Question about Hotpoint Ariston NWXR483EGWW Electric Dryer
Clothes getting stuck
I am having trouble with my dryer it is hotpoint is the brand, the problem I am having is it seems as though the "tumbler" part of the dryer is not alligned right my clothing keeps getting caught between it and the lint trap,
  • 166 Answers
Check the top drum slides and tub bearing slide support. it is made of plastic and when it or the slides wear out the drum will drop down enough for clothes to start snagging
http://www.easyapplianceparts.com/ModelFrames.aspx?ModelID=395857&ModelNum=NWXR483EG3WW&mfgModelNum=&ManufactureID=2&Selected=00125553i02&Position=3&mfg=GE&Type=&Mark=3
Posted on May 28, 2010
Hotpoint aquarius vtd00 dryer clothes getting stuck all the time how do I fix
hiis the rim of the drum seating ok or worn out because it will give u sharp edges its all i can think of take top off rotate by hand check rim allso try lifting drum if you have fair bit of play you need front bearing pads
Dec 28, 2013 | Hotpoint Dryers
My GE Adora dryer is ripping clothes
look inside the drum with a flashlight and look for broken or loose tumbler rib, can be fixed with epoxy, sand smooth surfaces first, let cure and use appliance paint to paint it
Jun 09, 2012 | GE Adora Super Capacity Dryer
My hotpoint dryer has a loud squeaking noise and clothes are getting stuck in the drum above the door leaving brown marks all over the clothes. Why????
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Oct 21, 2010 | Hotpoint TDL15 Electric Dryer
I have a Neptune electric dryer model MDE4000ayw. The clothes keep getting stuck around the barrel as the dryer is operating. What is the problem? It also makes a very loud noise as it operates.
You need to disconnect the dryer from power source, open the unit, it sound like the drum has holes on it that stucked your clothes when turning. this problem common to all maytag dryers. The front support glide had chop up . You might likely change the drum or tumbler.
Comment if the solution solve your problem
Dec 06, 2009 | Maytag Dryers
Dryer puts holes in clothes why
very care fully run your fingers along the inside edges of the tumbler both front and back
obviously your searching for something that is cutting your cloths so be care full it will cut you too
with the ge, i would tend to believe that your tumbler might be off or have worn though your front slides, they are made of nylon and fall out of place
check behind the door twords the top
Oct 25, 2009 | Dryers
I have a Kenmore 70 Series gas dryer, model 76712691. The dryer has 3 plastic ''tumblers'' inside the dryer, to help the clothes tumble. Two of the tumblers have fallen off inside, leaving big holes inside...
Pull the dryer away from the wall, there is no bottom on the dryer, so the screws should be on the floor.
You can then pop the lid up from the front and fold it back. When you do, you will see the drum. Roll the drum around until you see the holes and reattach the tumblers.
You can also access the drum from below. Tip the dryer on its back and you can see the drum from the bottom.
Good luck.
Regards,
May 15, 2009 | Kenmore Dryers
Dryer tumbler barrel loose
Depending on what brand a model. This sounds as though the guide roller or guide roller shaft are bad and are in need of replacement. It could also be the tub glides are bad. If you will give me the brand and model number I can probably tell how to check this and repair.
Nov 14, 2008 | Dryers
Hotpoint bwd129 washer dryer won't dry my clothes.
my Hotpoint dry will not dry my clothes. It will run for hours and the clothes still haven't dry just felt hot.
Oct 05, 2008 | Washing Machines
Clothes burnt?
The Front Drum Glide is worn out.
An easy fix.
Trouble is they are expensive...
The cheapest I have found so far is about $60.00, and I can't find an off brand.
It is recommended to also change the lower felt band if the first one is changed, at about $45.00, tho I found an off brand for about $20.00.
I can get a reconditioned dryer for about $100.00, therefore I'm still considering my options.
Hope this helps.
Gary
Jul 21, 2008 | Hotpoint NVL333EY Electric Dryer
Hotpoint Ariston NWXR483EGWW Electric Dryer Logo
157 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Dan Webster
Dan Webster
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
