-jack to the telephone-port on the router.
Run an 8-strand "straight-through" (not "cross-over") Ethernet cable from one of the 'LAN' ports on the router to the network port on your computer.
Connect the AC power to the router, and turn it on.
You now should have Internet access.
Or, telephone the Technical Support department of your Internet Service Provider, and get them to help you, step-by-step.
Aug 19, 2011 | 2wire (2701HG-B) Wireless Router
We had to have at&t reconnect our dsl service. we had disconnected the Linlsys now we can't get it to work.Help please
Turn the DSL modem off.
Turn the Linksys router off.
Turn your computer off.
Check that all the cables are correct & are connected:
* 2-wire or 4-wire cable between telephone wall-port and DSL modem;
* 8-wire cable between DSL modem and the WAN (or 'Internet') port on the router;
* 8-wire cable between one of the LAN ports on the router to the network-port on your computer.
Turn the DSL modem on, and wait until its blinking-lamps settles down to a repeating pattern.
Turn the router on, and wait until its blinking-lamps settles down to a repeating pattern.
Ensure that the lamp for the WAN connection is on.
Turn your computer on, and let it boot.
Ensure that the lamp for one of the LAN ports on the router lights up as the computer is starting.
After your computer has booted, your router should have assigned an IP-address to your computer.
Click Start
Click Run
Type CMD
Press Enter
Type IPCONFIG
Press Enter
You should see an IP address like '192.168.xxx.yyy' for your computer,
and a similar IP-address for your "default gateway".
If you see an IP address like '169.254.xxx.yyy', then your computer has *NOT* obtained a *valid* IP-address.
Also, your router should have obtained an IP-address from your ISP (AT&T),
and you should have Internet access -- try to access 'www.CatsThatLookLikeHitler.com' (or any other web-site).
May 05, 2011 | Computers & Internet
I have a dynex 8 port gigabit ethernet switch. I see 8 ports but do not see a port to put the incoming ethernet wire. I put it in port 1 and put an outbound in port 2 but cannot connect to the internet.
Hello
Connections should go.Main internet to router,then from router to dynex switch,then to pc or pcs.
There is no main internet ethernet port, as this is just a switch.You need a Router before the dynex switch.
http://dynexproducts.com/cms/documents/DX-GB8PRT_10-1124_QSG_V1_ENG_Final%20Press.pdf
Apr 08, 2011 | Dynex Computers & Internet
How can I connect the router to my laptop if I don't have any internet. I mean I do have internet connection available on my landline but I need to set it all up on the laptop. how can I do this? I...
Use a 2-wire or 4-wire cable to connect from the telephone-jack to the telephone-port on your DSL modem/router combination device.
Use an 8-wire Ethernet cable to connect from one of the 'LAN' ports on the router to the network-port on your laptop.
Then, you will have Internet access, and, if this router also has a "wireless" capability, you can configure it to provide wireless access to your computer(s).
Mar 30, 2011 | D-Link ADSL 2+ Ethernet/USB Annex A Modem...
HVING PROBLEM ACESSING THE INTERNET THROUGH THE ROUTER . WIRELESS OR HARD WIRED . IFI RUN STRAIT FROM MODEM I HAVE INTERNET . ONCE CONNECTED TO ROUTER I DONT
connect the router wan port to one of the modems lan ports,
then connect to the router per lan or wlan and everything works.
Feb 24, 2011 | NetGear WNR2000 Wireless Router
The printers drop out the network when connected
Hello
Double check the IP Address info for both printers - ensuring the IP Address, Subnet Mask and Default Gateway are configured correctly. Printers should never use DHCP - so this info should be configured as a static IP.
Also, try moving the connections for the printers to different ports on the router. It is possible that the router may be going bad and the printer ports are the first to show the signs.
One final tip - power cycle the router. I have used D-Link for over 8 years and have had to power cycle their routers and hubs occasionally as they sometimes lock up. This typically affects all ports - so this is probably not the cause of your issue but power cycling the device may help resolve the issue.
May 04, 2010 | D-Link AirPlus DI-524 Wireless Router
Router / switch
For your type of varity the ideal harware would be a router. Preferably netgear.
May 30, 2009 | Computers & Internet
Need steps to reprogram chevy suburban 1997 keyless entery
1. Locate the Data Link Port. It is located under dash drivers side. Be sure you know
which pins are 8 and 4.
(Note port is wider at top) Your OBDII port will not
have numbers, use the for reference.
2. Make sure there are metal contact pins in terminals 8 and 4. Connect 8 to 4 with a
suitable jumper wire (leave the jumper wire connected throughout the programming
procedure). Make sure you know which terminals are 8 and 4. The vehicle will respond
by locking and unlocking the
doors to signify entering of programming mode.
3. Press and hold both the LOCK and UNLOCK buttons together on the first transmitter to
be programmed. After about 15 seconds, the vehicle will respond by locking and
unlocking the doors. Release the buttons on the transmitter.
4. Within one minute, repeat the previous step on the remaining transmitters to be
programmed.
5. Remove jumper wire applied to the OBDII Port.
Jan 15, 2009 | 1997 Chevrolet Suburban
Keyless remote programming
1. Insert keys in ignition and leave in the OFF position.
2. Locate the OBDII Port under drivers side dashboard.
(Note port is wider at top) Your OBDII Port will not have numbers, use this for reference.
3. Make sure there are metal contact pins in terminals 8 and 4. Connect 8 and 4 with a suitable
jumper wire (leave the jumper wire connected throughout the programming procedure). Make
sure you know which terminals are 8 and 4. The vehicle will respond by locking then unlocking the
4. Close Doors
5.
Turn ignition to the ON position (as far as you can go without cranking the engine).
Doors will
lock.
6. Press and hold both the LOCK and UNLOCK buttons together on the first transmitter to be
programmed. Up to about 30 seconds, the vehicle will respond by locking then unlocking the doors.
7. Within one minute, repeat the previous step on the remaining transmitter (if any – including any
existing remotes).
8. Remove jumper wire applied to the OBDII Port
Nov 25, 2008 | 1998 Buick Riviera
Dx-e402 router
hi,
Try this or this to open ports in PS3
Cheers !!
Feb 25, 2008 | Computers & Internet
Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835) Logo
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
