Question about Electric Razor Pocket Rocket Ride-on Motorcycle
Have a minimoto maxii 400 replaced rear tire when i took it apart all the washers and spacers fell out need to know the right combonation to go back together need drawing or photo or diagram to get it back together
  • 1 more comment
  • dempseya76
    dempseya76 Jan 08, 2012
    I have the Same problem with my maxii 400 pocket bike, did you ever figure it out or better yet do you have the diagram or exploded view of the rear wheel assembly? Please let me know~ ty Aaron in Nor Cal
  • Gnelson
    Gnelson Dec 06, 2012
    exploded view but does not have names of parts only numbers. Best I could find.
  • Gnelson
    my bad for got the link http://www.pocketbikemanual.com/freepock...
    New Friend:
Here is a link I found for the rear tire assembly. I think it will take some playing around to make sure everything is just right.
http://www.pocketbikeplanet.com/showthread.php?t=52784
Posted on Dec 06, 2012
Tip
How to take off the rear tire on a Kawasaki Drifter 1500
1. Lay out a towel/cloth to set fender on and protect.
2. With bike on jack and raised(back tire/wheel just off ground), remove entire rear fender.
3. Unplug wire harness left side just to front of left shock after you remove screw/cover. There's a 8mm bolt just above and over. Same bolt opposite side of fender.
4. Remove the 4 (12mm) bolts holding fender bracket to rear housing (left) and swing arm rear (right). Hold it because it will tip back and bang! It's not real heavy but you do need to support it.
5. When removed set on towel/cloth you have ready.
6. Release pressure from brake caliper (push/pull on caliper) remove brake caliper and hang it by wire (coat hangers work great) so it's not dangling from hose. Do not touch or let anyone touch brake pedal.
7. Remove the brake caliper bracket bolt that goes through swingarm. Place a towel/cloth on floor beneath brake area.
8. Remove cotter key from axle nut.
9. Remove axle while holding axle on the left side with wrench. You can use a large crescent on the axle nut so you don't have to remove exhaust/muffler.
10. As you loosen, slide axle to the left till nut clears muffler.
11. Now when you can slide the axle out. Support the tire/wheel as it is heavy. Caution: As the axle slides out of the brake caliper bracket the spacer could fall and hit towel (which is why you put the towel there see? It prevents too much marring.
12, Now you have room to slide tire/wheel assembly over to right and disengage from the gearcase. Caution: There is a spacer in the center of the gearcase that sometimes falls out and sometimes stays in (most of time). Just make sure it goes back the same.
13. When you're ready for the re-install, grease the drive splines with good quality axle grease.
14 Re-install everything in the reverse order you took it apart.
15. Re- torque rear axle from the left side and hold axle nut (right side) with same large crescent you used to loosen the nut and install a new cotter pin. Doing it this way saves you having to remove the muffler.
on Feb 16, 2010 | Motorcycles
Rear tires
pop off the center caps from both rear tires with a flat head screwdriver, and then remove the push nut washers by bending them with a pliers and removing them (keep in mind this will ruin the existing push nuts and replacements will need to be purchase from ebay or somewhere similar) then slide the tire off of the axle and replace (do not remove the axle cause there are spacers inside the vehicle that will fall out of place)
Mar 18, 2014 | Peg Perego John Deere Turf Tractor
KVD Quantum kinetic PT baitcaster reel, problem is I took it apart to clean it and couldn't figure out the right way to put it back together with all the spacers please help
I know how much everyone loves those reels They are great when they are new. But the truth is They are made to sell and they do sell. But I will bet a dollar to a donut that You would have 300% less trouble out of a Shakespeare Reel with less trouble and 70% less on cost and you cant wear them out.
Mar 31, 2013 | Fishing
We replaced the rear tire and brake on a 2005 yamaha 1100.each time it is reassembled, the tire is really tight to try & turn it. Any suggestions?
Quite common to get the parts in the wrong order. You should bave a shouldered spacer and a flat washer.
so looking from the back of the wheel...on the right side you should have the following..
wheel
shouldered spacer with shoulder into wheel.
flat washer
swingarm.
if the washers are in the wrong order it pulls caliper against rotor causing the drag
Mar 20, 2011 | 2005 Yamaha V Star 1100 Classic
My left back tire of a 1991 Lincoln towncar fell off & i was trying to replace rear lugnuts studs
remove all brake components off of that side, pound out studs towards center of the car with a hammer. place the new studs through the back of the axle and then use washers that just fit over the studs for spacers, and put the lugnut on the stud and tighten until the new stud is seated on the back flange of the axle. remove the lugnut and repeat for the rest of the studs.
Mar 20, 2010 | 1991 Lincoln Town Car
Hello my dad has a 1100 sporster any way we took the front tire off and we should of marked how every thang goes back togeather we cant get the tire back on right anyone have any answers what side the...
If you have no idea where the spacers went ,then try them on any way ,You will know if they are in the right position as the disc break will only line up one way .and when you spin the wheel it should run fairly free .If it binds then its not right .
Mar 16, 2010 | 2006 Harley Davidson XL 1200 C Sportster...
Statesman 5.5 Hp Rear tine tiller swing handle
Hello Debra:
Depending on the Units Model Numbers, you May be Able to View a Breakdown at the Following Site Addy.
http://www.searspartsdirect.com/partsdirect/index.action?sid=PSHx20080114x00001
If this Unit has a Model Number that is Not a Sear Number, then Send it to me and I can Locate the Correct Site Addy for you.
I have Just Joined this Site as an Expert and Hope to be here for a Few Years.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
John
May 08, 2009 | Garden
Need a diagram of rear disc brakes
Replaced rear drum brake 97 f150 4x4. A spacer/washer oval in shape with 2 notches on outer edge and a rectangular hole in center. Where did it come from? Fell out while taking drum off.
Jul 21, 2008 | Ford Mustang Cars & Trucks
Electric Razor Pocket Rocket Ride-on Motorcycle Logo
497 people viewed this question
Top Electric Toys Experts
ray gallant
Robert A. Watson
Robert A. Watson
Tom Chichester
Are you an Electric Toy Expert? Answer questions, earn points and help others
